Need 700c/29er wheelset built - PSIMET not responding
I'm looking for an all-black disc wheelset built, for my Cannondale Bad Boy Ultra. Budget is $450. I'd like a weight from 1500g-2000g, excluding skewers. Since this is for a bike that will see 100% street duty, brute strength is not the highest concern. Wheels will most likely stay planted on pavement, with few speed bump hops. I weigh 175. Nearly all eBay sellers want outrageous prices for what I am specifying. Can it be done? PM me, if need be....
S'Cruzer
for rather good prebuilt wheels, try handspun, if you get them trued up on arrival, they are as good as it gets, if they have what you want.
not familiar with that bike... you have any idea what hub size it takes? 135 rear, 100 front or what? and you want black hubs, black spokes, and black rims? this is 700C? how wide a rim do you want? how many spokes?
maybe this
https://handspunwheels.com/products/view_product/1851/
and
https://handspunwheels.com/products/view_product/1853/
? those are 29-er mountain wheels, which will should fit most 700c tires down to probably x28 or skinner.
or
https://handspunwheels.com/products/view_product/1738/
and
https://handspunwheels.com/products/view_product/1739/
(hybrid/cross 700c with dyad rims)
Handspun is affiliated with QPB, so most any bike shop can order these. the wheels are cheaper than you can buy the parts for retail, and they are quite well made. those dyad rims are bomb-proof.
maybe this
and
or
and
Quoted: 5766 Post(s)
Liked 2,538 Times
If you can source the components for $345 excluding spokes, I'll build them for you using Wheelsmith DB spokes. If you want different spokes, my alobo alone is $25/wheel or $50.00/pr.
This only make sense if you're in the Northeast, otherwise the shipping will be high. If you're in the midwest contact Yellow Jersey In Madison, WI who build great wheels at reasonable prices.
FB
Chain-L site
FB
Chain-L site
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
Salsa has nice light 700c disc rims...they build up quite well.
You should be able to pick up a set of Deore Disc hubs...for a decent price.
DTSwiss DB spokes...with a few locations here in the Bay Area where labor is 30-40 per wheel. Definitely doable...
=8-)
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Don't the Deore disc hubs weight a lot? I'd like the wheels to run under 1900g, minus skewers. Still possible, under $500?
Constant tinkerer
Here's a set: https://www.velomine.com/index.php?ma...oducts_id=1890
1960g, pushing your weight limit a bit, but only $210. I've bought from Velomine before and they were fine to me.
Quoted: 145 Post(s)
Liked 35 Times
If weight is a concern, why not focus on where it really counts focus wise at the rim side?
Salsa's would be fine, and the set FastJake linked to would be fine - though not double-butted.
It's almost as if you are trying to have it both ways...
=8-)
Disclaimer:
Disclaimer:
S'Cruzer
Handspun Pavement Series 1:
Deore XT 6 bolt disc black hubs, DT black Comp spokes (2.0/1.8), Dyad 32H black/reflective rims, 2211G together, MSRP $350 for both wheels.
or...
Handspun Mountain Comp Series 1 29er,
https://handspunwheels.com/products/view_product/1709/
https://handspunwheels.com/products/view_product/1710/
SRAM 505 6 bolt black hubs, DT black Champ spokes (2.0), DT X470 32H black rim. 2080G, $228 MSRP for the pair.
or...
Quoted: 145 Post(s)
Liked 35 Times
Providing suggestions...or shilling pierce?
=8-)
=8-)
Disclaimer:
Disclaimer:
S'Cruzer
suggestions. I have no skin in that game, they just came out on top of the wheel::value equation when I was researching upgrade wheels for my ride. I heard about them from several people I respect in R.L. that these wheels are very well made, and you just can't beat the price, its cheaper than you can buy the parts and build your own.
I'm thinking I'll get the Pavement Series 5.1 when I need better wheels for my hybrid (36H, LX hub, machined Dyads for rim brakes, DL Champ. Silver).
disk brakes are dragging on your weight target... a disk wheel has to take all the braking force as radial tension along the spokes, so they aren't likely to be less than 32H, and you won't find disks on ultra light weight road-bike wheels, strictly on mountain and cyclocross/hybrid wheels.
I am conscious about weight simply because I want the total bike to be under 19 pounds....and is willing to pay(reasonably) for it. I already have lightweight, German Magura disc brakes, carbon bars, carbon seatpost, race saddle and 780g crankset.
Quoted: 2026 Post(s)
Liked 1,095 Times
With that many expensive carbon components already on the bike, I would think having a low cost limit for the wheels shouldn't be a major consideration. What size tires do you plan to use? If not over say 700-32 then road rims would work fine and be lighter than 29er rims.
S'Cruzer
get a road bike. under 19 is easy (my 1975 steel bike was 19 pounds if I used the lighter grade tubulars etc), 17 lbs is doable. then, if you pound on it, expect a steady diet of expensive replacement parts.
Liked 1,095 Times
For that matter, well under 15 pounds is doable on a road bike. The UCI imposed that limit on race bikes to attempt top head off a technology war but it didn't work.
S'Cruzer
i suspect if you get much under 15 lbs, you're rapidly approaching the point of single use ... you get one good race, and poof, its rebuild-everything time. and we'd start seeing a lot more catastrophic failures during races, which would not be good for the sport's already tarnished image.
Liked 1,095 Times
Liked 2,538 Times
Not at all. Many pro teams have their bikes so far under the 15 lb UCI limit that they have room to add power meters and still have to ballast them to pass tech inspection. These bikes are rugged enough to last a full season or more. Sure they are maintained after each race but that was also done decades ago with steel bikes weighting 50% more.
BTW- pro rules dictate that only equipment available for sale to the public may be used.
FB
Chain-L site
FB
Chain-L site
handspun is run out of QBP .. there are other places to hire wheels assembled for you
OP wants a weight target as a priority.. good luck with that.
Sew up rims weigh less than clinchers..
Im sure there are weight weenie hubs , aluminum axles & such ..
maybe a large flange hub because the steel spokes are shorter, reduces the overall weight.
Ceramic bearings probably weigh less than steel ones.. etc..
Titanium spokes used to be made and sold.. now? IDK.
I dont own a Scale..
S'Cruzer
made a few for the public, just to meet such a regulation.
S'Cruzer
reminds me of that Dodge Daytona , aerodynamic nose, and a rear wing for downforce .
isnt XTR alloy axled? i know there are some really light discs made heat treated Aluminum or Titanium, .. Titanium freehub body..
light or low cost, pick one,
actually, its strong, light, cheap, pick any two.
Liked 1,095 Times
