Help me find where the click is coming from
Bikes: Moots Vamoots, Colnago C60, Santa Cruz Stigmata CC, and too many other bikes I don't ride
Quoted: 152 Post(s)
Liked 7 Times
- Two quick click-click sounds
- Happens with each revolution of the crankset
- Sounds like it's coming from the bottom bracket area (but not 100% sure)
- Gets louder when I pedal harder or ride out of the saddle
- Also, it seems to get louder the longer into the ride, say 15 miles in, and I notice it more
The bike is a 2008 Cervelo RS.
Help, please. It's driving me nuts.
Try to isolate it. But the bike on a stand and crank away. Sit on the bike and flex the stem. Take off the rear wheel and spin the cassette. Coast. Etc.
If you're having a hard to isolating the click. Re-tighten everything (make sure to do it to the right torque). Lube chain. Then go from there.
Usually when I have a clicking noise it's usually the bottom bracket.
Bikes: are better than yours.
Clicks always sound like they're coming from the BB, but as often as not, they aren't. It could be anywhere.
Telemachus has, indeed, sneezed.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
i had a regular click from every pedal stroke. I don't know exactly where it was, but i got rid of it by pulling the cranks out and cleaning and putting them back in.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Sometimes it's the crank hitting the front derailleur cable.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
strip the whole bike down and re-build it after cleaning every little part and allen bolt. shouldn't take too long.
The Weird Beard
The click is coming from inside this thread! I've had the derailleur cable thing happen to me. Took me longer than it should have to figure it out.
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Also pedal standing up, see if it stops then sit on the seat not clipped in fake the pedaling motion see if you still hear it, then alternatley pull on the bars as if you are pedaling but keep your feet still. just to narrow things down.
Don't Believe the Hype
Bikes: 1999 Steelman SR525, 2002 Lightspeed Ultimate, 1988 Trek 830, 2008 Scott Addict
Quoted: 21 Post(s)
look at the connection between cleat and pedal. Oil/lubricate lightly. This will all go away.
Also check the excess cable when you are in the small chainring.
Bikes: Cervelo Soloist
SocialCyclists Forum
Poseur Extraordinaire
Bikes: 2009 Wilier Izoard, SR11, Edge 68s
Sucking Wheel at the back
Bikes: Lynskey Helix Sport, Lynskey M290, Cervelo S3
