when did recessing brake bolts become a thing? and more...
Old 11-28-23, 12:08 PM
Robvolz
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 999 Post(s)
Liked 1,619 Times in 602 Posts
It's helpful to know certain things when trying to date a bike.
Like:
what year did bolt on front derailleurs begin?
when did top tube cable guides begin?
When did braze-on shift bosses begin?
When did cables go from on-top the BB to below?
and
when did recessed bolts for brakes begin??
Thanks
Robert
"Leave the gun. Take the Colnagos."
Robvolz is offline
Likes For Robvolz:
Old 11-28-23, 12:15 PM
squirtdad
squirtdad's Avatar
Quoted: 2283 Post(s)
Liked 2,683 Times in 1,471 Posts
From what I have seen it will all be a range of years varying by region, manufacturer, and whether builder was in good mood or not that day
squirtdad is online now
Likes For squirtdad:
Old 11-28-23, 12:50 PM
SurferRosa
señor miembro
SurferRosa's Avatar
Bikes: '70s - '80s Campagnolo
Quoted: 3840 Post(s)
Liked 6,416 Times in 3,176 Posts
https://www.bikeforums.net/classic-v...t-w-links.html
SurferRosa is offline
Old 11-28-23, 01:55 PM
Robvolz
Quoted: 999 Post(s)
none of those catalogs actually list recessed brake bolt
Which is really my main question
Robvolz is offline
Old 11-28-23, 02:08 PM
jetboy
jetboy's Avatar
Bikes: centurion cinelli equipe, look hinault 753, Zunow z-1, 83 stumpy sport
Quoted: 814 Post(s)
Liked 329 Times in 185 Posts
1983 is when I see recessed brake bolts appearing. its around there anyway. i suspect it spans some years.
probably the "higher end" models got them first as they were getting the newest brake tech.
jetboy is offline
Likes For jetboy:
Old 11-28-23, 02:43 PM
bikingshearer
Crawlin' up, flyin' down
bikingshearer's Avatar
Quoted: 977 Post(s)
Liked 2,365 Times in 992 Posts
My 1978 Eisentraut has neither recessed brake bolts nor brazed-on rear brake cable guides. My 1982ish Ron Cooper has both. I'm certain about the date of the Eisentraut (his serial numbers are date-certain), less so the Cooper, but I'm pretty sure I'm not off by more than a year one year or the other.
Hardly a definitive answer, but a couple data points for you.
One more data point: I just went back through an old "Show you Ron Cooper" thread and found a link to Flickr album showing off a 1982 Cooper (definite on the date) that also had cable guides and recessed brake bolts. So there you go.
bikingshearer is offline
Old 11-28-23, 02:49 PM
madpogue
Quoted: 2341 Post(s)
Liked 1,692 Times in 1,157 Posts
Um, isn't it the nut that's recessed/exposed?
Definitely a function of both time and quality level of bike. Earliest bike I have with recessed nuts (both) is an '82 Trek 730. My '82 412 has both exposed. My mid-'80s mid-level bikes have a mix, recessed front and exposed rear. By the late '80s, they seem to have moved to recessed front and rear. I'm sure there are exceptions.
madpogue is offline
Old 11-28-23, 03:07 PM
repechage
Quoted: 3434 Post(s)
Liked 2,776 Times in 1,959 Posts
It was a transition.
I have found a 1975 Carlsbad Masi with recessed attachments- serial number points to Mid Summer of that year, for the End of year show season, frame was originally just clear coated.
it would be years before Masi would make them production.
Even the two bikes Mario built for the couple who designed his USA graphics did not get that feature.
The Confente USA bikes came with recessed brake attachment from the get go, later 1976, Mario got the fasteners out of Italy.
Aside from a probable 1973 Ritchey I have examined that had the fork so set up, not the rear bridge, it would take a few years.
Masi took another five years to show up on series bikes and not till 1984 (give or take a year - think product on the shelf ) for Campagnolo to make it an attachment option.
prior to that, it was up to the mechanic to swap the pivot bolts and add threads to what would become the rear brake bolt.
we tore up a lot of tapping dies, I could extend the die life by taking a belt sander to the chrome prior to running the die.
for a while frame sets out of Italy in the early 80’s came with the recessed nuts to fit- they were not a standalone parts stock.
repechage is offline
Likes For repechage:
Old 11-28-23, 03:21 PM
13velos
13velos's Avatar
Bikes: 1969 Peugeot PX50, 1973 Raleigh Competition, 1982 Trek 720, 1970 Motoconfort, 2023 Soma Pescadero
Quoted: 9 Post(s)
Liked 5 Times in 5 Posts
Recessed mounting had definitely trickled down to mid-range bikes by the mid-1980s. Like just about everything else, there’s probably an example from 100 years ago.
13velos is offline
Old 11-28-23, 04:24 PM
Doug Fattic
framebuilder
Quoted: 610 Post(s)
Liked 1,902 Times in 647 Posts
I remember seeing a rear recessed brake attaching bolt on a brake bridge for the 1st time in August of 1976 on a Mario Confente frame. I had a cousin that owned Raincross Cyclery in Riverside, CA and he brought some pro rider's (I forget who he was) Confent to me to see if I could do the same thing on frames I made. I'm not where I can check on my build sheets to see when I started putting recessed brake bridges on my own frames. I believe I first did it in 1978. I didn't do any of the machining of the rear brake bridge myself, I bought them from framebuilder suppliers. Silva or a similar company made them in 2 parts, the bridge itself and a barrel shaped cross piece that held the brake bolt. These 2 pieces had to be brazed together. Cinelli offered rear brake bridges for recessed bolts that also came in 2 parts but the 2nd part was a kind of brass washer that pressed into the bridge. A brake's star washer went against this brass piece. These could be a problem because the brass piece could get lost.
Here is a picture of a frame I know I finished in early 1979 but probably started in late 1978. I can see I brazed the Cinelli recessed rear brake bridge on it. Recessing the fork is just a matter of machining it with my vertical mill. These pictures were taken about 2 years ago when this frame was gifted back to me so I could repaint and resell it to use the proceeds for our Ukraine Bicycle Project. This was just at the start of the Russian invasion so the money went to Ukraine for a worthy cause.
Recessed brake bolts would have coincided with Campy's introduction of its short reach brake. They changed from 47/57 to shorter 40/50? I don't remember precisely when this was and what was the new length. What I do remember is that I sometimes had to use the rear brake with its shorter bolt in front and then cut and thread the front brake to match the length of the recessed brake bridge in back.
Obviously when the parts to make these changes first became available and when custom frame builders and production companies started to use them could stretch over several years.
This frame I made with Henry James lugs and a Cinelli fork crown. I can see I recessed the fork crown to accept the front brake bolt.
I put it on my Ukrainian frame fixture to verify its dimensions.
This is after a fresh repaint. The recessed brake bridge is visible in this picture.
Doug Fattic is offline
Likes For Doug Fattic:
Old 11-28-23, 04:47 PM
Lamont Cobb
Lamont Cobb's Avatar
Quoted: 50 Post(s)
Liked 32 Times in 24 Posts
I like the non-rescessed look better myself.
Lamont Cobb is offline
Old 11-28-23, 05:30 PM
repechage
The piccolo brake calipers started in 1974 by what I saw, adjuster barrel was not to be seen again till years later on the G.S. Series calipers, it is the one with the cone top and perimeter knurling. Now you know the why of the little black bumper on the front caliper arm.
to buy them one had to buy a complete DeRosa.
stuff like this happened later too, I saw a Cinelli frame set in the window of a shop, the bike shipped with Ergo 9 speed- a well heeled customer bought the Cinelli just for the group.
the rich are not like you and me.
frame set was then on consignment.
Old 11-28-23, 05:36 PM
VRJAKE
Bikes: Bakers dozen is the limit!
Quoted: 84 Post(s)
Liked 393 Times in 128 Posts
Another data point, 1980 Merz, 753 tubing, with recessed brakes. Recall claims that Peter Johnson, master craft low volume builder in the SF Bay Peninsula, was one of the first to make frames with recessed brake bolts. I don't recall the year claimed, perhaps someone knows or has a reference.
VRJAKE is offline
Old 11-28-23, 05:41 PM
repechage
As Peter knew Tom Ritchey- who knows who was first. Creative guys.
prior to this a few Italian makers were brazing pivot bolts into frames and forks. Blacksmith centering required of the spring. A special customer or special team bike thing.
Old 11-28-23, 06:00 PM
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Quoted: 2581 Post(s)
Liked 1,658 Times in 916 Posts
I would have put it a little later- from my uninformed guesswork- I'd have figured it kind of tied together with the "aero" trend @1981 or so...
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Old 11-28-23, 06:05 PM
Portlandjim
Portlandjim's Avatar
Bikes: 1946 Holdsworth Cyclone, 1969 Cinelli SC, 1972 Raleigh Pro, 1973 Merz road bike, 1974 Alex Singer Sportif, 1974 Merz track bike, 1975 Teledyne Titan, 1976 Ritchey road bike, 1977 DiNucci built Merz track bike, 1977 (?) Exxon Graftek, many more!
Quoted: 135 Post(s)
Liked 1,384 Times in 167 Posts
A quick look at my Merz build sheets shows May 1977 as the first mention of recessed brake bolts. The comment is "Zues bolt for brakes". I remember that Zues had these recessed brake nuts first, in the USA anyway. Jim Merz
Portlandjim is offline
Old 11-28-23, 07:29 PM
P!N20
P!N20's Avatar
Quoted: 1065 Post(s)
Liked 1,838 Times in 902 Posts
Don't know, but, the 1979 Pinarello Catalog shows the Prestige model with a bolt on front derailleur. No tab, just bolted to the seat tube like you would bolt on a bottle cage.
There's a better picture somewhere, but here's one: https://velo67.ch/products/pinarello
Velobase lists the 1052 Super Record as the first Campy FD for braze-on tab in 1979...although the model was available through to 1987, so not sure when the braze-on was introduced: https://velobase.com/ViewComponent.a...m=113&AbsPos=6
Velobase lists the Shimano EA-200 Dura-Ace EX FD with a braze-on option: https://velobase.com/ViewComponent.a...=113&AbsPos=50 and the FD-7210 Dura-Ace EX as braze-on only: https://velobase.com/ViewComponent.a...=113&AbsPos=53 both introduced in 1978.
P!N20 is offline
Old 11-28-23, 07:51 PM
zukahn1
zukahn1's Avatar
Quoted: 763 Post(s)
Liked 1,689 Times in 607 Posts
79-80 on higher end stuff 84-85 on cheaper stuff.
zukahn1 is offline
Old 11-28-23, 07:59 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2700 Post(s)
Liked 3,303 Times in 2,007 Posts
Mid level observation. 1984 Raleigh Gran Prix and 1987 Trek 400 both nutted rear, recessed front. 91 Trek 400 both recessed.
dedhed is online now
Old 11-28-23, 08:02 PM
Portlandjim
Quoted: 135 Post(s)
Proof that these nuts were around before 1977
Did you even look at my post with my build sheet? Zues was selling the resessed brake nuts before 1977, when I built this bike.
Old 11-28-23, 08:33 PM
P!N20
P!N20's Avatar
Better pictures - looks like a variant of the Record 1052/NT:
From here: https://vintagevelore-cycling.com/pi...e-columbus-kl/
This 1979 Marco Marastoni is interesting:
P!N20 is offline
Old 11-28-23, 08:50 PM
sd5782
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 563 Post(s)
Liked 653 Times in 366 Posts
Interesting points on quality of frame mentioned by madpogue on his 82 trek 736 having recessed. My year later 700 also in full 531 is nutted Superbe brakes. Same year 760 also in full 531 however is in recessed in Superbe Pro. Perhaps it is also as Doug Fattic mentioned with the early Campy stuff, and also when the components were available. Chicken vs egg thing along with builder preference. On my nutted 83 700, perhaps the mid reach Superbe brakes were only nutted at that time.
sd5782 is offline
Old 11-28-23, 10:53 PM
seagrade
Making up the numbers
seagrade's Avatar
Quoted: 92 Post(s)
Liked 409 Times in 132 Posts
It’d be interesting to see examples of recessed front/nutted rear brakes at the catalogue. I suspect this mismatch more often arises from a replacement fork over the ensuing 40 years than original spec.
Not completely unrelated to this thread is that in the late 60s and/or early 70s Bianchi built several frames for Felice Gimondi, and no doubt others, with integrated brake centre bolts, so neither recessed nor exposed brake nuts visible on the off side of the crown or brake bridge.
Nothing quite says wall hanger like drillium toe straps
seagrade is offline
Old 11-28-23, 11:41 PM
repechage
Zeus importation and distribution was just so haphazard, little product marketing, Joe Kossack obtained a sponsorship for the QRBC, and I think had a hand in the distribution, the new club was aptly named as the initial riders were recruited from other SoCal clubs in 1975 for 1976 onward. Back then a club had to exist for a year before it could have a sponsor. A bit of creative bookkeeping and paying of fees, a
“paper” club got things done. Ever wonder how the East Coast clubs dominated the board of the sanctioning body? Back then voting weight for the Board was based on total club membership, pay the rider fees, get more votes.
Old 11-29-23, 01:48 AM
Andy_K
Andy_K's Avatar
Bikes: Yes
Quoted: 3222 Post(s)
Liked 3,817 Times in 1,427 Posts
This sounded so wrong that I had to go out to the garage to double check, but my 1973 Raleigh Professional has recessed brakes front and rear.
My Bikes
Andy_K is offline
Likes For Andy_K:
