Dub pre-load thread ring question
Old 11-29-23, 05:09 AM
masi61
masi61's Avatar
Quoted: 1149 Post(s)
Liked 434 Times in 309 Posts
I am using (trying to use I should say) a Cannondale mountain 30mm Hollowgram axle in a BSA30 thread fit bottom bracket. Doing this would allow me to use a 104/64 triple spider with the Hollowgram crank arms with a nice triple chainring set of 48/36/24. So far I feel like I will either smash the bearings, or have insufficient spacers and end up with play/slop in the axle. Has anyone used one of these “dub” pre-load adjusters for custom Cannondale Hollowgram 30mm applications? Thanks for any help.
masi61 is offline
Old 11-29-23, 08:33 AM
Iride01
Iride01's Avatar
Quoted: 5994 Post(s)
Liked 4,624 Times in 3,190 Posts
Is this what you are asking about?
Iride01 is offline
Likes For Iride01:
Old 11-29-23, 12:02 PM
masi61
masi61's Avatar
Originally Posted by Iride01
yes - this is on the right track!
masi61 is offline
Old 12-03-23, 01:12 PM
trucklet
good cheap fun
trucklet's Avatar
Bikes: Too many
Quoted: 12 Post(s)
Liked 47 Times in 17 Posts
The DUB spindle is 29mm so it wouldn't fit, unfortunately. You may have good luck going to your LBS and seeing if they have any leftover 30mm spacers sitting around, something like these.
Edit: This would work too, they're nice quality and can go on 30mm spindles.
trucklet is offline
Old 12-06-23, 05:14 AM
ls01
he said member
ls01's Avatar
Bikes: yes please
Quoted: 2681 Post(s)
Liked 1,885 Times in 1,159 Posts
Sram makes the plastic version in 30 mm and Dub. They cost about $7.00
ls01 is offline
