Braking squeaking
Braking squeaking
all sorted
Hi When i brake hard on my front brake its squeaking I’ve cleaned changes the pad bed them In like 20 miles while not braking hard and now when I brake hard it squeaking my back brake is fine any advice would help
p.s tried different rotor and like 2 sets of pads
hydraulics disc brake
Liked 2,968 Times
what material are the pads? Some are more metallic than others & can cause an audible resonance. If brake performance is not impacted, it would be just a personal preference to address it, otherwise, it make stop or fade less over time of being a nuisance. You can try a 200ish grit even scrub followed by a clean wipe down using denatured alcohol on both sides of the rotor to see if it changes any. If it does lessen or eliminates the noise & comes back, it's likely the pad material. If it never returns, then you removed a potential surface contaminant.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 6193 Post(s)
Liked 4,808 Times
Just like rim brakes I've had in the past, with my disc brakes if they start squalling, then I just make sure they are clean with some alcohol and it goes away after a ride or two.
Usually they develop an annoying squeal after riding in the rain. But again, just not worrying about it every moment gives it time to fix itself in a ride or two..
Likes For Iride01:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Damn OP, could you maybe make that post a little easier to understand? Try some punctuation every now and then. Like periods at the end of sentences. ... . .
maybe don’t comment if u don’t understand I’m not expert on writing/spelling I try my best to word etc and I understand if no one comments because then it means my wording all wrong but then get daft people like u with your comments
Bikes: lots
Liked 2,932 Times
I'm trying to help you out. You don't need to have a degree in creative writing, I'm talking about middle school knowledge.
Likes For Cyclist0105:
Liked 4,808 Times
Which is more important? Your brake issue or rebuking someone that you feel impugned upon you wrongly?
I always make sure to clean the rotors before using new pads, then make sure to bed them in. Everyone has their own method, but I still believe that fast to hard and long braking works best for me. Good luck
Bikes: lots
Liked 2,932 Times
all sorted
