Wheels BB backed out...how to fix for good?
Quoted: 196 Post(s)
Liked 12 Times
Installed a wheels BB30 to 24mm outboard BB for a Specialized Tarmac last year. Put about 1200-1500 problem-free miles on it, and only noticed a problem when one day last week the chain began striking the front derailleur. Upon further inspection, the BB had backed out about 1/8-inch and was playing side to side. Because the NDS crank arm was locked into place on the shaft, the BB backing out had effectively compressed the NDS cup tightly up against the arm and they were now spinning in unison, so it was further unscrewing the BB with every pedal revolution.
Wheels customer support evidently does't answer nor return calls anymore, so seeking advice here on resolving the problem. Would blue Loctite on the BB cups be the most likely plan of attack? I set up the preload bolt at precisely the point where there is no side-to-side play, so the crank arm was not compressed up against the BB cup so tight that it unscrewed it...like I said, I rode it for almost a year before it ever started backing out.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Loctite? No. Take the bb out, clean and re-grease and put it back in making sure it's tight. Don't overthink this.
Likes For cxwrench:
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 75 Post(s)
Liked 195 Times
Take it all apart, clean out the shell thoroughly and check the threads in the shell. If its been spinning with the crank, they may be destroyed at the lip.
Its unusual for that to happen, so if everything is good, put it, or a new BB in with that fully seated. There is a torque spec for that but most people just give it a lite grunt and its good. Ive seen some not fully seated where people stopped turning them because it got a little hard due to the threads being dirty. Maybe that's what happened here.
