A pretty familiar story (650b conversion)
Old 07-02-20, 12:02 PM
abshipp
abshipp's Avatar
Quoted: 3331 Post(s)
Liked 3,562 Times in 1,228 Posts
Originally Posted by Andy_K
Welcome to the club. We should get T-shirts.
I've got two sets of 650B A23 wheels, one with the standard silver rims and one with polished silver. Trouble is I've only got one 650B bike. Hmm.... What can I do about that?
Mine are the polished ones
They're replacing a mis-matched set of Synergy/Atlas, so I'm in the same boat!
What to do, having a MTB/touring grade set of 650b wheels....what to do....
abshipp is offline
Old 07-02-20, 01:38 PM
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1953 Post(s)
Liked 3,634 Times in 1,671 Posts
Originally Posted by abshipp
Don't they build up nicely?
This bike looks super fun, kudos!
Must be A23 build week, I finished up a 650b A23 wheelset Tuesday evening
they tension and true so well. I should use good rims more often.
52telecaster is offline
Likes For 52telecaster:
Old 07-02-20, 01:47 PM
noglider
noglider's Avatar
Quoted: 7287 Post(s)
Liked 2,365 Times in 1,382 Posts
You should go way down in pressure. You'll see why.
noglider is offline
Likes For noglider:
Old 07-02-20, 02:23 PM
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,798 Times in 1,798 Posts
Any problems with crank length from the conversion and lower overall bike height?
A 650B has been on my to-do list for my Univega Via Carisma. Partly to lower the height a bit -- the frame is slightly large for me but generally comfortable after tweaking the fit with a different stem and handlebar. But I'm also hoping the conversion will contribute to a plusher ride.
Much as I like the bike with the current setup -- Nitto albatross bar -- something about it jolts my old neck injury the wrong way on chipseal. And chipseal has increasingly become the standard pavement in my area. I've tried various height/reach tweaks but nothing quite resolves the problem.
Recently I switched my Ironman to latex tubes and was surprised by how much it improved the ride quality. It's more comfortable on bad roads with latex tubes and decent 700x25 tires than my Univega with 700x38 tires at lower pressure.
I'm at the limit of tire width with the 700c setup, but there's plenty of room for fatter tires if I convert to 650B. Even if I could fit fatter 700c tires, it would also raise the overall bike height, which is already marginally tall for me. I think it's a 58cm frame, maybe 60cm, and I'm 5'11" with 33" inseam.
I'll probably need to replace the 175 cranks with 170 to make it work and ensure enough clearance.
canklecat is offline
Old 07-02-20, 03:44 PM
52telecaster
ambulatory senior
I have 3 bikes with 650b conversions. A 175, 172.5 and 170 crank on the respective bikes. I really dont notice pedal strike issues on any of them. The 175 is on a px10.
Old 07-02-20, 04:08 PM
noglider
noglider's Avatar
@canklecat, everyone is different, but somehow I can adjust to stuff like that easily. When I'm on a bike at risk of pedal strike, I coast through turns without thinking about it. You might be able to, also.
noglider is offline
Likes For noglider:
Old 07-02-20, 04:10 PM
natterberry
natterberry's Avatar
Bikes: ‘83/‘85 Trek 760, ‘82 Trek 614, ‘77/‘78 Trek 304, ‘74 Raleigh International
Quoted: 285 Post(s)
Liked 220 Times in 138 Posts
I’ve only ever hit once, and I was probably doing something stupid.
natterberry is offline
ctmullins
Lurker
Bikes: Various home-built frankenbikes
Quoted: 18 Post(s)
Liked 37 Times in 23 Posts
For this build, the difference between the old 700x28 and the new 650x42 is a reduction in diameter of at most 3mm. So, negligible in terms of standover height, but transformative in terms of ride quality!
1987 Nishiki Prestige (now 650B!)
1981 Trek 710
198? Nishiki Olympic 12 mixte (now 650B!)
2020 Surly Troll fat-tire build
ctmullins is offline
Likes For ctmullins:
Old 07-02-20, 04:11 PM
ctmullins
Lurker
Quoted: 18 Post(s)
Can you quantify “way down” for me?
1981 Trek 710
Old 07-02-20, 04:36 PM
52telecaster
ambulatory senior
in my exp on 38s about 35 to 40 psi is real nice, but i weigh 200 lbs. I very often start higher.
Old 07-02-20, 05:52 PM
noglider
noglider's Avatar
I can't quantify. I weigh 165. On 32mm tires, I am in danger of bottoming out on potholes at 30 psi, but I've managed. The more weight you have, the higher pressure you require. The wider tire you have, the less pressure you require.
noglider is offline
Likes For noglider:
Old 07-02-20, 07:40 PM
seedsbelize
smelling the roses
seedsbelize's Avatar
Quoted: 7081 Post(s)
Liked 901 Times in 612 Posts
Originally Posted by 52telecaster
i very often do that when i lace. It doesnt bother me at all. My son has a23s in 700c on a bianchi. Light and strong!
Same. It's shocking how easy it is to do that. About half of mine come out like that
seedsbelize is offline
Likes For seedsbelize:
Old 07-02-20, 07:48 PM
seedsbelize
smelling the roses
Well I just started thinking about a 650b conversion on my 80 Trek 414.
Old 07-02-20, 07:50 PM
Korina
Happy banana slug
Korina's Avatar
Quoted: 1524 Post(s)
Liked 1,513 Times in 906 Posts
Try taking them down to 40 and see how they ride. If you don't bottom out, you can try going down some more until you find the sweet spot.
Korina is online now
Old 07-02-20, 07:53 PM
natterberry
Quoted: 285 Post(s)
The way should be clear. Proceed
Old 07-02-20, 09:57 PM
bwilli88
Not lost wanderer.
bwilli88's Avatar
Quoted: 885 Post(s)
Liked 979 Times in 514 Posts
I never saw the bike in person, got it from nlearner and he sent it directly to gugie
As sold to me, nlearner's pic
After a little massaging, the gugieficatizion.
Now if this Covid-19 crap would go away and I could get back to the States I could build it up. Looking at Dura-Ace 7600, I think, with some nice Velocity rims and some Paselas 650bx40.
Gugie built it for Mafac racers. Hopefully it will replace my Centurion Pro-tour here are my #1 bike.
bwilli88 is offline
Likes For bwilli88:
Old 07-02-20, 10:33 PM
52telecaster
ambulatory senior
killer!
Old 07-05-20, 06:45 PM
ctmullins
Lurker
Quoted: 18 Post(s)
Bottom bracket is knackered. It’s a Performance-branded cartridge bearing unit I bought about thirty years ago. I suppose I can retire it finally....
I came this close to ordering the ubiquitous Shimano UN55 replacement. Thank goodness I came to my senses and ordered a NOS SunTour cup-and-cone unit for three times the price.
1981 Trek 710
