Birdy thread
#1901
So I‘ll rephrase my reply since the original text was lost:
Please use Loctite with whatever adapter you buy. Both the H&H adapter and the Brompton luggage block came with Loctite blue.
#1902
Thanks, I always do, on all bolts that are not supposed to be unscrewed.
Likes For Jipe:
#1904
Did the same, put short ones in. There is a hole from the inside too, added washers to make sure bolts don’t touch each other inside the fork.
#1905
I’m about 100kgs and my R&M Birdy Touring came with red rear elastomer which seems to be a little too soft. Trying to order hard one but they don’t seem to be available all that wide. Found this one but its grey and it reads hard. As far as I know hard ones are green. Is there a difference for elastomers for Birdy 1, 2 or 3 or they fit all models?
#1906
Likes For jackyharuhiko:
#1907
Schwinnasaur
[QUOTE=fatbikeGM;22565839]Apparently I can not even _quote_ URLs before 10 posts …
Please use Loctite with whatever adapter you buy. Both the H&H adapter and the Brompton luggage block came with Loctite blue.[/QUOTE
The adapters have tiny set screws that are used to lock in the top (tension) bolts by screwing them down on the threads of the tension bolts. I think that even if the set screws were to back out, that having used them, the threads of the tension bolts would be damaged and will resist being unscrewed. They also supply a loctite type liquid.
#1908
judging from the price these are made from solid chunk of gold. I looked at different options with sane prices for front suspension but they all are stiffer than stock and I think stock is fine for me for now. If not there are options to change the spring for a stiffer one.
#1910
Quoted: 800 Post(s)
Liked 247 Times
jackyharuhiko has a Pacific Cycle Birdy, most Pacific Cycle Birdy are factory equipped with the 10.5 turn softer front spring while Riese & Müller Birdy are factory equipped with the harder 8.5 turn spring.
For me, the original front suspension with the 8.5 turn spring is perfect ( I am around 80kg), the softer 10.5 that was factory mounted on my Ti Birdy was too soft especially with a loaded Brompton front bag.
I tried the Multi-S G5+ suspension set (that seems very good with a front spring+hydraulic damper and sophisticated rear multi-rubber system) and it was bad.
The rear is ultra hard, there is almost no suspension. I couldn't compress it by pushing on it, then I put it in a vice and even so, the max compression I could obtain is about 5mm.
The front is also harder with a shorter spring that results in a shorter travel than the original and the top ring for the hook has a rectangular groove that doesn't fit with the shape of the frame hook (which is designed to hook a spring = a round object) with as consequence a continuous rattling noise coming from the front suspension.
I also tried the Ridea PU 100 hard rear suspension and it works slightly better than the original but the M3 very long mounting bold was broken several times, I eventually glued the several parts of this PU block instead.
Likes For Jipe:
#1911
This is the information about my front suspension and the rear suspension - a newer version released in early 2021.
#1912
I kept the front light, because if was difficult to find something better that isn't put at risk when folding the bike. I added an on/off switch to the dynamo wire. It's a 12-volt rated water resistant toggle switch, mounted to a small plate of aluminium bolted to the light mount. When it's off, both lights are off and the front wheel spins much longer, so it seems to do what it should.
https://www.flickr.com/photos/gunnst...7700342795322/
I replaced the tiny caliper mounted taillight with a bigger standard carrier mounted light with a reflector. Point shaped light sources give little indication of distance. Bigger (not necessarily brighter) lights makes it easier to judge changing distance for someone who approaches from behind. I had to extend the cable and lead it up to the carrier, making sure nothing is damaged when folding. Not a great photo, but you can see it under the carrier, behind the roller wheel:
#1915
I just checked B&M IQ-XS model which is 70lux (or 80lux acc to b&m site) like supernova E3 Pure and has almost identical dimensions, 50 x 40 mm vs 49 x 41 mm on Supernova E3 Pure 3. Difference is IQ-XS has a built in switch and light sensor which automatically switches it on/off, two side light strips for side visibility, aluminum casing. Also back light connection, so B&M rear light can be installed on the rack. Dis you consider this option before? I’m pretty sure IQ-XS will also have excellent optics and wide beam. Not sure how reliable it is though as there were few reviews on the Amazon saying it died after less than a year.
#1916
What would be the effort to switch? I assume the cable is fixed to the lamp, not attached via a plug, right?
#1917
Likes For glye:
#1918
On the R&M site it only says "Hub dynamo Shutter Precision" so no idea but I would not expect ours to be better.
The way I read the graph in the cylclingabout article under "Results: Dynamo Hub Drag and Output Power Using Different Lights" ist that until 20 km/h is reached the SP has the least drag. That would be fine by me.
I am surprised by the total amount of drag though: Nearly 9 Watts (and half of that even with the light off) at 25 km/h is quite a lot. My average performance over an hour is about 250 Watts so that's 3,6 %. Cyclists have gone to great lengths to pursue smaller gains in efficiency.
Between this, the weight of my luggage and the excess weight on my hips atm I wonder how fast I could be without all that ...
#1919
I will handle it like you: If the Supernova light ever breaks I will replace it with this.
#1920
Good find!
However I have another small wheel bike, and there the SON is an interesting option, because of the very low drag with lights off (which is most of the time). Their folding specific hub won't fit as it is 74 mm and has no space for disks, but they claim the SONdelux is "for road bikes and smaller rims" so it's optimised for high rotation speeds.
I would also like to see a test of the Shimano 1.5W hubs. They are small, lightweight and deliver half the power, but with higher rotation speeds of small wheels it might be enough. They would be a bad option for USB charging, though.
#1921
A duckduckgo search for "birdy son dynamo" brings me to a uk dealer called "sjscycles" [still not allowed to post URLs ...] who appears to have a SON hub for Birdy in stock.
But again the price (>200 gbp) puts it in the luxury category. At least it's polished silver and I like my Birdy to be all-black, so I desire it a bit less ;-)
#1922
For zero drag with lights off there is the Velogical rim dynamo which I have on another bike: https://www.velogical-engineering.co...ation/?lang=en
It runs on the rim, not the tyre as the old style bottle dynamos do, so there is no tyre wear. It is also extremely small and light weight. It is an easy retrofit since there is no need to rebuild the wheel. The only downsides are the cost (still less than SON) and some running noise (where hub dynamos are completely silent).
#1923
AFIR there _used_ to be a SON hub for Birdy, it's just discontinued.
Costs about the same as the standard SONdelux which they recommend for small wheel bikes. If the goal is minimum resistance then SONdelux is probably the better option I think. The Birdy specific one will likely give better light at low speeds. (Edit: NB the sondelux won't fit the birdy, so for that there is only the linked one or the standard SP.)
#1924
For zero drag with lights off there is the Velogical rim dynamo which I have on another bike: [URL removed]
I like this alternative even better since there is no drag when not in use.
I could probably live with a little noise while in use. That does not disturb me too much on my ebikes either.
And regarding the cost: It's still cheaper if you add (re-)building a Birdy wheel, no?
#1925
Ah, this almost feels like a chat by now with these fast responses :-)
Possible hack: It would be nice to be able to engage it when riding at daytime, when I suddenly get to a tunnel. It is likely possible to make a remote using a spring, shifter wire, and a friction shifter on the handlebars. Whether the sudden acceleration would be bad for the electronics I do not know. Mainly useful for tunnel countries like Norway.
