shifting issue
shifting issue
so i picked a new bike the other day...everything is working well except one thing. I have an mechanical 11 speed, when im in the 11 cog occasionally the chain skips like it maybe trying to shift gears.the indexing seems to be very crisp and precise so i dont think that is the issue but what do i know....any ideas? lol please dont tell me to take it back to the shop, im sure this is a very easy fix and its more of a hassle to go back there!😂
Quoted: 645 Post(s)
Liked 797 Times
Quoted: 1819 Post(s)
Liked 1,693 Times
Likes For alcjphil:
sounds like the chain is trying to pull itself up onto the next largest sprocket, ie, your RD cable tension is too high. I would try screwing the RD barrel adjuster in (clockwise) a half turn and take it for a spin. This adjustment shortens the effective length of the RD cable housing, thereby reducing cable tension. If you have a stand, best thing to do is to put the RD through it’s paces on the stand. The half-turn adjustment will potentially affect shifting on all the gears. If you find that shifting to larger sprockets becomes a little hesitant across the board, then back the barrel adjuster out (counter clockwise) 1/4 turn and try again. Adjusting shifting is a compromise - you adjust until you get the best result across the whole range. If your shifting is currently perfect except for this occasional issue with the 11t only, another possibility is that your RD high limit screw is in too far, and it’s not allowing the chain to sit squarely on the 11t sprocket, the result being that the chain is half heartedly trying to climb up onto the next largest sprocket. Back out the high limit screw 1/4 turn and see if that fixes the problem.
Quoted: 2482 Post(s)
Liked 2,953 Times
"picked a new bike" --- "new" as in purchased brand new from a bike shop or as in used but new to you?
If new from a dealer, bring the bike back to have the problem fixed.
If used but new to you, the most likely source of the problem is a worn cassette sprocket or chain or both. (Nine times out of ten, threads that describe a chain skipping on the smallest one or two or three sprockets go on for a number of pages of guesses and end with the OP replacing the cassette or chain or---usually---both and thus fixing the problem.)
Next most likely: misaligned dropout derailleur mounting tab. Any bike store can check the alignment of the dropout. Simple check, takes just a couple of minutes to correct the problem. If the mechanic finds that the alignment is OK and the chain and sprocket(s) do not show excessive wear, other checks can be done to diagnose the problem.
Likes For Trakhak:
In any case, it's way easier to check the screw before doing anything else and not confuse the OP. If that fails, then we can start looking for more complex issues.
Quoted: 2026 Post(s)
Liked 1,096 Times
Make the adjustments a little bit at a time, say 1/4 turn, and see how the shifting responds. Keep track of where you started so you can go back if needed. Do not twirl it a lot as small changes have a big effect.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
hey guys so i have adjusted the high limit and it still was happening, i took the bike back to the place and they said they had adjusted the limits some more, its still happening.....they are telling me to change a basically brand new dura ace chain.....what are your thoughts on this??
Really Old Senior Member
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Quoted: 6193 Post(s)
Liked 4,808 Times
While the limit screw might be something to check in this instance, I would say the limit screw is not the likely cause. I'd have turned the barrel screw on the rear DR in a turn or so if it had that range of adjustment left. Or moved the cable in the hold fast a millimeter or two.
There are other reasons you might not get into the 11 cog. How new is this bike? And "the place" is a shop that's business is selling bikes and not a small part of a store that deals in many other things?
Bikes: lots
Liked 2,932 Times
Ok...even though I said it most likely wasn't the hanger, stand behind the bike and have a look at it. Obviously it should be vertical and not angled in towards the spokes. After that put it in a work stand and undo the cable. Pedal it. If it shifts down to the 11 it was a cable tension or cable/housing problem. If it doesn't go down it's probably a limit screw issue. Pull on the cable and make sure the shifter is in the high gear position. Attach the cable and all should be good.
Which D/A is it? 9000? 9100? Rear derailleurs are silly easy to adjust and most problems (if looked at in a logical fashion) are easy to figure out. Don't always try to adjust right away...have a look and try to figure out what's not happening and why. Never be shy about going back to step 1 and redoing everything.
Likes For cxwrench:
Quoted: 1088 Post(s)
Liked 1,024 Times
Gonna be a stupid one but pull the wheel and check the lock ring. There are 12sp lock rings and if some dope put one on there it will sit just at the bottom of each valley but in the process will keep the chain from properly seating and will feel like its trying to shift but really its skipping. Shifting will feel perfect in the stand, only with decent leg pressure will it shop up.
If it isn't that then the shop needs to deal with it.
9100, it goes into the 11 just skips once and while under load (never leaves the 11 completely)
Bikes: lots
Liked 2,932 Times
Limit screw.
Chain problem.
Lockring problem (highly unlikely on a new bike)
The only other thing I can think of is that the 11 cog isn't positioned on the splines correctly but that would be crazy obvious.
