Trek FX 7.1 or 7.2 Max Tire Width?
Quoted: 17 Post(s)
Considering purchasing a Trek FX 7.1 or 7.2 (size 20"). What is the max width tire that this model of bike can handle?
Quoted: 5223 Post(s)
Liked 3,579 Times
fyi - got some 700x45s on one (old) bike I'm positive will fit on my (not as old) 7.0 Alpha
Bikes: Trek Allant 7.2, Trek Soho S
Quoted: 15 Post(s)
Just measured from my 2016 frame (Allant 7.2, same as FX 7.2). The smallest opening is the fork, 56 mm wide. The inside measurements of the rear triangle are slightly wider.
I have the stock 700x35s on it, but I'm sure 45 would fit in the frame. The rims might be another story, they're 22 mm wide on the outside in mine.
Liked 3,579 Times
my 45mm riddler sidewall reads
tire section 44mm
recommended: use 17c - 29c inner rim width
tire section 44mm
Bikes: 80/90's Specialized Crossroads (3), '91 Miyata Triplecross, '91 Bianchi Boardwalk, 2002 Schwinn Frontier, 2002 Gary Fisher Tarpon, 2009 Trek FX 7.2, 2014 Motobecane 400 HT
Quoted: 9 Post(s)
I finally put some 40mm Kenda Kwicks on my 25" 2009 FX2 to smooth out the ride. The chain stays are plenty wide, but I have to mount the tire partially deflated since it bumps into the fender mount behind the kickstand before I can slip the axle into the dropout. Once the wheel is mounted, the fully inflated tire has plenty of room.
Liked 3,579 Times
Quoted: 9 Post(s)
rumrunn6 – So far, I haven't mounted any fenders, so it's just the mount that gets in the way. That would be a good place to install an old-school tire saver, now that I think of it.
Liked 3,579 Times
I'm late to this discussion but in case anyone still has the question, I asked at the trek site for tire range size for FX 7.2.
Their reply: 700 x 28C to 700 x 38C.
(I am getting a flat a day now & need replacements).
Liked 3,579 Times
my Trek 7.0 Alpfa currently rides with 40mm WTB Nano tires (at I think around 60-70psi)
different bike, I know. the rest of my family has FX 7.1 or 7.2 & I think they all have 32mm tires, but might be able to fit 35mm tires
