Do any of you actually use DELTA brakes??
Old 09-07-23, 07:58 AM
  #51
El Chaba
Quoted: 184 Post(s)
Liked 504 Times in 183 Posts
El Chaba is offline
Old 09-07-23, 08:21 AM
  #52
smd4
Quoted: 2892 Post(s)
Liked 2,448 Times in 1,475 Posts
Maybe people are drawn to, and like things, that are so far outside the norm, that it's almost like they're seeing "The Emperor's New Clothes." Deltas offered nothing beneficial in terms of performance, ease of use/maintenance, weight or aerodynamics, and yet there is a cadre to this day who are mesmerized by them.
smd4 is offline
Old 09-07-23, 08:39 AM
  #53
Johno59
Quoted: 327 Post(s)
Liked 316 Times in 179 Posts
Like most rim brakes they are considerably different if you are caught in a cloud burst. If it's wet from the get go you adjust from the start. On a sunny day I reached a downhill when I suffered a cloudburst over the previous mile leading to s short sharp downhill.. I went to brake on my Delta braked Holdsworth and not much happened. At the T-junction I sailed thru a busy dual carriage-way and ended in a ditch. It was startling how poorer they were if wet. Usually brake pads begin to bite as you frantically squeeze harder to get the grime/water off the rim but this happened very slowly indeed with the Delta's.
Johno59 is offline
Old 09-07-23, 09:39 AM
  #54
styggno1
Steel is real
styggno1's Avatar
Bikes: 40 - accumulated over 40 years
Quoted: 367 Post(s)
Liked 1,037 Times in 293 Posts
styggno1 is offline
Old 09-07-23, 10:03 AM
  #55
Johno59
Quoted: 327 Post(s)
I just had a thought. When it rains does some of that lubricant that keeps smooth all the pivots/bushes/springs/bells/whistles behind the front cover, dribble down the housing, run along the caliper arm and onto the face of the pad wherein it deservedly kills you for taking it out in the rain!
Johno59 is offline
Old 09-07-23, 12:21 PM
  #56
Robvolz
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 855 Post(s)
Liked 1,245 Times in 479 Posts
Originally Posted by Steel Charlie
They could cost $1million and if I was given a pair and had to keep them they would never be on a bike. The pix in posts above are worth a few thousand words.
Just say'n
So you have no experience in how they brake.
"Leave the gun. Take the Colnagos."
Robvolz is offline
Old 09-07-23, 12:23 PM
  #57
Robvolz
Quoted: 855 Post(s)
So which bikes did you use your deltas on? I would like to hear your personal experience on their performance.
Robvolz is offline
Old 09-07-23, 12:25 PM
  #58
smd4
My fellow mechanic had them on his Bottechia. I didn't like them when I rode his bike. But then, I didn't like my Dura Ace 7400s.
Why do you think there were so many versions, and why, if they were superior, were they discontinued in 1992?
Next question?
smd4 is offline
Old 09-07-23, 12:28 PM
  #59
Chombi1
Chombi1's Avatar
Quoted: 1540 Post(s)
Liked 700 Times in 459 Posts
I never really tore down my Deltas but from what I coupld see, I think pretty much all of the pivots run on "plain" bearings, (I think they have bronze bushings on the main pivots.) IIRC. So I assume they can be badly affected by contamination from road grit. The big problem with the Deltas is, the caliper casing tends to accumulate/retain a lot of road grit.
I could not believe how much grit I had to flush out of the calipers, the first time I cleaned them.
Chombi1 is offline
Old 09-07-23, 12:35 PM
  #60
repechage
Quoted: 3239 Post(s)
Liked 2,505 Times in 1,786 Posts
Originally Posted by Chombi1
I jever really tore down my Deltas but f4om what I coupd see, I think pretty much all of the pivots run on "plain" bearings, (I think they have bronze bushings on the main pivots.) IIRC. So I assume they can be badly affected by contamination from road grit. The big problem with the Deltas is, the caliper casing tends to accumulate/retain a lot of road grit.
akin to watch repair.
found similar way back but in SoCal it was road dust - it never rains, well it never used to
repechage is offline
Old 09-07-23, 12:46 PM
  #61
Johno59
Quoted: 327 Post(s)
A quick blast of WD-40 before you replace the cover to keep everything sweet, will cause no end of problems. Folks do all sort of unhelpful things if they have paid too much for something. Grease on chains, inside SA hubs, powder coating etc etc. If it can happen it will.
Johno59 is offline
Old 09-07-23, 12:48 PM
  #62
Steel Charlie
Steel Charlie's Avatar
Quoted: 276 Post(s)
Liked 345 Times in 194 Posts
They're too ugly for me to care how they work
Steel Charlie is offline
Old 09-07-23, 12:57 PM
  #63
Johno59
Quoted: 327 Post(s)
Well you could at least give them a chance by painting them and riding backwards. I have a horse for sale.
Johno59 is offline
Old 09-07-23, 01:13 PM
  #64
Steel Charlie
Quoted: 276 Post(s)
You should hang onto the horse. They'll get to be pretty valuable when the food shortages hit
Old 09-07-23, 01:23 PM
  #65
repechage
Almost thought this blog was dead- found it.
campagnolo delta brakes: delta brakes
Likes For repechage:
Old 09-07-23, 04:05 PM
  #66
Johno59
Quoted: 327 Post(s)
I was wondering if the fully flared up derailleurs and other flamboyance thruout the groupset in the 1985 Groupo cataloge went with the Deltas calipers or was all that excess discontinued when the 'Delta' brakes were discontinued.
Johno59 is offline
Old 09-07-23, 04:58 PM
  #67
abdon
Quoted: 395 Post(s)
Liked 411 Times in 220 Posts
To me they don't have enough tire clearance. Grinding the bottom with a file may make them useable...
abdon is offline
Old 09-07-23, 05:13 PM
  #68
smd4
And unsellable. Two birds…
smd4 is offline
Old 09-07-23, 05:21 PM
  #69
Trakhak
Trakhak's Avatar
Quoted: 2031 Post(s)
Liked 2,346 Times in 1,336 Posts
Originally Posted by seagrade
Comparing Delta brakes with dual pivots was not a comparison that was possible when Deltas were released. I was and would still be quite happy with Deltas but I’d hope dual pivots would be an improvement, as I would monoplanars for that matter, which both followed Deltas.
I find it a little weird how Delta brakes seem so polarising. It’s not like C&V riders don’t accommodate numerous other safety and performance shortcomings in their parts choices with little or no concern from anyone…!
One of the attractions of C&V: lots of hills to die on.
Trakhak is online now
Likes For Trakhak:
Old 09-07-23, 05:25 PM
  #70
Chombi1
Chombi1's Avatar
Yes, tire clearance is minimal at best, I use 23mm tires on my Montello and it's really close, specially up front. It is so close that the tire tends to sandblast etch the bottom of the caliper cover with road grit that gets flinged off by the tire treads after some time.
Chombi1 is offline
Old 09-07-23, 05:53 PM
  #71
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Quoted: 3734 Post(s)
Liked 4,351 Times in 2,034 Posts
Say what one will, Campagnolo Deltas are firmly in the category of Classic Italian.
Regarding clearance for tires. I run Conti Sprinter 22mm, so not an issue for me. And best for an '86 DeRosa Pro.
Butt, for shats and giggles - I pulled a front wheel with Schwalbe S One's measuring 29.3mm (listed as 30mm) and they fit, so there are different versions to suit one's needs.
¿Who runs fatties on classic race bikes?
Ohhh, classic is pretty
Wildwood is offline
Likes For Wildwood:
Old 09-07-23, 07:17 PM
  #72
abdon
Quoted: 395 Post(s)
My comment was meant to be extremely tongue in cheek
abdon is offline
Likes For abdon:
Old 09-07-23, 07:19 PM
  #73
smd4
I know. I liked it!
smd4 is offline
Old 09-07-23, 07:25 PM
  #74
smd4
Okay, one will say it: They’re ugly, heavy, overly complicated, over engineered to no advantage, aero-adverse and by many accounts not great at the one job they have: stopping. By all accounts, they should have joined AX—and Bio-pace—in the dustbin of cycling history. But…they were Campy. And that’s all. A brand.
—Steve - a classic Italian himself.
smd4 is offline
Likes For smd4:
Old 09-07-23, 09:26 PM
  #75
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Quoted: 2100 Post(s)
Liked 3,181 Times in 1,132 Posts
Had a pair on a Bottecchia Team Record several years ago.
They worked OK, about the same as a half decent set of late 80’s single pivot brakes.
The dual pivots that eventually replaced them had more braking power and better modulation.
Oh, and I made my own 3.5mm allen wrench with a larger key and a Dremel cutoff wheel. Worked fine.
rccardr is offline
