Bottom Bracket Cable guides
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 322 Post(s)
Liked 596 Times
Bottom Bracket Cable guides Fisher Montare
I just picked up this Fisher Montare (T6G Ser.#) and the FD needs adjustment. The bottom bracket guides are stock. I don't like how the cable rides against the bottom bracket, metal to metal, and cuts into the paint/metal.
Can anything be done for this or a dab of grease as regular maintenance?
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
grease there will collect dirt and cause more wear... see if the holes are big enough to fit V-Brake Noodle Tube Liners in there! I've used them on old canti-brake bikes to line the rear guide on the Seat tube....and several other similar situations.
Likes For maddog34:
Quoted: 4201 Post(s)
Liked 3,858 Times
One could clean up, prep and paint touch up the now bare spots. Then, as maddog34 mentioned, use a cable housing or noodle liner that fits within the guides. Do know that depending on conditions these anti friction liners tend to be of limited lifespan.
If you do decide to touch up the paint consider how much opening the guide have to accept a liner over cable. If there's any burrs or filler closing up the openings now would be the time to deal with that.
I have run my gear cables bare against many of the frames I have built since the 1970s. Only the times I neglected their maintenance for too long (cleaning mostly) have I had issues with gear shifting. But I don't ride in salty conditions these days like I did when younger so don't think much about this on my current bikes. Andy
AndrewRStewart
AndrewRStewart
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,481 Times
In trivial matters such as this, I go with what the frame designer intended.
And it looks like you need new cables.
Henderson, NV
Quoted: 322 Post(s)
Liked 596 Times
Henderson, NV
Quoted: 322 Post(s)
Liked 596 Times
I see now.....
A Mt Tam
A Mt Tam
Likes For Desert Ryder:
Quoted: 3511 Post(s)
Liked 2,925 Times
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 116 Post(s)
Liked 209 Times
I use the housing ling also, but mine were smaller holes so I had to get Jagwire shift cable lining with is even smaller than the brake version. If a bare shift cable could wear through a bottom bracket, then surely it would eat through those plastic liners. It doesn't. If you want "something" to spray on the rustiness, that Fluid film stuff seems to stop rust just fine. I use it on my snowblower that's loaded with heavy rust.
