Show Us Your 650B Conversions
#151
I am actually a mobile LBS with several distributors selling tektro, cane creek, velo orange, etc; I was hoping you might have specific model numbers of dual pivot calipers with a +75mm reach. The 650b conversions I have done in the past were all based off 700c bikes, but 27" bikes present more of a challenge as their brake reach is even greater.
Quite true. This is why I encourage as many people as I can to go this route. Plus, the more people who do, the more products will be made to accommodate it. Just look at how many new 650b options there are these days in both rims and tires. I am excited to try out Pari-Motos for myself soon.
#152
Quoted: 3788 Post(s)
Liked 6,573 Times
https://www.flickr.com/photos/26811168@N07/
She'll build you whatever you want, front or rear, I believe.
Those rims are Rigida Sphynx, no longer made. That's a sweet wheelset w/ Campy NR hubs, and is now on my Ebisu rather than on my gritty commuter!
Neal
#153
New account: KlunkerBiker
Bikes: Lots
What about a brake drop bolt in conjunction with long reach brake bolts. https://www.sheldonbrown.com/dpdropbolt.html
#154
consilio et animis
Bikes: It's not 'bout the bike!
#155
A 27" bike with long reach brakes from the factory is a really nice frame to convert to 700C as it most likely allows for a wider tire and fenders with the smaller 700C rims. How wide a tire can fit with fenders depends on the frame, but typically it's the next size up (or 2 sizes up) from the widest that originally fit. A 27" bike with 'racer' dimensions might work going to 650B if the frame was originally sized to fit really skinny tires, no fenders, and used short reach brakes with the pads at the top - but that's not a common frame design for a vintage 27" bike.
#156
Liked 6,573 Times
I have a set of Dia Compe 800 centerpulls; max reach is 85mm. A popular and pricey option is the Mafac Raid, which have at least 75mm of reach. I really regret selling the NOS set I had for $32! Excellent comparison chart here:
https://ruedatropical.wordpress.com/2...l-brake-specs/
Neal
Neal
#157
Bikes: Lots
Thank you everyone for your input. I look forward to making this conversion happen.
#158
N+1
Bikes: A few
Liked 5 Times
Why do the French always have to be a PITA. After reading this thread and seeing pics and mentions of a 650b Px10 I thought why not let's give it a try. I have a 72 px10 that has been repainted and upgraded with a mostly NR Campagnolo drivetrain. It also has a French Cinelli stem. I have been looking for a long French Cinelli with no luck. I bought it earlier this year and with the too short stem and needing new tubular tires I have ridden it. So I figured a 650b conversion might be in order.
I test fit the 650b wheels I pulled from an 80's schwinn mtn bike and put on a set of col de la vie tires I bought awhile ago. Everything fit perfectly and I found some weinmann 750 brakes that reach with room to spare. Then I found why the French can be a pain. The bolt hole on the fork isnt drilled even close to straight. I have thought of a few options and think I am going to replace the fork with a dimension 700c I can get from work. This way I can fix my brake issue and stem issue all at once. The wheels are steel hubs laced to single wall aluminum rims. I rebuilt both hubs at work today and converted the rear to a q/r instead of the stock bolt on.
I am thinking Tiagra hubs to Velocity Dyad rims running a 7 or 8 speed cassette friction shifted of course. The bar and stem will be Nitto Noodles and a Technomic I just traded for the other day. The CdlV tires will stay in the meantime and I plan to order some Tektro R556 brakes along with the wheel parts and fork. I just hope the fork can fit the 650b rims and the tektro brake has enough reach. It has the same axle to crown as the stock PX10 fork so I hope it will work.
#159
27" frame and brake reach
I have an old 27" frame that I'd like to go to 650B on, but it may be just too far of a reach.
The photo below is that of Zeus calipers against a 700c wheel. As you can see, I'll need long reach brakes to go to 700c.
Is it silly to think of trying for 650B? Or should I just get fat 700c wheels & tires, plus, of course, long reach brakes?
1959 Hilton Wrigley Connoisseur (my favorite!)
1963 Hetchins Mountain King
1971 Gitane Tour de France (original owner)
* 1971 Gitane Super Corsa (crashed)
* rebuilt as upright cruiser
1971 Gitane Super Corsa #2 (sweet replacement)
1980 Ritchey Road Touring (The Grail Bike)
1982 Tom Ritchey Everest
(replacing stolen 1981 TR Everest custom)
1982 Tom Ritchey McKinley (touring pickup truck)
1985 ALAN Record (Glued & Screwed. A gift.)
#161
Bikes: Lots
Your sidepulls don't look all that long, which may be why they're adjusted to the bottom of their reach. You can figure out your current reach needed for 27" wheels, and what you will need for 650b's.
If you remove your front caliper, and measure the distance from the center of the brake hole in the fork crown to the center of the braking area of the rim, then add 23mm, as this is the rough difference of radius between the two sizes, 27" and 650B, this should give you the brake reach needed for a 650b conversion. Using a caliper to take this measurement really makes things infinitely easier.
At least this is how I determine brake reach.. I think it's correct...
#163
Bikes: 76' Centrurion Pro-Tour, 86' Specialized Rock Hopper, 88' Centurion Iron Man, 89' Bruce Gordon "Hikari", 95' Rock Hopper Ultra.
Quoted: 14 Post(s)
#164
Very nice. A Stronglight 93 w/ 105bis rings? What RD is that, please? While you're also commenting on the ride.
It sure looks great!
#165
N+1
Bikes: A few
Liked 5 Times
The parts are a mix of old and new. The original owner I purchased it from had it repainted and after the repainted bought almost full Campagnolo Nuovo Record group for it. I didn't like how the r/d and rear shifter were working with the now 8speed cassette it sports on the rear wheel.
Here is the full parts spec:
63cm 1972 Peugeot PX10 frame and fork repainted by Matt Assenmacher
Stronglight roller bearing headset
Stronglight bottom bracket
Stronglight 93 crankset 170mm arms with 52/42 Stronglight rings
Crank Brothers Eggbeaters
Nuovo Record clamp on shifter mounts with Rivendell Silver shifters
Nuovo Record brake levers
Cinelli 1A stem (still too short)
Cinelli 66-42 bars
Tektro R556 dual pivot monster reach brakes
basic seatpost with a Brooks Swallow copy
Campagnolo BB cable guides and top tube housing clips
NR Front derailleur
Shimano 105 rear derailleur
KMC X9 chain
SRAM 12-26 8 speed cassette
Planet Bike Cascadia fenders (700c)
and the wheelset hand built by yours truly with Shimano Tiagra Hubs laced three cross to Velocity Dyad rims with DT Swiss 2.0/1.8 double butted spokes with Panaracer Col de la Vie 650b X 38 tires
#167
Quoted: 147 Post(s)
Liked 8 Times
I like your build. It does look like a Rene Herse or Alex Singer bike.
This is the poor man's way to build a homage to the great constructeur/porteur bikes in France of the 1940s and 1950s.
I have a Peugeot PX 10 built up as a 650B porteur ride.
#168
Papa Wheelie
Bikes: Jamis Aurora '02; Takara Medalist (650B)
Latest Conversion finally finished:
John Howard 'Turbo Dog'
I believe this is a 1985 KHS John Howard Turbo frame (with some of the cheesy decals removed)
Tange Infinity
I am running a 1 x 8 drive train with a single bar end shifter
Wheels: Rigida Sphinx rims
105 hubs w/8 speed cassette
Soma B-Line Tires
Grip King pedals
V-O City Levers
Tektro R556 brakes
V-O Porteur Bars
Nitto Technomics Stem
Cinelli tape
Brooks b-17
some ebay big setback seat post
PB Eco Rack
Tourney Crank (scrounged)
Modified 'chain guard' (52 tooth chain ring with teeth ground off)
Shimano Deore RX (scounged)
Planet Bike Cascadia Fenders (hybrid size)
Way fun to ride!
Home Made Chain Guard
(phantom left side shifter!)
(reverential pose)
Tange Infinity
Soma B-Line Tires
Grip King pedals
V-O City Levers
Tektro R556 brakes
V-O Porteur Bars
Cinelli tape
Brooks b-17
PB Eco Rack
Way fun to ride!
(reverential pose)
#169
Quoted: 8 Post(s)
Liked 15 Times
Wow, these are some beautiful conversions. Some help please, if you will. My daily commuter was stolen a couple of weeks ago and I've been thinking about how to replace it. I have a speedy bike, and a touring bike, and an oldie bike (all really nice fun bikes), but my daily commuter was fitted out with baskets and racks etc. I work as a carpenter and I've occasionally loaded my full kit onto my old bike to trek it across town to some job that requires my immediate appearance. I could make it on my old bike but it always seemed too wobbly for my taste. I've got a miyata 310 frame (for 27" wheels) and having read these great 650B conversion stories, I'm wondering if I should do the same. I would really like a sturdy bike to move my (heavy) tools around. I don't want a mountain bike type frame or anything really beefy, just a little bit sturdier ride than I had. Would this miyata 310 frame work for what I want to do? I'm ready to take the plunge.
thanks for any advice. I didn't want to start a whole new thread. Sorry if this is a hijack.
cheers Joe
cheers Joe
#170
I've done two 650B conversions. One was a new Soma mixte frame built up for my wife with a 650B wheelset and extra long-reach Tektro R559 brakes. It wasn't so much a conversion, per se, but more of a build conceived from the start, around a frame that was desigend for either 700C or 650B wheels:
The other was a true conversion of a 1980s Japanese touring bike built around 27" wheels. This was more of a challenge because the frame had cantilever brakes, and the mounting bosses had to be removed and rebrazed to fit 650B wheels. You wouldn't want to do this on a frame that you want to keep original, but I made the decision to do this knowing that the frame didn't come from any particular provenance and that I would be powder coating it anyway:
siggurd-- you can mount a bell to the unused shifter boss!
woodrupjoe-- a frame made for 27" wheels presents an extra challenge because it may not be possible to source brakes with enough reach. Bikes built around 27" wheels require, on average, an additional 23mm of brake reach compared to 19mm when converting a bike designed around 700C wheels.
Likes For southpawboston:
#172
No one cares
does anyone have trouble with 175mm cranks hitting pedals on the ground in turns on 650b conversions?
I prefer emails to private messages - holiday76@gmail.com
Jack Taylor Super Tourer Tandem (FOR SALE), Jack Taylor Tour of Britain, Px-10, Carlton Flyer, Fuji The Finest, Salsa Fargo, Santa Cruz Tallboy, Carver All-Road .
#173
Papa Wheelie
cheers Joe
cheers Joe
I've always found that I have to be reeeeeeally patient when I do conversions... waiting to find parts that will work locally for a good price.
Holiday 76: I may get a pedal strike if I'm really swooping around a corner. I think I run 170MM cranks. For me, the bike is a town / commuting bike so I just back off on speed and watch my pedals. It's not a suicidal issue. I have to be leaning way over to hear the *bink* of pedal metal. Quoting BikeMan "The bottom bracket will come down a bit with 650B tires, you can expect a lowering of about 8mm-10mm converting from 700x23mm tires to 650x38B tires. So a good 650B conversion candidate will have a bottom bracket height of about 275mm with 23mm 700C tires. More is better, but anything lower than 270 is risky. "
#174
Fahrrad Mama
Would it be terribly tacky of me to mention in this thread that I have a pair of brand-new VO 650b fluted fenders that I can't use? (too wide) Sorry if it's not the appropriate place to do so. It's pretty tough to find a 650b audience locally. I'm loving everyone's conversions. Can't wait to do mine!
#175
The housing is a NOS Soubitez Catalux 6 that I scored from an eBay seller in France. I retrofitted it with the internals of a new B&M Seculite plus LED taillight with standlight:
The Seculite is a screaming bright taillight, and the standlight function works very nicely... maintains full brightness for about 4 minutes.
I find this to be pretty accurate. My Shogun dropped 13mm after conversion from 27" to 650B, so that's consistent with Bikeman's estimate of 8-10mm for 700c to 650B conversion. I was patient in waiting for the right frame to come around for converting. The early 80s Shogun touring frame that I ended up with had a very high bottom bracket to begin with, at 182mm. After conversion, it's about 169mm... very safe. Also, if you end up getting more BB drop than is safe, this can be somewhat mitigated by using a narrow crankset and/or narrow pedals. The TA double crankset I chose has a Q factor of only 136mm, so it's very narrow.
For 175mm cranks, I would say you need a BB height of at LEAST 265mm after conversion, or 275mm before.
