Brake hangar for centerpull front brakes?
Hi,
I'm working a retro-roadies build, on a Centurion ProTour. The frame came to me with cantilever-like posts and center-pull brakes on them. (DiaComp?).
But, in setting up the cockpit, I don't know how to get enough brake hangar clearance for a clean run.
Brake hangar only 5/8" or 3/4" below stem
Is that going to be an acceptable cable routing? It seems like the cable &housing is going to take a fairly steep bend to reach the hangar cable stop.
Am I just overthinking this?
Or, are there longer drop hangars that I thought be looking at?
I bought a hangar stop that mounts on the front brake center-hole (https://www.modernbike.com/product-2126251742?gclid=Cj0KCQjwmN2iBhCrARIsAG_G2i4kNzfIqUVeFHb-sNBNZyJP5yiA6yKoPHn5I9b4yOoEuKVBRLLTEjMaAt13EALw_wcB)/, but it looks nether high enough nor flat enough to clear the post-mount brakes.
I almost wonder about something longer, like (https://www.modernbike.com/product-2126181880?gclid=Cj0KCQjwmN2iBhCrARIsAG_G2i65AvM2hSrOiLLJ4vdpKbzawZlFTNSefDAHGYkWoJFBDSqG8y2_TzgaAlS rEALw_wcB) and using aircraft cable to hang.it off the stem. But that seems ugly and I hesitant to jury-rig brakes.
Suggestions?
Suggestions?
Quoted: 4806 Post(s)
Liked 3,928 Times
DIacomp makes a traditional hanger that hangs around an inch lower and includes a cable release lever. It's rather nice. I bought front and rear last year, new. I think they are still in production. I paid just ordinary bike shop prices, not any NOS jack-up.
Edit: there are also brass? curve tubes that replace that cable housing stop. They make for a nice smooth cable bend. A housing from an aero-style brake lever will turn nicely into it. Don't have a name for you. I purchased mine in some distant century and I highly doubt they are still made.
Second edit: You could also drill the stem and run the cable or cable plus housing through it. Bikes have come new with that. I wouldn't because I am superstitious about the "path" of forces from my hands to the road; ie bars, stem, steerer, fork, front wheel. I gambled once and lost - big time.
Likes For 79pmooney:
Quoted: 1829 Post(s)
Liked 3,375 Times
I've rotated the hangar on the steerer tube so that the adjuster barrel isn't directly below the stem. It doesn't look quite as nice and symmetrical, but it works fine.
If your hanger is keyed to the steerer tube, my idea would require filing off the key on the hanger.
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
Liked 3,928 Times
Steve in Peoria
Steve in Peoria
Quoted: 1949 Post(s)
Liked 2,010 Times
I always wanted a Paul.
https://www.paulcomp.com/shop/compon...-cable-hanger/
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 116 Post(s)
Liked 209 Times
Dia Compe makes a flexible linear brake noodle that's applicable here, called a "Flexi" that has a cable adjuster and comes in silver or black. It's just a noodle with standard cable ends of course(one in, one out), so it's not limited to, or by, any brake type it's applied to. Porkchop BMX sell them both. https://www.porkchopbmx.com/search/flexie/
If the cable noodle rubs against the stem and that bothers you, a little clear Racers Tape will do, or heck, even clear packing tape if you have nothing else.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
Firstly, get rid of that butt ugly threadless stem and get a real stem.
That bike calls for a retro stem since you are building a retro roadie bike.
This is my 81, I think I used the same thing on my 83 but that had cantis.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
For canti's I use Paul hangers and RH cable yokes.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Hi,
I bought a hangar stop that mounts on the front brake center-hole (https://www.modernbike.com/product-2...At13EALw_wcB)/, but it looks nether high enough nor flat enough to clear the post-mount brakes.
I almost wonder about something longer, like (https://www.modernbike.com/product-2...gaAlSrEALw_wcB) and using aircraft cable to hang.it off the stem. But that seems ugly and I hesitant to jury-rig brakes.
Suggestions?
Suggestions?
Stuart Black
Stuart Black
Thanks to all who replied. I found DiaCompe hangers on eBay that appear to be significantly lower, and will go that route.
If the routing still seems too tight, I will file off the tab and accept a slight diagonal pull.
Quoted: 116 Post(s)
Liked 209 Times
They're more flexible than regular housing, hence the name "flexi". It's able to negotiate tight bends where brake housing would want to straighten itself out.
Edumacator
Quoted: 2439 Post(s)
Liked 3,123 Times
Quoted: 753 Post(s)
Liked 737 Times
I've used a flexible V-brake noodle above a hanger, to get under a stem, where the cable housing wouldn't make the bend. I think I got the noodle from Problem Solvers.
Quoted: 192 Post(s)
Liked 566 Times
Late to the party, but you do need a hanger that is lower allowing more room to route the cable. Failing that, if the stem is of sturdy construction, you can drill the stem directly over top the brake straddle cable and use the stem as the cable stop. Drill a small hole big enough to comfortable clear the cable all the way through and at the top drill a larger hole big enough to clear the cable casing and an end ferrule to act as the casing stop. Drill the larger hole only deep enough to clear about half the length of a ferrule. (Just to increase photo content in the thread a lower front cable hanger is pictured)
Quoted: 874 Post(s)
Liked 2,287 Times
A longer hanger would help but I think , ultimately , a different stem would be the best solution .
Likes For El Chaba:
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
you can find a hanger with a noodle to accept a cable entry from the front
somebody suggested using a stainless steel "noodle" from a V brake - great idea
I don't care for the ones that hang way down as they will hit the top tube if the steering is deflected too far.
/markp
/markp
Not sure where I get adjustment with that solution, though.
Quoted: 502 Post(s)
Liked 466 Times
Another option would be a cable stop that bolts to the fender attachment hole in the fork crown and extends upward for clearance above the straddle cable. Sorry, no photos to offer.
Ive dealt with quite a few of the “cable stop hole in the stem” on bikes rebuilt for Bike Works in Seattle (https://bikeworks.org) and they work, but make any changes in stem height a pain.
