Bike Computer /w No Minimum Circumference
Hey all, I'm looking for a wired bike computer (non-GPS, new or older) that doesn't have a predefined minimum circumference for the wheel size. It's for an off-topic project. Thanks for any help you might provide.
The two low priced units i installed both provided option for entering the tire circumfrance manually. If they dont go low enough, you could use a preset size that is easily divisable to get the correct speed. So for example if it reads 30 mph, you might divide by 2 or 3 to get the correct speed.
The app I developed will accept a Bluetooth speed sensor and you can enter any wheel circumference you want.
https://cykelstrom.com
Kind regards,
Chuck
Kind regards,
Chuck
