Old Frame, no Derailleur Hanger
I have an old frame that used a claw type derailleur. Unfortunately no hole to mount a derailleur hanger on the dropout. I can easily drill and tap a hole. Would having someone braze the hanger in place be overkill? Its getting new paint so no worries about torching the paint
Old fart
Quoted: 3571 Post(s)
Liked 3,366 Times
Why not just get a claw to mount the derailleur? Is there something unusual about either the dropout or the derailleur that precludes this?
Likes For JohnDThompson:
I am potato.
Quoted: 1764 Post(s)
Liked 1,577 Times
Should be fine.
The plus side is no retaining nut means that modern high number cassettes won't have interference issues between the small cog, chain, & the frame/hanger nut.
You might braze on a hanger to both sides & remove the unneeded bit on the NDS so that both dropouts are the same thickness (8-9mm-ish) so that long axle nubs & QR's play nicely.
IMG_0554 by Richard Mozzarella, on Flickr
IMG_0553 by Richard Mozzarella, on Flickr
Old fart
Liked 3,366 Times
Aha! Got it. Yes, I was going to get a claw, need to drill a hole in the dropout to secure it. I was thinking braze a claw onto the existing dropout, but that makes no sense, you would just braze in a new dropout.
Likes For etherhuffer:
Old fart
Liked 3,366 Times
You shouldn't need to drill any hole. Claws mount into the dropout slot:
Should be fine.
Quoted: 928 Post(s)
Liked 1,594 Times
Posted this fix over 12 years ago. I have done this on three bicycles and they are all working fine. I run 34T Cogs on my freewheels so I needed a longer hanger.
https://www.bikeforums.net/classic-v...lded-puch.html
Likes For zandoval:
Old Bike Craphound
I also recently "discovered" that even among these two types, not all claws are the same length, and I was able to get a RD to work with a larger freewheel by going through the bin at my local bike co-op to find a 6mm longer claw to get the RD to sit further from the sprockets.
-Will
-Will
feros ferio
Quoted: 1384 Post(s)
Liked 1,293 Times
I face the same issue with my most recent acquisition, the 1962 Carlton Franco-Suisse, which surprised me by never having had a derailleur hanger. For starters I plan to use the SunTour VGT and claw that were on it when I got it.
