Practicing carbon refinishing - resources
Old 05-16-21, 11:41 AM
Plainsman
Quoted: 169 Post(s)
Liked 40 Times in 30 Posts
I bought these for $25. Thought they would be a great way to practice carbon fiber refinishing since I would like to be able to rehab scratched carbon frames, cranks, etc. Looking for some best practices (turorials) that cover techniques, safety, etc. FWIW, these bars seem to be structurally sound, but appear to have been adjusted a lot without loosening the clamps enough, so the finish that is missing is around the clamp area. Any links most appreciated!
Plainsman is offline
Old 05-17-21, 11:42 AM
burnthesheep
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times in 974 Posts
I was able to do some structural repair following these:
For your part there, likely first you'd have to mask off the area away from the scratches then sand the area down until you don't see them. If it wasn't structural (you didn't have a crack and didn't have a hole or didn't need to "cut" damaged fibers out) then you can likely just put on a fresh epoxy coat to protect where you sanded out the scratches and then sand and polish the dry epoxy it till you get the finish you want. As you'd likely only need to sand the surface level of original epoxy to get those scratches out. Usually that's thick enough it takes some serous sanding to get to bare carbon (when the sanding material turns black).
Use a mask! Sanding fines are bad.
burnthesheep is offline
Old 05-17-21, 03:43 PM
Kimmo
Kimmo's Avatar
Quoted: 1528 Post(s)
Liked 718 Times in 510 Posts
Problem with sanding carbon, aside from the nasty dust, is that it's easy to start going through it, which if you've got the traditional twill on the outside, due to the weave, is obvious.
Kimmo is offline
