Clicking/creaking carbon saddle rails -- best solution?
Old 07-14-20, 09:05 AM
ljsense
ljsense's Avatar
Quoted: 284 Post(s)
Liked 152 Times in 92 Posts
I've got a saddle with oval carbon rails clamped into a Thomson seatpost. It clicks when my weight shifts on it.
The rails are in good shape, no cracks or damage. There's just enough micro movement to make a noise.
I had the two seatpost bolts torqued to 5 Nm. I increased that to 6 Nm, and that helped. I could keep tightening, but there is no torque rating on the rails, and before I did, I wondered if anyone has other approaches, like putting a paste or goop on the rails, or can provide a good max torque.
Thanks for any advice.
ljsense is offline
Old 07-14-20, 11:22 AM
canopus
canopus's Avatar
Bikes: Road, Touring, BMX, Cruisers...
Quoted: 135 Post(s)
Liked 173 Times in 111 Posts
A thin film of grease or oil usually takes care of creaks and such... Now, I am sure someone will come along a say that that stuff on carbon will eat away at whatever and cause your seat to disintegrate and cause you to crash and die, so...
The thing to determine is, is it the rails/clamps? or is it the seat? or is it the seatpost in the frame? You have to isolate each thing too determine the cause of the clicking.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
canopus is offline
Likes For canopus:
Old 07-14-20, 11:48 AM
frankenmike
mechanically sound
frankenmike's Avatar
Bikes: Indy Fab steel deluxe, Aventon cordoba, S-works stumpy fsr, Masi vincere, Dahon mu uno, Outcast 29 commuter
Quoted: 100 Post(s)
Liked 84 Times in 53 Posts
A light film of carbon assembly paste between the rails and the post would be a good thing to try.
frankenmike is offline
Likes For frankenmike:
Old 07-16-20, 12:16 PM
ljsense
ljsense's Avatar
Quoted: 284 Post(s)
Thanks for the responses. I was contemplating grease or carbon assembly paste, but I wondered if anyone had tried something else. A thin layer of tubular glue or barge cement came to mind, as did Loctite. I just thought in this interface, it might make sense to have something that acts more as a rubbery binder.
ljsense is offline
Old 07-16-20, 12:20 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
I have no real issues with my steel rail bike saddles, but then again at my age my hearing is less than acute..
have access to a vacuum pump ? Vacuum Bagging gets air bubbles in carbon fiber lamination out ,
while the resin has yet to cure..
So would pull your rubbery compound into air voids between saddle & frame , One presumes..
fietsbob is offline
