how to remove stuck cap?
I have a set of Powercranks. The end-caps are thick and important for the tricky, mysterious mechanism. One cap is seized. I drilled it and loosened the allen bolt that held the crank arm on but the end-cap won't come off. I'm thinking I need to drill 2 holes in it and make a stout pin-tool to undo it. Whattaya think? Any advice?
Quoted: 1438 Post(s)
Liked 1,092 Times
Not familiar with that model, but is is possible that the cap is left-hand threaded?
I'm assuming you want to remove the center piece.
Some motorcycle oil caps have curved detents like that and require a special tool.
I use a large washer turned by a large crescent wrench. The key is to find a washer that fits exactly with as little play as possible. And be sure to maintain downward pressure at all times to keep the washer in its place.
Good luck !
Good luck !
Bikes: Scott speedster flatbar, univega fixed gear conversion, Dawes Galaxy MTB
I have removed similar with a coin held in adjustable spanner. 'Copper' coins will be softer than the cap so will save it if it goes wrong.
Hey, fellow Powercranks rider --
If you're going to give the leveraging it another shot with the existing slots, the thing that fits well is the outside curve of a Park cone wrench. It's all alloy, so you might want to heat it up, break the bond.
What's going on with the cranks?
Before you destroy them, you can send them back to Powercranks and have them repaired at a very reasonable cost (I paid I think $75 a few years ago for them to fix the clutches).
I've interacted w the owner about salvaging these old things. I might need a fresh cap when i'm done. we'll see. I've tried some powerful usual ways of removing it. it is seized. i'll try the heating method and the park tool idea.
it's been a few months since i messed with them and i forget some details other than that i wanted to remove the cap so that's where i'm starting back up. the main problem was both cranks were slipping forward. and i think that was somehow over-tightening the caps. ?? maybe they need to be on but not too tight? does the arm rotate around them? i forget. i got the right one liberated but not the left. i think another issue was that the right arm was propelling the left arm. maybe i got them both to grab but then they wouldn't rotate independently of each other anymore. anyway the mission was to loosen the left cap. for some reason. these are tricky critters!
as i recall they were both regular threading. ??
