View Poll Results: Bottom Bracket Fixed Cup Removal Schedule
Never
2
3.28%
Only if damaged
27
44.26%
Only if it comes out on the first try
6
9.84%
On a regular basis
26
42.62%
Voters: 61. You may not vote on this poll
Bottom Bracket Fixed Cup Maint/Removal
It seems merziac and I are in the minority when it comes to bottom bracket fixed cups ( see https://www.bikeforums.net/classic-v...ight-pull.html ). So, here's a poll to see if we have any allies.
Likes For leftthread:
Likes For gearbasher:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2197 Post(s)
Liked 4,596 Times
My approach:
- if just for maintenance, I'll check for damage and if none is apparent, I'll check if it is still tight and most often just clean and grease it in situ
- if it is to be replaced with a shorter/longer/whatever different type, I'll remove it. If that turns out to be a risk and it is in good shape, I will reconsider the replacement and look for other options
- if it needs to come out because it is damaged or I really want that particular Gipiemme triple, it comes out, no matter what
Quoted: 4510 Post(s)
Liked 6,377 Times
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 529 Post(s)
Liked 1,000 Times
Before I got the proper tools, I would leave the fixed cup in place and clean it the best I could from the opposite side. Now, I don't think twice about removing the fixed cup to do a proper overhaul.
Likes For Pompiere:
Liked 6,377 Times
Likes For merziac:
Liked 6,377 Times
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Of course, this leaves the original question. Suppose you have a cartridge bottom bracket that last for an improbably long time. For instance, maybe you invested in a Phil Wood and after 20,000 miles it's still spinning smoothly. Would you ever remove it just to regrease the threads? Me personally? No.
So I voted, only when damaged.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 964 Post(s)
Liked 1,451 Times
I like to maintain fixed cups in situ if possible. However, there are lots of reasons to remove one.
I will remove a fixed cup based on a couple criteria considered at the same time.
I consider, in the following order:
- Is it damaged? If it is, sure, take out by whatever means necessary, unless I believe the bike is not really going to be ridden much at all.
- Can I get it out? If I can easily, sure, take it out.
- Is it RH or LH threaded? I am more likely to leave in an RH threaded fixed cup because it might be stuck (and that's a good thing in this case) and it might be hard to find another one!
- What's the future use going to look like? If it's going to be commuted on in salt and weather, or ridden in muddy sandy areas, I will remove it and change it for a sealed BB regardless of the condition, to save the future strife.
- What's the BB? If it's worth saving/preserving/reselling, and not on this bike, then I'll take it out and replace it with something appropriate for the quality level of the bike and its expected duty. I might even consider polishing the pitting out of an old damaged cup from a respectable marque, depending on the extent of the damage. There is absolutely no sense in leaving a nice Campy or Stronglight or TA BB on a bike which is going to be used for all weather touring or commuting!
Likes For scarlson:
Liked 6,377 Times
Quoted: 2363 Post(s)
Liked 1,749 Times
I'm between choices 3 and 4, leaning toward 4, esp. since reading the recent admonitions of some of the "do it every time" purists. So far I haven't had one thwart me yet, but I suppose if I encounter one that really puts up a fight, and it's for a low-buck build / rehab, I may opt to leave it in.
Likes For madpogue:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 582 Post(s)
Liked 697 Times
Moved to “Politics and Religion”.
Likes For sd5782:
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
Weld or glue in place; purchase grease gun extender tube. Procure and use a high suction vacuum. Scoff at the crunchy sound after you put it all back together.
I just sell the frame.
All joking aside, I take it out every several overhauls, not each one.
Liked 6,377 Times
Liked 6,377 Times
Shop mechanic: "The DS BB cup is stuck, can I just leave it?"
Shop manager: "Sure, I'll have somebody that can do it get it out, don't bother coming back tomorrow."
Liked 6,377 Times
Likes For merziac:
Liked 1,749 Times
Liked 6,377 Times
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
When I took the 1959 Capo to CyclArt for a repaint, I needed help removing the fixed cup. Jim Cunningham had a bench vise mounted atop a long pole in the middle of a large room, and that was the only way we could garner enough leverage to break it loose.
For an ISO, British, or Swiss-threaded BB, I can justify removing the fixed cup, but how about Italian or French? I find I need to use Loctite to keep those fixed cups "fixed." Is it really advantageous to take these in and out and grease the threads when they inherently have trouble staying tight because of a major (self-loosening) design blunder?
Bikes: 1981 Bianchi Specialissim, 1976 Colnago Super. 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1
Quoted: 276 Post(s)
Liked 951 Times
I fully strip all bikes when they come in (including removing the fixed cup). Otherwise when I'm doing routine maintenance I will remove the fixed cup every other time.
Likes For SwimmerMike:
