Help with a Campagnolo Racing Triple rear derailleur
Quoted: 1856 Post(s)
Liked 664 Times
I have a Campy Racing Triple rear derailleur with what looks to be a hybrid cage. I'm looking for a source
of the derailleur cage plate. I think the one I have is bent.
If you put it on a frame with wheel and cassette or freewheel and adjust the stop screw to align the upper
pulley with the small sprocket, and then look for the alignment of those two wheels with the lower one,
the lower pulley is offset by about 5 mm. I think the inner cage plate is not a Campy original, and
represents a bodge by the original owner of the part. I've actually ridden on it pretty extensively,
but I'd like to fix it now that I've seen it.
I trued the rear wheel, verified the dish, aligned the dropouts, performed a string test, and hence have
the back of the bike in as good an alignment as I can think of, short of trying a Park frame alignment
gauge to make sure the two rear triangles are symmetrically offset.
If I could get a complete Racing Triple or find someone who can perhaps make a replacement (I can
provide specs, pics, or the offending device) inner cage plate, I could get this old shifter back into
doing its business.
doing its business.
Liked 664 Times
Short version: Does anyone have a Campagnolo Racing Triple or Racing T rear derailleur, to sell, used or for parts?
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times
I have an Icarus MTB RD and it has a bent cage too. When I first noticed it, I was super confused because there’s no indication mine ever hit a rock or anything, it’s almost brand new. Then I looked the Campy MTB derailleurs on Disraeli Gears and some of them look the same way.
https://www.disraeligears.co.uk/site...erailleur.html
does that look like what’s going on with your cage?
Quoted: 472 Post(s)
Liked 1,028 Times
I would do two things first: a) I did not see you mention alignment of the RD hanger. That is a very common problem. I’ve corrected dozens of “tweeked” hangers and solved dozens of shifting issues. And b) disassemble the RD cage and check the two side pieces on a glass plate. Glass plates (I use a scrap bit of 1/4” plate glass) are pretty good reference surfaces. Do the side plates lie flat on glass or rock a bit cuz they’re bent?
Quoted: 1607 Post(s)
Liked 2,216 Times
@Road Fan - You don't need a special tool to check the rear triangle, although I do have one. @Doug Fatticc recommends using a long straight edge like a 4' level to lay across the head tube and seat tube. Measure from the dropout to the straight edge and compare to the measurement from the other side after flipping the frame.
I did that on my Bianchi and found the rear triangle was skewed to the DS. After placing a rear hub in the dropouts and supporting the main triangle, I stepped on the the upper DO a couple of times and it move into place. Now it is symmetrical.
It might make sense that checking the DO alignment is enough wrt the hanger, it should be checked anyway. The misalignment could be between the plane of the axle portion of the DO and the hanger portion. @Prowlers recommendations is good. I use a glass coffee table to check "flatness" of rims, very useful as is a large stone countertop.
Likes For SJX426:
Liked 664 Times
Liked 664 Times
I'm pretty sure there is a bend in the derailleur cage.
I don't think the Racing T was intended as a MTB derailleur. I'm pretty sure Racing T and Racing Triple sets were intended for wide range over terrain requiring more and wider gears, and to handle a wider range than a Record Triple. I think the Centaur CTs (50/34 doubles) were not on the scene yet. I'm not sure about indexing drivetrains. At least I've always thought of it as a Road group. I don't know the purpose of a cage which bends outward, for an MTB and certainly not for road use. I don't see this contouring on several Shimanos I have and on an 11sp Athena triple on my wife's road bike.
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
I'm starting to build up the frame I built in Doug's class (with much work by Doug -- credit where credit is due). I'm using a Racing Triple rear derailleur. I took a peek at it yesterday. The cage is arrow straight. It looks nothing like the images posted here or on Disraeli Gears.
Liked 2,216 Times
RD00-RA309, from 2000,. Cropped pic but it states 9 speed. Cage is straight, no bends.
P1050217 on Flickr
P1050217 on Flickr
