Miyata 610 - Need some advice
Hello from sunny Singapore.
I am a beginner looking to step into the world of vintage bike and I will appreciate some advice.
There's a listing of this Miyata 610 at USD467. To note, it is quite difficult to source for vintage bikes in Singapore, unlike the US.
Hence, I am wondering if it's a good buy and what might be the necessary change of parts?
The seller only provided info that it is an L size frame
Thanks in advance!
Thanks in advance!
Quoted: 586 Post(s)
Liked 612 Times
Based on this catalog, it appears to be a 1985. https://www.ragandbone.ca/PDFs/Miyat...logue%2085.pdf
Miyata made three "Grand Touring" bicycles and this one was in the middle. The 1000 was the top model and is much coveted by those looking for a vintage tourer. But the 610 is a very nice bike in its own right.
The price seems high, but as you pointed out, there isn't as much to choose from. Supply and demand.
What I can tell you is Miyata was a good manufacturer and my Miyata 312, a 1989 model is one of my favorite bikes. I pass by lots of more expensive bikes and often choose to ride it instead.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
May I know what are the estimated price for this bike in the US?
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
In my area, that would be a $250 bike. Every area is different! I recently donated one. Later models were quite a bit nicer.
Given your description of the Singapore market, I could imagine it being a much higher price. Here, vintage bikes are plentiful and customers are not.
Likes For wrk101:
Likes For TugaDude:
Shall think again before biting the bullet for this!
Bikes: 50s, 60s, 70s Nottingham/Worksop bikes, becanes, Gitane, Bertin, Lion of Sochaux
Quoted: 145 Post(s)
Liked 120 Times
So far no discussion on what size bike would be appropriate for you. Note: I would not buy a bike long distance without knowing exactly it’s size and what I’m looking for.
how tall are you? What is the inside length of your pants (how long are your legs)?
I am 6'1 (187cm) and my legs are 2'6 (80cm) long
Seller says its an L size, so i presume i should be fine with it?
Quoted: 145 Post(s)
Liked 120 Times
https://steel-vintage.com/bicycle-size-calculator
Size large is not enough information to make an informed decision. Check this out in order to help you figure out what size you need. You will want to ask seller to measure stand over height. I usually also ask for seat tube ctt and top tube length ctc (ctt is center to top; ctc is center to center)
Quoted: 4789 Post(s)
Liked 3,915 Times
I had a ~61cm 610 perhaps a year or two earlier than this one Second Edit: I'm getting my bikes confused. I think my 610 was '85 or a touch later. Got it used in '90. Rode it as a commuter through all weather and a bunch of crashes for 20 years and 27,000 miles. Now I started with a bare frame so I cannot speak for the parts. That frame is excellent. Probably butted main tubes and hi-ten stays and fork. Very well made and strong. Bike rode well. It was slightly odd in geometry. Touring, so a long head tube but medium top tube. BB was high. I still don't know why. I rode it fix gear and loved that feature. Other 610s I've seen don't seem to have that oddity.
I'd still be riding it except I destroyed it in a crash that would doom any bike. (It would be at 47,000 miles now.)
Edit: Size - I was 6'-1/2", long legs when I got it. (Legs are still long but the rest is shrinking.) So, longer legs than you, shorter torso and probably lot longer arms. Standover on mine which was a size larger than that one was a little close. I'm guessing that bike would fit you just fine with no more than perhaps a stem change. (Any old 22.2 quill stem will fit so you have thousands to choose from. Nothing quirky on those frames.)
Third edit: Those cantilever brakes are as good as you'll find. I took one ride when I got my 610 and promptly took them off and put them on my custom where they still are. I never saw those brake on other bikes but they are keepers!
Likes For 79pmooney:
Seller said that it is a 58/59 frame!
Will that be too big for me?
As I thought I will fit around a 54-57 frame
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 684 Post(s)
Liked 370 Times
Firstly a link to the catalog https://www.ragandbone.ca/PDFs/Miyat...logue%2085.pdf
We know it's an '85 based on that seat tube sticker, they changed every year. In '85 Miyata measured their touring bikes in inches which makes them pretty easy to size. Looking at the head tube length I know it's larger than a 21" frame and smaller than than a 25" frame so it's a 23" frame.
23" = 58.4cm, Miyata measures seat tubes from center of the BB to top of the top tube, so center to center its a little bigger than a 57cm.
At 6'1" the "will it fit" question depends on your cycling inseam length, your fitness and flexability, and your fit preference. If you carry your hight in your torso it could be a good fit, if more of your height is in your legs, it could be too small.
If it fits, I think its worth picking up. I had an '84 610 and it has clearence for 40mm tires (without fenders) and it's nice and stout. It flexes less under load than the Trek tourers, at least less than my '83 Trek 720. They have 45cm chainstays, and the canti brakes can be adjusted to reach 700c wheels (again based on my 23" '84 610).
I find that for whatever reason Miyata's tend to ride a little smaller than their stated size, but I have measurements a little outside of average. I am of average height but more of my height is in my legs than in my torso, and I tend to larger frames because of it.
Likes For Chr0m0ly:
Liked 3,915 Times
Firstly a like to the catalog https://www.ragandbone.ca/PDFs/Miyat...logue%2085.pdf
I've bitten the bullet and gotten it! Thanks to all of you who has provided me with your kind advice.
Now it's time for me to think of changing some parts.
Am thinking to change the brake pads and tyres since it look/feels quite old..
Let me know your thoughts.
Likes For SeeSeeRookRook:
