painting over chrome?
Old 01-21-23, 10:28 AM
jadmt
jadmt's Avatar
Bikes: Handsome xoxo, Serotta atx, Canyon Edurace CF8
Quoted: 454 Post(s)
Liked 991 Times in 457 Posts
I found a vintage chrome fork that I want to use on a vintage mtb. Is there a way to paint it black without having to strip the chrome? I am guessing there is no good way to do it but figured would not hurt to ask.
jadmt is offline
Old 01-21-23, 10:29 AM
Robvolz
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 677 Post(s)
Liked 923 Times in 360 Posts
you have to etch the chrome, then primer then paint
"Leave the gun. Take the Colnagos."
Robvolz is offline
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 2781 Post(s)
Liked 2,428 Times in 1,303 Posts
I think you need fancy primers or something
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Likes For Bianchigirll:
Old 01-21-23, 10:54 AM
Wright Bros
Bikes: '92 Schwinn Paramount PDG 2, '92 Trek 930 & '98 920
Quoted: 26 Post(s)
Liked 18 Times in 5 Posts
I've painted over chrome many times by just cleaning it with alcohol and painting. It never peels and in fact it pretty hard to remove but when you do the chrome looks brand new underneath if you ever want the chrome look again.
Wright Bros is offline
Likes For Wright Bros:
Old 01-21-23, 11:13 AM
jadmt
jadmt's Avatar
Quoted: 454 Post(s)
that is why I really don't want to strip or etch it. what paint did you use? thanks
jadmt is offline
Old 01-21-23, 11:14 AM
jadmt
jadmt's Avatar
Quoted: 454 Post(s)
don't really want to etch it in case I end up wanting to go back to the chrome, unlikely but possible.
jadmt is offline
Old 01-21-23, 11:32 AM
zandoval
zandoval's Avatar
Quoted: 759 Post(s)
Liked 1,300 Times in 832 Posts
If your not going to recover the chrome latter on then a simple light sanding with 400 grit and a cleaning with a drying solvent like acetone will do. I have done this several times and have successfully used Rustolium rattle can primer and then painted over it with Rustolium enamel.
This fork was in real bad shape, so much so that the Peugeot logo impressions at the top of the fork were eroded. After a close inspection inside and out I did some heavy sanding to get all the rust and chips off. It was not hard and I did a diligent cleaning afterwards. I brush painted this frame with Rustolium enamel and it is holding up really well. I don't do Moutian Biking but my local torn up asphalt roads can do a real number on frame paint. That is why I brush painted it...
zandoval is offline
Likes For zandoval:
Old 01-21-23, 11:13 PM
Wright Bros
Quoted: 26 Post(s)
I've mostly used black Krylon which I'm pretty sure is lacquer by how quickly it dries.
