2012 Yetis SB-66, Full Suspension MTB
Old 08-23-21, 12:11 PM
katlinbr
katlinbr's Avatar
Bikes: Road, Cross, Mountain
2012 Yetis SB-66, full suspension mountain bike with new brake pads and fluid. Fully cleaned and lubed. In great condition and is ready to rock and roll!
Purpose: Trail / all-mountain
• Hydroformed 6061 aluminum frame
• Rear-wheel travel: 6"/152mm
• Fox Float CTD rear shock
• Fox 34 150 CTD fork
• Switch Technology Suspension
• Tapered InSet headtube, 44/56mm
• 12 x 142mm rear axle
• Splined BB shell w/ ISCG-03/05 adapter
• Weight: 27.4 lbs (w/o pedals )
• Sizes: small, medium, large (tested ), XL
• MSRP: $6,800 USD as tested
Super Bike Suspension
The highlight of Yeti's SB series is their Switch suspension design. Yeti employs a rotating main pivot that is mounted on an eccentric, allowing it to change direction in order to react to opposing suspension forces. The eccentric assembly continuously repositions the lower pivot of the swing arm throughout the range of travel. Acting as a dual link design, it allows the early stages of travel to guide the lower pivot of the swing arm rearward, lengthening the chainstay.
Frame size: S/M
Seat tube length:17"
Top tube length: 23"
Wheels: 26"
Crankarms - Shimano XTR (26-38)
Rear Derailleur - Shimano XTR 10 speed
Front Derailleur - Shimano XTR
Shifter Pods - Shimano XTR
Handlebar - Race Face SixC
Stem - Thomson
Brakes - Shimano XTR
Wheelset - DT Swiss M-1700 Tricon
Tires - Maxxis Ardent, 2.4 Front, 2.25 Rear
Seat WTB Yeti Branded
Seatpost Thomson
katlinbr is offline
