Park Dishing Tool - WAG-3
A Park dishing tool, model WAG-3. I don't need as I have a 2nd one, why do I have 2, not exactly sure here as I don't use them all that much. Either way this one has to go, nothing wrong with it.
I ship within 3 days
Paypal, check (ship after clearing), local pick up
It can be disassembled for shipping
$30.00shipped Sold
$30.00
Quoted: 4746 Post(s)
Liked 3,861 Times
Good! I missed it. Nice! And much nicer than the cheap bent flatbar unit I've been using. But I made a plunger for mine that has a slotted "foot" that slides under the axle nut or quick release. Such a hassle saver I'd do the same form this Park but it is almost certain the unit I made would not work here so this sweet dishing tool in my shop would be Project #273.
Bikes: '71 Raleigh Inter, '98 Tommasini, '83 Trek 500, 83 Trek 720 '
Quoted: 118 Post(s)
Liked 198 Times
Liked 3,861 Times
You need two 1x3/16 angles, 1 1'2" each. Aluminum makes this easy. (Home Depot.) Drill small holes along one edge of each so you can bolt them together to form a shallow U: 1" deep and 1 1/2" wide. Vertical legs will be slightly staggered heightwise. Doesn't matter. Drill a hole in the middle of one of the U's sides to fit over the tool's threaded rod. Drill the same hole in the other side (in line with the first) and big enough to fit your biggest hub axle. Now cut and file to the edge of the FB of the axle hole so that it becomes a slot. You should be able to easily slide this flange under the hub axle nut (fix gear) or QR nut and over the hub's locknut. (If you have a drill press, clamp the U on its side. First drill the axle hole with the larger drill bit on the upper flange. Swap bits to the threaded rod size and drill the other flange through the first hole. Nicely keeps both holes in line.)
Assembly - thread a nut onto the existing threaded rod leaving about 1/2" of rod sticking past the nut. Insert the rod into the hole in the U. Thread on a second nut and tighten against the first so the U is locked rigidly in place. Done.
Remember to send me royalties. We have documentation here where you got the idea from.
Likes For 79pmooney:
