Battery v/s USB Rechargable - Old Guy
Quoted: 965 Post(s)
Liked 1,629 Times
Posting this here because I need and "Old Guy" opinion.
I need to order some lights for my latest build,m a P6 Frankenpeu. It appears that USB rechargeables are the latest thing. The days of the two C size battery flash light strapped to my left leg are thankfully over. Yet some how I am reluctant to give up my Cat Eye 2 AAA and go to USB rechargeable. Maybe its just that dead cell phone horror that I'm feeling. I like the low profile of the newer lights and the intensity appears to be fantastic. In my area I don't see many bikers and rarely do any of us ride at night so I have never seen them in use. So...
Can you tell how much of a charge they have left them?
Do they take long to recharge?
Can you leave them plugged into the charger?
Are they durable?
Do they look OK on an old bike?
Is there a Cheap Guy version?
I know there have been more than a few threads on this subject but the lights available and thier construction is changing almost day to day.
Any comments would be appreciated...
Are they durable?
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I only do dynamo which does not answer your question but I will say I never worry about batteries.
Likes For 52telecaster:
Quoted: 3015 Post(s)
Liked 3,802 Times
My lights have an indicator when low. My old-timey stuff that used batteries tended not to have an indicator.
Either way, I can't imagine ever replacing batteries instead of just using a plug. USB on a plug are a dime a dozen, so the cheap guy should love not buying a battery.
Mine are pushing ten-years-old. Rain, sun, rough roads, dropping them, they are just dandy.
Recharge via an outlet is maybe an hour. Charge through the computer is slower. I don't leave them plugged in more than overnight, can't comment beyond that.
As for looks, ymmv.
As for looks, ymmv.
Likes For iab:
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I run AA rechargeable on the front light and USB rechargeable on the tail lights. I like them both. I carry a spare AA in my pack and keep a couple fully charged at home that I rotate with. The USB is an entity 100 and has been going strong for more than a year now through all kinds of weather. It takes about an hour to charge and lasts about 5 hours on super bright blink. It has 7 functions total. The headlights only have 3 functions. Blink, dim and bright, but they are bright. My AA is 2800 mah and lasts about 2 hours on bright blinky during the day, not much less on bright solid at night (1.5hr). Hence, the spare bats. I have several older USB rechargeable lights also, but haven't used them in a while because they were never as bright for daytime use. I do have a USB on the rear of my helmet too, but it's more for night visibility. Good luck, hth
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
Some sort of rechargeable is the responsible way to go. I like the convenience of USB charging . You can always carry a small storage element with you for emergency recharge of your USB, although this is admittedly slower than simply swapping batteries.
Sunshine
Quoted: 10963 Post(s)
Liked 7,489 Times
All my lights are rechargeable. All last way longer than any 1 single ride I do, so there is 0 concern about running out of light.
And I don't feel like charging after each ride, so all my lights last way longer than 2 rides. Especially when you consider how few hours I typically ride at night where a front light is needed.
Rear daytime light is currently a trend and rechargeable is usually brighter/more powerful than battery. <--something to consider.
Likes For mstateglfr:
Quoted: 4559 Post(s)
Liked 2,802 Times
In tail lights, it's hard to beat Cygolite Hotshots and Hotrods for value and brightness. They're reasonably priced, lightweight, very bright (but adjustable as needed), hold a charge well enough they don't need to be recharged every day (unless I'm riding several hours a day), recharge reasonably quickly, and the batteries are good for many charging cycles.
I have some battery powered taillights but those are relegated to my hybrid and errand bikes.
In headlights there are many suitable choices. For awhile I mostly used Light & Motion but I've mostly switched to NiteRiders, and I've noticed most of my local friends have as well. For serious nighttime riding it's hard to beat the NiteRider Lumina Dual 1800. Dual LEDs side by side, plus a properly designed lens to throw a well shaped beam that lights up the road rather than indiscriminately lighting up the trees and blinding oncoming traffic. It's pricey at around $150 or so, but really good for an all-in-one unit. And Outbound Lighting offers similarly good headlights with separate headlight/battery modules.
Quoted: 100 Post(s)
Liked 57 Times
I'm somewhat old and very crotchety. I don't believe in index shifters or cassette hubs and currently I don't even have a smartphone. I use a wind-up watch and a fountain pen. I wouldn't use the newer tech if it weren't really noticeably better. In this case, it is.
First choice: cheap Sanyo dynohub + Busch & Müller lights. I've got four bikes running this setup. Seriously, it's worth the initial investment -- once you get a dynohub wheel, you'll never think about batteries again.
Second choice: USB (I like a Cygolite Metro 600, for the 10+ bikes that don't have dynohubs).
Third choice: rechargeable AAAs.
Likes For brianinc-ville:
Quoted: 3810 Post(s)
Liked 6,691 Times
I run dynohubs on all of my commuters, including the 1950 Raleigh Lenton Tourist. As Brian notes above, not having to worry if my lights/batteries are charged and taking advantage of modern optics are a win-win. That said, I do often stick rear rechargable LED lights so that I don't have to deal with running wires from the front hub to the rear. My commute is short, so they last a long time between charges.
Likes For nlerner:
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
I run a Bontrager Ion Pro and it has good light and lasts a long time. The color of the LED at the button reflects charge - green for mostly full, yellow for half, red for low. Charge time is actually pretty slow/long maybe due to the high power usage. Runs for a long time though, and low power is enough for many of my rides, medium is more than enough. This one and many other modern lights also help you limp home by going to a low power mode before running completely out of juice. I also use their small cube lights (forget the exact names) front and rear on my helmet.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
I have one light that when powered down, blinks multiple times to indicate remaining charge. When it gets down to one blink, I recharge it. Others, you find out when they die. Eventually you get an idea of how long you can go between charges.
Generally, a couple hours. It seems that the quicker they charge, the quicker they deplete.
I've heard mixed reports on that. Some say it's fine, some say it shortens overall life of the battery.
Yes, unless they get run over by a car or something.
I don't have a problem with how they look. No goofier than the Wonder light of yore strapped to your leg, anyway.
The cheapest ones I've found were free road finds. For that reason, I use a rubber band as a secondary retention device, so it's not just relying on the flimsy clip to hold it in place.
Are they durable?
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I have two dyno hub wheels, one 700C and one 27". Sadly neither is in use atm. I use a cygolite in the rear and some other usb light in front. Very, very bright. I have to be careful where I point it. I agree, rechargeable is the responsible way to go. But I don't want to sound preachy.
Edit: pushing 70
Edit: pushing 70
Likes For seedsbelize:
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,525 Times
Contrary opinion, or at least Some food for thought. I have and use a mini-USB rechargeable headlight., Actually, I have two, I ride one while the other is charging. I still have an old battery-powered blinkey taillight. I'll probably replace it soon.
But, were I to do another self-supported tour, I almost certainly would go with battery powered lights all around. Yes, there are work-arounds for portable charging of USB devices, and I probably would carry one for my smartphone (mainly so people have a shot of tracking me if I go missing) but having to to recharge the lights is an additional layer of complexity I would prefer not to have on a fully loaded, self-supported camping tour. For a "credit-card camping" tour, yeah, rechargeable is good.
Them's my thoughts, and they are worth exactly what you are paying for them.
Likes For bikingshearer:
Liked 3,802 Times
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
I've got a couple rechargeable Light & Motion lights- I like them very much.
Granted, my experience with AA powered lights has been with lower powered (and less expensive) models- but these lights are SO much better.
I have a dynamo/light setup coming- hopefully within the next week or so. I'm really excited about that!
720 Lighting by Dave The Golden Boy, on Flickr
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
Why I replaced a bunch of outlets in the house with ones with USB ports.
Quoted: 874 Post(s)
Liked 2,287 Times
I use a set of Lezne lights and they last about two , two hour rides. I like the recharge feature and using a USB charger is handy. My helmet has flashing lights or steady on features as well as turn signals and is also rechargeable. The charge probably lasts longer than two rides on my lights and helmet but that’s my routine , I charge every other ride and I don’t run out of charge. I might add that I don’t ride at night.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Kasai USB rechargeables here. Good for about 6 hours, no batteries to toss, and a single cheap charging station does my phone and both blinkies for the next day.
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
Sunshine
Liked 7,489 Times
GB- doesn't that light location make the drops useless?
I ride almost exclusively at night. I have three wheels built up with dyno hubs. But on those occassions when I rode a bike that didn’t, I used an ultrafire wf-502b flashlight that uses an 18650 rechargeable battery. its bright, cheap, lasted well over any 20-35 miler i did and a spare battery is easy to carry. It mounts easy and is easy to remove. Unless its a dyno light I will never purchase a specific bike light again. Best of all its only 25-35 to get one with a good 3500mAh battery and the mount… much cheaper than most battery lights sold for bikes.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
I use rechargeable but carry an AA battery powered unit as a backup. Rationale is, even if AA batteries are down, I can easily pick up more at any gas station.
Liked 1,699 Times
They throw off a lot of light. At the time it was comically larger than any USB light - now it’s pretty much in line with the larger lights available.
Liked 1,699 Times
Yes- it’s attached with the easily removable strap- it could be anywhere on the bars- I’m just on the ramps, corners, hoods and tops 99% of the time. Not so much of a drops rider.
Bikes: Fuji S-12s, Trek Navigator 200, Dahon Vitesse D7, Raleigh Sprite Touring ('70's)
Electrical Engineer weighing in here. I've been heavily into rechargeables for going on 20 years now. I still run a ton of higher capacity conventional NiMH AA & AAA batteries with a smart charger (LaCrosse) that optimizes each cell. With $10 flashlights that output up to 600 lm for general home use and a handlebar bracket or two for the bike, I'm all set. Li battery tech takes that further albeit with higher initial investment. I'm dabbling there too.
Throwaway batteries are so last century.....
Likes For Fibber:
