Is there a way to seal a leak on the base of a tub's valve stem.....
Quoted: 1635 Post(s)
Liked 823 Times
On a tubular tire, where it goes into the base tape?
Would an injectable sealant work to seal the leak?
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
In my experience, no. Also, often what appears to be a leak at the valve stem is actually coming from some other place. Air leaking inside the casing comes out at the easiest place - the stem hole. Once I tried sealant and it came out around the stem, and began to fill the rim. Not pretty.
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
My C&V Bikes:
Half way there
Quoted: 985 Post(s)
Liked 879 Times
Yep, air from a tubular tube leak will always migrate to the valve stem, confounding locating the puncture. Get your magnifying glass out and search the tread for possible punctures if you want to have a chance for real repair. That said, I have used a sealant somewhat successfully on a latex tube with a very slow leak of undetermined location. Effetto Mariposa Caffelatex was the product. Good luck.
Quoted: 3464 Post(s)
Liked 2,827 Times
Old old tubulars had a valve stem bolted to the tube. ( completely threaded valve stem required)
more modern tires will have a molded base bonded or vulcanized to the tube.
a leak there is probably a tear
those though usually deflate fast.
one check with the tire off the rim, inflate till it turns inverted almost and manipulate the valve observing for faster deflation.
so, what was also mentioned as a leak not revealing at the puncture is true.
I have a few tires where the leak just does not show anywhere. But overnight flat.
a good candidate for sealant.
thinking of the Newer Silca product.
Quoted: 191 Post(s)
Liked 564 Times
If the leak is actually from the valve stem area, count me as another vote for the tubular mortuary. If the air is coming from elsewhere, you might be able to patch it in the normal way, should yo want to go to that trouble. My bet would be on a valve stem leak as that is not a rare thing, especially with threaded valve stems as they take a bit of a beating from the pump head being mounted and removed during inflation…
Quoted: 1946 Post(s)
Liked 2,004 Times
Pinch the tubular in various places to restrict the air as you pump it up. This can help locate the puncture. You can fold the tire or use pliers, vise grips, etc. I doubt it is the valve.
Liked 823 Times
I submerged the tire while pumping it up and the bubbles are coming from the seam where the base of the valve stem goes ibto the base tape. I examined the joint closely and could not see any signs of a pin hole so the leak must be very miniscule and very hard to find and fix..... and as also mentioned could actually be happening deeper in the tire structure, away from the valve stem area .
I guess the tire is just toast at this point. The tire has a more modern construction that does not have stitching exposed like older tubs do. Everything seems to just have been permanently bonded together with glue.....
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
