mount water bottles onto carbon fork
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I have a carbon road bike I plan on using for a weekend tour. Due to space constraints I need to mount the water bottles somewhere other than the main triangle (I'm using a frame bag as well as a saddle bag). I was thinking of using these from Topeak to mount water bottle cages on each side of my carbon fork:
As the forks weren't meant for this, is there any danger or things I should watch out for? These are plastic mounts so I'm not too concerned about damaging the forks but may use protective tape just in case.
Thanks for the help!
P.S. I'm using a 2007 Specialized Roubaix Comp Triple.
Likes For Rick:
Quoted: 83 Post(s)
Liked 64 Times
No to fork mounts. Easiest solution is 2 Revelate Feedbags. Bonus is they insulate and give you extra storage pockets. Wolf tooth makes some cage mount options to check out too.
If I was using my road bike for a one-time weekend tour, I would probably just zip tie a couple of cheap water bottle cages to each side of the fork. Zip ties are cheap, disposable and hold well. Of course I would wrap something (maybe electrical tape or friction tape) around my precious carbon fiber fork before zip tying around it.
Quoted: 3426 Post(s)
Liked 1,441 Times
I have used a Two Fish bottle holder on my folding bike, but in that case the base of the cage sat on the bike frame. The velcro and rubber method of attachment might slide if you tried that on a carbon fork. I would not advise that for your bike, although it worked great for me where I could strap it to a seatpost extension and support the base of the cage on the frame.
I put some sticky backed foam (weatherstripping) on my frame to protect the paint from the cage.
My folding bike only had one cage, I had two more liters in the saddle bag. This was in West Texas where you can get quite thirsty. The Two Fish cage gave me a second liter on the frame.
I suspect you will end up using a backpack with a hydration bladder. A lot of bikepackers I have seen carried a backpack.
Bikes: Corvid Sojourner, Surly Ice Cream Truck, Co-Motion Divide, Co-Motion Java Tandem, Salsa Warbird, Salsa Beargrease, Carver Tandem
Quoted: 533 Post(s)
Liked 435 Times
I think they are excellent. You can cinch the bottle real tight with the bungee or loosen it up completely. The bottle stays in by gravity and IMHO does not require cinching at all so you can just grab it and pull it out and just plop it back in when you are done.
Given that it is a tour, you could even stop, and fish the bottle out of a pannier, or the like. Racers need quick, convenient access to their water, tourists are not so pressed for time.
If I had to fasten something to a carbon frame, I would clean and lightly sand the place I wanted it and them epoxy on a mounting plate/hard point that could take the screw. I would be careful to place it where it did not alter the flexing of that part of the bike.
Quoted: 345 Post(s)
Liked 237 Times
I ended up getting a bladder as it holds more and keeps the weight low. I also got a mount for the stem in case the bladder takes up too much room.
I like immediate one handed access to water
i found mounting on the forks to be to unstable as I jettisoned a water bottle
Quoted: 581 Post(s)
Liked 921 Times
My concern about a jury rigged fork mount is that forks are generally tapered, and the weight of the bottle pulling down will tend to loosen whatever clamp you are using.
Likes For ClydeClydeson:
