Go Back  Bike Forums > Bike Forums > Winter Cycling
Bike Cleaning - Vinegar
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Old 06-21-21, 10:44 AM
parkbrav
Quoted: 220 Post(s)
Liked 114 Times in 97 Posts
Can Vinegar hurt a bicycle frame if a very low amount gets sprayed onto it?
My dad's house has vinyl siding. part of the siding needed routine cleaning with water and vinegar. I brought my water sprayer normally used for the bicycle. I mixed some white vinegar in with the water in the sprayer and sprayed the siding. the siding is now clean. I forgot that the container now has a very small amount of vinegar when I sprayed down my bike. Did I do baaadddd?
parkbrav is offline
Old 06-21-21, 05:24 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,581 Times in 2,342 Posts
where's a chemical engineer when you need one?
rumrunn6 is offline
Old 06-21-21, 05:39 PM
nathand
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D, Xtracycle Swoop, 1992 Trek 790
Quoted: 87 Post(s)
Liked 107 Times in 62 Posts
I haven't been a chemical engineer in years, but I do have a degree in it. While spraying your bike with an acid isn't ideal, a small amount of diluted white vinegar is not going to have any significant negative effect on your bike. I'd rinse it off with some water if you're concerned, though.
nathand is offline
Likes For nathand:
Old 06-24-21, 08:03 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6219 Post(s)
Liked 4,218 Times in 2,365 Posts
No. Where’s a chemist when you need one. Chemical engineers are just plumbers who know a (very) little about chemistry
My favorite nerd joke: A chemist and a chemical engineer walk into a bathroom. They do their business and the chemical engineer walks to the sink. The chemist starts walking out the door. The chemical engineer says “Hey, buddy! In chemical engineer school, they taught us to wash our hands after going to the bathroom!”
The chemist replies “Well, in chemistry school, they taught us not to pee on our hands.”
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 06-24-21, 08:12 AM
cyccommute
cyccommute's Avatar
No, it shouldn’t ld be a problem. The question to ask, however, just what do your think vinegar…assuming household vinegar… is going to do to clean the siding. White vinegar is 5% acetic acid in water. It’s mostly water. Adding more water makes it more mostly water. No matter what the Intertubz says, vinegar is a very poor cleaner. My favorite dumb Intertubz chemistry is to add vinegar to baking soda. It makes sodium acetate and some carbon dioxide. It cleans nothing.
Get a commercial surfactant based cleaner. It won’t hurt your bike either but will do a better job of cleaning.
Finally, why in Winter Cycling?
Stuart Black
Old 07-04-21, 09:33 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
My dad, a chemist, told me: "You can tell a chemist, because they wash their hands before they go to the bathroom."
Gresp15C is offline
Old 07-10-21, 06:03 PM
Medium Size Dog
Bikes: 98 Trek 6000 MTB, 70's mutant St. Etienne
Quoted: 45 Post(s)
Liked 49 Times in 32 Posts
IMO. Don't know about you but I keep things pretty clean inside my pants. I wash the world off of my hands before I reach for anything in there.
Medium Size Dog is offline
Old 07-16-21, 08:59 PM
jmphill01
I've tried vinegar once for trying to remove rust but would not recommend it for anything on a bicycle. For rust I use a product called Evaporust. It is a very safe product and does not eat into good metal like an acid can. I filled up the tubes of a steel frame once and sealed it up to derust everything. Then I spray a bunch of Fluid Film to prevent rust from taking course in the future since I ride through a lot of salt in the winter. For general cleaning, dish detergent or Muc-Off bike wash are pretty good. For gummy sticky stuff like adhesive I will use Goo Gone but it might harm certain finishes but generally is pretty safe.
jmphill01 is offline
Old 07-21-21, 09:07 PM
VegasTriker
Quoted: 523 Post(s)
Liked 229 Times in 181 Posts
The answer is no, a dilute vinegar solution will not hurt your bike frame. Remember you can drink the stuff right out of the bottle and not even get a stomach ache. It is an acid but a very weak one. It also evaporates easily so there will be nothing left once the smell is gone. And yes, I am a chemist. This holds true for the 3% variety you buy in the grocery store. Just don't try drinking the 30% concentrated acetic acid found in a lab.
VegasTriker is offline
Old 07-27-21, 08:41 AM
cyccommute
cyccommute's Avatar
I’ve never seen 30% acetic acid in a lab. We always have glacial (100%) and just dilute to the concentration needed. My point above, however, still holds. Vinegar won’t hurt the frame but it’s not going to do much good at cleaning either.
Stuart Black
