Alloy
Old 11-27-23, 02:23 PM
TC1
Quoted: 275 Post(s)
Liked 115 Times in 74 Posts
Originally Posted by dmarkun
Why is it common to refer to high end aluminum in the bicycle world as alloy, but high end steel is hardly ever called alloy. Like this question from quora: "Which is better chromoly or alloy?"
For what it's worth, this isn't a "bicycle world" issue, it's much larger than that. Aluminum wheels on motor vehicles are routinely called "Alloys", for example.
Basically, in inaccurate and vernacular American English, "alloy" is a synonym for "aluminum".
TC1 is offline
Likes For TC1:
Old 11-27-23, 02:26 PM
zandoval
zandoval's Avatar
Quoted: 882 Post(s)
Liked 1,507 Times in 973 Posts
I don't know the names of Aluminum and Titanium Alloys used in bicycle frames. I do know a few in older steel frames and enjoy pleasant conversations with others that do. All in all Steel Remains Real.
There are many but these few come to mind.
853
531
Dedecciai
Columbus
CroMo
zandoval is offline
Old 11-27-23, 03:48 PM
madpogue
Quoted: 2339 Post(s)
Liked 1,690 Times in 1,156 Posts
Why do cyclists ride bikes, but bikers ride motorcycles?
Why is the one clean-shaven guy in ZZ Top named Frank Beard?
madpogue is offline
Likes For madpogue:
Old 11-27-23, 04:12 PM
mrv
buy my bikes
mrv's Avatar
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 518 Post(s)
Liked 414 Times in 243 Posts
Originally Posted by blacknbluebikes
"none" is plural.
.... "none" are plural ......
mrv is offline
Likes For mrv:
Old 11-27-23, 04:19 PM
Kontact
Kontact's Avatar
Quoted: 4134 Post(s)
Liked 1,322 Times in 862 Posts
Originally Posted by Portlandjim
Instead of assuming everyone will know that when you say "alloy" you mean "aluminum alloy", it's helful to always describe this material using both words. All steel is an alloy. Although when it includes more than just carbon "steel alloy", implies higher properties than carbon steel.
Basic steel isn't an alloy since it only has one metallic element. Iron and carbon. "Alloy steel" is different from "steel".
By tradition, small amounts of metal additives are also not called "alloy steel", while the term is reserved for higher concentrations of other metals
I would not be surprised if pure aluminum had a bad rep at one point, and emphasizing the fact that it is an alloy was key to getting cyclists to accept rims and components made of it. 6061 was originally known as "Alloy 61S" in 1935.
Kontact is offline
Old 11-27-23, 04:51 PM
TC1
Quoted: 275 Post(s)
FYI, not per Merriam-Webster.
Originally Posted by https://www.merriam-webster.com/dictionary/alloy
1 : the degree of mixture with base metals : fineness
2 : a substance composed of two or more metals or of a metal and a nonmetal intimately united usually by being fused together and dissolving in each other when molten
also : the state of union of the components
3a : an admixture that lessens value
b : an impairing alien element
4 : a compound, mixture, or union of different things
an ethnic alloy of many peoples
5 archaic : a metal mixed with a more valuable metal to give durability or some other desired quality
(emphasis mine)
Nor Cambridge. Or Brittanica. Or any other reference that I can find.
TC1 is offline
Likes For TC1:
Old 11-27-23, 05:59 PM
Trakhak
Trakhak's Avatar
Quoted: 2329 Post(s)
Liked 2,752 Times in 1,571 Posts
Enclosure of "none" in quotation marks presents it as an example that is thus grammatically singular. Same as this example: "boats" is usually the wrong term for describing ocean-going vessels.
Trakhak is offline
Likes For Trakhak:
Old 11-27-23, 06:14 PM
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 4644 Post(s)
Liked 5,634 Times in 2,238 Posts
Some people get torqued up when definitions and grammar ain't used correctly, even when it's understood what they're talking about.
The classic example is the term brass brazing. Is it bronze? Is it brass? I use Gasflux C-04 Nickel bronze when I'm not using Harris 56 or 50N silver alloy. I'm fine saying it's either brass or silver, I'm pretty sure no one gets confused.
Now, let's argue about clipless pedals. Don't you clip into them?
gugie is offline
Likes For gugie:
Old 11-27-23, 06:21 PM
Eric F
Habitual User
Eric F's Avatar
Quoted: 4681 Post(s)
Liked 7,559 Times in 3,579 Posts
"Strapless" or "clip-in" would have been better. "Clipless" is dumb. I know where it comes from, but it's still dumb.
Eric F is online now
Old 11-27-23, 06:57 PM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6115 Post(s)
Liked 4,034 Times in 2,291 Posts
The real question is why don’t we call them solutions? That’s what they are…homogeneous solid mixtures which is the definition of a solution.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 11-27-23, 07:02 PM
Kontact
Kontact's Avatar
Who's the jerk that first called snapping into clipless pedals "clipping in"?
Kontact is offline
Likes For Kontact:
Old 11-27-23, 07:03 PM
Kontact
Kontact's Avatar
(emphasis mine)
Sure. So water with iron dissolved in it is an alloy.
Kontact is offline
Old 11-27-23, 07:06 PM
cyccommute
cyccommute's Avatar
"none" is plural.
Or singular. “None” is photon or electron of language. It can be singular…”there is none available”…or plural…”none of the tests were positive”. It’s what you need it to be when you need it to be that thing. A photon is a particle when it needs to be and a wave when it doesn’t. Depends on the context.
Stuart Black
Old 11-27-23, 07:34 PM
P!N20
P!N20's Avatar
Quoted: 1063 Post(s)
Liked 1,838 Times in 902 Posts
Where I'm from it's aluminium, SO YOU'RE ALL WRONG!
P!N20 is offline
Likes For P!N20:
Old 11-27-23, 07:41 PM
smd4
Quoted: 3250 Post(s)
Liked 2,674 Times in 1,621 Posts
Submarines and sailboats? I know… “usually.”
smd4 is offline
Old 11-27-23, 07:42 PM
Chuck M
Happy With My Bikes
Chuck M's Avatar
Quoted: 842 Post(s)
Liked 2,212 Times in 1,071 Posts
Originally Posted by 3alarmer
...if we called these components "aluminum", there would be huge controversy over whether to use the American version, or the UK's "aluminium". There's already the controversy over "tires" versus "tyres". Why can't everyone just get along ?
I'm pretty black and white on a lot of things with no gray (grey) areas. But if someone wanted to gift me financially, I would accept a cheque as readily as a check.
Chuck M is offline
Old 11-27-23, 07:46 PM
TC1
Quoted: 275 Post(s)
Sure, if you can get water not to boil off when mixed with molten iron, or if you can fuse water and iron together, then in either case, you've got an alloy. Good luck with that.
That said, you are arguing the wrong person. Take your complaint up with all of the people who publish those dictionaries, which, with a few others, are cumulatively the authority on the English language -- not with me.
TC1 is offline
Old 11-27-23, 09:35 PM
Alan K
Quoted: 470 Post(s)
Liked 329 Times in 257 Posts
I can see this devolving into a brass vs bronze brazing argument.
I need to remember this wisdom the next time we discuss (or not discuss) my bicycles (with my wife). 😉
Alan K is offline
Old 11-27-23, 11:53 PM
cyccommute
cyccommute's Avatar
Iron wouldn’t form an alloy with water because iron isn’t water soluble and water isn’t an element. Alloys are solid solutions of elements and, usually, only metals. Carbon is an nonmetalic element in iron but, for the most part, alloys are metal mixtures. Alloys can only form if the elements are soluble in each other and there are a lot of metals that won’t alloy together. Lead and zinc, for example, won’t alloy. Iron won’t alloy with copper, tin, bismuth, or aluminum. Copper won’t alloy with tungsten. Slagesium that is currently being sold on a whole lot of Chinese bicycles from HellMart is likely iron that hasn’t been separated well from the other metals in the waste stream. It likely contains copper, tin, and aluminum which are fairly common in mixed metal waste streams.
Stuart Black
Old 11-28-23, 12:27 AM
Insidious C.
Quoted: 454 Post(s)
Liked 320 Times in 201 Posts
somebody wake me up when we get to hypereutectoid microconstituents
I.C.
Insidious C. is offline
Old 11-28-23, 01:01 AM
Eric F
Habitual User
Eric F's Avatar
Valid point.
Old 11-28-23, 10:03 AM
madpogue
My clipless pedals and shoes have cleats, and are, therefore, clipless.
madpogue is offline
Old 11-28-23, 10:19 AM
cyccommute
cyccommute's Avatar
Valid point.
It goes back further. Who was the person who called the metal bands on pedals “clips”? They are foot cages. Synonyms for “clip” are things like fastener, clasp, catch, pin, buckle, lock, etc. A “cage” has synonyms like enclosure, pen, and confine which is what a “toe clip” does even without the straps.
None of the words for clip actually fit the description of the “toe clip”. They fit the description for the mechanism for clipless pedals perfectly.
Stuart Black
Old 11-28-23, 10:35 AM
Eric F
Habitual User
Eric F's Avatar
When talking about being connected to clipless pedals, people generally use the term "clipped in". How can you be clipped in to something with no clips?
As pointed out by cyccommute, the term "clips" is bad, from the start. The downstream effect of that poor bit of terminology continues to haunt us.
Old 11-28-23, 12:22 PM
smd4
Now we need to discuss alloy clips.
Supposedly made by Shimano for the 7400 pedals, but I’ve never seen them…
smd4 is offline
