Go Back  Bike Forums > Bike Forums > Fatbikes
Fatbike wheels
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Fatbike wheels
Old 05-08-21, 06:36 PM
Witrailpro
Fatbike wheels
Hello all,
I am in the process of changing my fatbike to make it more mountain bikeish for non winter riding.
My bike is a Framed Minnesota LTD.
Where would be a good start to finding a wheelset?
I will up size to 27.5 rim. The front is 150mm with a thru axle and the rear is 177mm quick release thru axle.
Any thoughts and ideas would be much appreciated as i cannot be the first biker to complete this conversion.
Witrailpro is offline
Old 05-09-21, 09:21 AM
jim_pridx
jim_pridx's Avatar
Bikes: 2010 Bob Brown Cycles tandem, 2019 Co-Mo Carrera tandem, 1980 Richardson tandem, 2014 Cervelo R3, 2018 Specialized Roubaix, 1985 Bianchi Campione, 1983 Trek 720, 2020 Trek Fuel EX8, 2021 Salsa Mukluk
Quoted: 72 Post(s)
Liked 114 Times in 70 Posts
Yeah, a lot of people do this, so you're certainly not alone! We just did the very same thing with my wife's Salsa Beargrease so that she could do some summer singletrack riding with me. You might want to talk with Mike at LaceMine29. Depending on your budget, he can build a custom-built wheelset that'll fit your needs. He's a great wheelbuilder that doesn't charge an arm and a leg for his work!
https://lacemine29.com/
jim_pridx is offline
Likes For jim_pridx:
Old 05-09-21, 07:08 PM
Witrailpro
Thanks much for the wheel source.
Likes For Witrailpro:
Old 05-12-21, 07:37 AM
prj71
Quoted: 2265 Post(s)
Liked 738 Times in 492 Posts
Here's another source that is probably a better deal than Mike. But I would go with 29 tires not 27.5 on that bike. If you go 27.5 you will lower the bottom bracket height which would lead to possible pedal strikes if you ride off road.
https://www.speedgearbike.com/
prj71 is offline
Old 05-12-21, 04:32 PM
Witrailpro
I dont want to be close to the ground as this is my off road bike.
​Than kk s
Old 05-13-21, 01:59 PM
jim_pridx
jim_pridx's Avatar
Quoted: 72 Post(s)
That's a great point! We ended up going with a 27.5" summer wheelset on my wife's bike - primarily to improve her standover height - but it has resulted in more pedal strikes. In our case, going from a 26x4.6 to a 27.5x3 actually lowered the BB by at least one-half of an inch. She would definitely be better off with 29s or perhaps shorter cranks.
Old 05-14-21, 06:21 AM
prj71
The thing is the outer diameter of 26" fat = 29" mountain bike tire.
prj71 is offline
