Campagnolo Delta brakes, a classic component from Campy
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 666 Post(s)
Liked 964 Times
Good Morning
I have on my Raleigh Campy Delta drakes a lot not only for their looks but for their performance too (in my case the brakes works very well even, though, I prefer my Shimano Dura Ace 7700 and 7800 on my other bikes), an interesting article is dedicated to them:
Have a nice read
Very best regards and stay safe
Georges
Have a nice read
Georges
Likes For georges1:
Likes For El Chaba:
Quoted: 567 Post(s)
Liked 563 Times
I recall enjoying the sale price I got for my early 3 link Deltas. As a mechanical design engineer and later years in maintenance I was horrified by dozens of discrete parts
Quoted: 2323 Post(s)
Liked 4,936 Times
I saw my first set of a De Rosa when I was at an old local pro's house picking up my first Giordana bike from him. They were beautiful.
I have a set of the 3 pivots on my one Lemond and am certainly in the camp of "they work just fine" when set up properly.
I don't normally seek them out due to the high price they demand but I sure wouldn't mind another set or two to put on a couple of the bikes.
Steel is real...and comfy.
Likes For jamesdak:
Quoted: 3464 Post(s)
Liked 2,827 Times
the Delta brake is interesting, nice to admire on someone else's bike. I was working at a shop when they finally arrived.
the one feature that provides a summation, 3.5mm Allen wrench required.
kind of like the Lamborghini Countach, no suspension bushings, all rose joints.
An Italian flight of fancy.
Likes For repechage:
Steel is real
Quoted: 666 Post(s)
Liked 964 Times
I have them on my Raleigh too
Likes For georges1:
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 364 Post(s)
Liked 457 Times
Delta brakes look nice, until you remove that cosmetic face plate.
Then it resembles the Predator when he takes off his helmet, before trying to destroy Arnold.
Likes For roadcrankr:
Quoted: 3497 Post(s)
Liked 2,911 Times
Always thought Deltas were ugly and over complicated. Was there ever a less aerodynamic bike component?
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Mod Note To All. Please stay on topic. Several off topic posts have been deleted.
Likes For Homebrew01:
Quoted: 1635 Post(s)
Liked 824 Times
Not to mention, it was one of the heaviest brakesets you can put on a bike in the 80's....Just mostly form with the slightest nod to function, even after so many times they tried to get it right.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Liked 4,936 Times
I wish the whole bike world would hate on the Delta's more so I could find another set or two for a reasonable price.
Likes For jamesdak:
seńor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
They're sort of interesting ... in a hideous and alien sort of way.
Likes For SurferRosa:
Likes For El Chaba:
Likes For chain_whipped:
Steel is real
Quoted: 666 Post(s)
Liked 964 Times
Liked 2,911 Times
Likes For smd4:
Steel is real
Quoted: 666 Post(s)
Liked 964 Times
Steel is real
Quoted: 666 Post(s)
Liked 964 Times
Liked 2,911 Times
Quoted: 175 Post(s)
Liked 435 Times
I doubt you're qualified to conclude 'infunction'.
The aesthetics will always be subjective.
Owned the third gen Campy Delta. I liked the looks, and they did work, but sub-par for performance. Tricky to modulate and then, wham.... clamped down. Wet and oily roads were sketchy under braking. Lastly, finicky initial set-up and unnecessary weight. Cover plate had some fastening issue on one caliper... I forget exactly the cause.
Also had the Weinmann 531, there were a few versions and I don't know exact model type or series. Swiss made but not to ones expectation of finely finished. Some had that unattractive rubber cover and in the later series I could see why it was needed. I had the version sans that rubber having the plastic cover triangle plate in black. If dirt and dust gets under the cover, these brakes would be a pain to always removing the main triangle part for cleaning (unlike Campy). That cover is required as the underside is part of a pivot bearing support. The rest is aluminum. On initial setup, you have to carefully snip the cable and then further grind off the remaining strands using a Dremel stone. Otherwise that cable will scrape the tight tolerance clearance to tire. No cable end is used. For having smaller pad surface, its a pretty impressive brake. Good modulation, and the amount of lever pull felt like the typical racer sidepull / aero levers. The surprise was the light weight. I would own a set again but they too are pricey collectible.
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1079 Post(s)
Liked 1,803 Times
I read an interesting article where the author compared them to Philipe Starck's "day of the triffid" looking tripod juicer. Both are rather attractive. Neither works all that great, yet both are beloved.
https://www.bicycling.com/bikes-gear...o-delta-brake/
"Leave the gun. Take the Colnagos."
Quoted: 2479 Post(s)
Liked 2,948 Times
