Chain rubbing on chain ring
Quoted: 267 Post(s)
Liked 155 Times
Yeah that sounds like you're hitting trim first (which is designed to half-move the FD to allow large / large without scraping the cage) but if you push on through that first ratchet release, it should allow a full change without having to release & move the shifter again (I've never used Apex, but assume it's like Shimano in this regard)
Likes For choddo:
Bikes: Trek FX 7.3, Specialized Roubaix & Allez, Huffy RedRock, Aostimotor S17 ebike
Quoted: 153 Post(s)
Liked 198 Times
I've read somewhere that SRAM Apex requires a very tight cabling for FD, which would explain why it hesitates or takes two taps to downshift.
Quoted: 2893 Post(s)
Liked 2,448 Times
Cross-chaining simply doesn't make sense on its face.
Quoted: 453 Post(s)
Liked 377 Times
Trim won't prevent the chain from rubbing on the inside of the big ring. Unless you want to trim it to rub on the outer plate of the derailleur instead. This something you will regret after the chain wears a hole in it.
Little-little is the sacrificial gear. Short chainstays and wide gear spreads between the (50-34?) chainrings make this inevitable. Don't use it. You can find a similar ratio using your big ring.
Quoted: 267 Post(s)
Liked 155 Times
Quoted: 153 Post(s)
Liked 198 Times
Mine does the same thing. Also 2x10 SRAM drivetrain on a Specialized bicycle. This is normal for small-small combination.
As always, the intensity of this effect will depend on chainline parameters and chainstay length. But even longer chainstay bicycles often show this effect.
Quoted: 267 Post(s)
Liked 155 Times
Hey, wondering if this normal operation for left shifter. To shift to small chainring, I tap the lever once lightly, it clicks, but nothing happens to FD, I tap it a little harder and it clicks again and finally downshifts, literally double tap. If I shift with one single lever moment, it still click twice to downshift. RD shifts with single light tap.
Bizarrely, I read that in earlier SRAM groups, they had trim work the other way, for small / small which is what you orignally asked about. But they changed it because almost no one uses that combo for all the reasons mentioned above and the pros wanted trim in the big ring.
Quoted: 153 Post(s)
Liked 198 Times
I thought so too, but like I said fd did not move, I even tried to move it manually by hand in case it was sticking.
Likes For choddo:
It should move a little. If it doesn't, your shifter cable might be too short.
Likes For AndreyT:
