What plug does shimano use for the di2 charge port?
over $100 for a 2s lipo charger is silly. Does anyone know what kind of plug is used, so I can build my own?
https://imgur.com/a/ubOHbzw
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
It's proprietary.
Quoted: 453 Post(s)
Liked 104 Times
If you can afford to buy a DI2 equipped bike, you should be able to afford the chargers etc that go with it.
Just buy the OEM stuff
Quoted: 6193 Post(s)
Liked 4,808 Times
You could buy an SM-BCR2 and cut the end off of it.
https://www.universalcycles.com/shop...s.php?id=60079
Not completely certain the plug is proprietary as it seems like a long time ago I had something else that looked very much like it. But it certainly isn't common.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Quoted: 800 Post(s)
Liked 512 Times
Buy the OEM part and you'll probably save yourself some headaches down the line when other parts of the system mysteriously start shorting out...
Quoted: 1248 Post(s)
Liked 1,323 Times
Rather than purchase the plug get a couple simple round female pin connectors and build it up from there. Not sure what a new Di2 battery costs but I am sure you are going to find out pretty soon.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Quoted: 836 Post(s)
Liked 1,061 Times
Zemo, I would also add that if you have a good amount of expertise in building your own chargers than ignore the rest of this, but if not, building your own can be very dangerous as many fires have started from poorly made lithium battery chargers. There have even been 2 housefires within a mile of my apartment in the last 18 months that were caused by homemade chargers for ebikes. The $100 for a new Shimano charger is cheap insurance.
Likes For Crankycrank:
Quoted: 532 Post(s)
Liked 621 Times
Quoted: 3238 Post(s)
Liked 2,084 Times
What a dumb idea.
