Totally Tubular
#2751
Quoted: 2588 Post(s)
Liked 4,824 Times
Question:
When you have two nice wheel sets -- one clincher and one tubular that go with your weekend 50 mile local ride nice bike, which wheel set to you choose under the following conditions? Currently wet roads, fog, mist, and light rain likely for the rest of the day.
When it's wet, I take the clinchers. How about you?
Road debris tends to stick around longer in wet conditions, and said debris is a common cause of punctures. I'd rather hole a tube riding with clinchers than tubulars. Plus, imagine trying to swap out a spare tubular - particularly if using tape vice glue - in wet, nasty conditions.
That be my take.
DD
Likes For Drillium Dude:
#2752
Quoted: 1163 Post(s)
Liked 442 Times
Question:
my interest has been triggered by this query...
I avoid riding in the wet (but I've been caught out by sudden weather changes mid-ride more than once), but if I did: clinchers every time.
That be my take.
DD
That be my take.
DD
would be very grippy in the wet. Probably too nice to trash this way, but I wouldn't mind riding a set of tubulars like this in the wet.
Likes For masi61:
#2753
Quoted: 1949 Post(s)
Liked 2,010 Times
Like DD pointed out, punctures are more likely when the roads are wet.
Likes For Classtime:
#2754
Liked 442 Times
But the crazy side of me STILL desires a road racing set-up with grippy (tubular) rain tires just to check out the ride. Black sidewalls would be a better choice than tan sidewalls here. We all know how gross tan sidewall tubulars look after heavy rain riding
Likes For masi61:
#2755
Quoted: 4806 Post(s)
Liked 3,928 Times
That be my take.
DD
That be my take.
DD
I also used glass catchers with my fenders because the rear fender prevented the hand wipe and at night or in rain, I often couldn't see glass. Rear catcher mounted at the chainstay bridge, front under the crown. I think I drilled out the fender rivets and replaced them with screws but its been a long time.
Timely topic! My new fenders for my TiCycles just arrived at the shop. SKS Blumels with the Esge silver/plastic/metal technology. To be painted with 2-part yellow epoxy paint. Yellow fenders for that fire engine red bike - my vision from conception. Who knew yellow road fenders would be so hard to get? Need to do this glass catcher drilling before paint! (That bike is my par excellence go anywhere, climb anything all weather bike. Fenders, ti, sealed bearings. Water doesn't phase it. Race short chainstays to put enough weight on the rear tire to grip in the wet when I'm out of the saddle and pulling as hard as I can. A real Pacific NW bike.)
#2756
Liked 3,928 Times
My intro back to clinchers ~1988. Living in the Ballard community of Seattle. Used to ride north following the Puget Sound shore but in a couple of miles on very quiet roads. There was a descent into Woodinville that had a 90 degree bend at the bottom. I knew it very well and had done it many times in the wet on sewups. First time with clinchers - winter NW wet. Maybe light ran but I recall seeing OK. Hit that turn and knew instantly I did not have the traction to make it. Expressed the F word very load because I knew exactly what I was in for. The road rash, the bruises, the wet dirty ... At the apex, tires let go and I went for the slide. Outcome exactly as expected.
As soon as I slid to a stop, an attractive young lady appeared. Had to apologize for what she just heard.
And clincher vs tubular for cornering traction? The new clinchers have very, very good tread (the Vittoria Open Paves and I assume the G2.0 Controls; the regular G+ are very good) but I bet, in the real world, the tubulars with the same casing and tread do better. And I've done my crashes. I won't take either to their limit unless that is what I have to do to stay ER free. So someone else is going to have to do that research. (I'd have to glue the tubbies on hard to max out the turns. If I raced, yeah, but otherwise? I'll take the knowledge that I will roll the tire before the tread slips so I have a tire feasible to change on the road. (I ride with brakes for a reason.)
Now, if my hunches are right, my Vitt G2.0 Control 30c tubulars ought to grip like flypaper.
Likes For 79pmooney:
#2757
Liked 4,824 Times
What about "rain" tires? From what I can tell these tubulars : Michelin Power Cup Racing Line Tubular Tire - 25-622 - black | BIKE24 would be very grippy in the wet.
Drive train components wear exponentially faster when used in wet conditions as the road debris I mentioned affixes itself to the chain, which in turn transfers it to the rings and cogs. It's akin to sandpaper slowly but surely wearing away at the moving parts. Brake pads transfer that same grit to the rim's braking surfaces, which in turn gets onto the tire sidewalls; both actions shorten the life of the rims and tires.
Rain-riding - for me - is a zero-sum game, because I'm not training, touring, or commuting, but riding primarily for fun and fitness. I can always wait for the next sunny and clear day
DD
#2758
Liked 4,824 Times
Full disclosure: I also absolutely hate deep-cleaning a bike I've been obliged to ride in wet conditions. I feel more than a bit peeved at myself for having subjected my bike(s) to such abuse, when all they've ever done for me is provide innumerable moments of unadulterated happiness
DD
#2759
Liked 442 Times
Speaking only for myself, it's not a matter of grip.
DD
DD
We're talking aesthetics here, but I'm in total agreement! It's also been shown the additional brake shoe residue build-up serves a role in decreasing the life of the tire's sidewalls if not cleaned off between wet rides.
DD
DD
My tubeless wheelset is built with Chinese made DT Swiss R460 tubeless compatible rims. The sidewall machining on these is good and the rims themselves I only paid about $40 each for (pre-Covid pricing). I'm about to add at least one tubular tire/wheel bike to the stable here soon. The Velocity Major Tom rims have nicely machined sidewalls but they are also mirror polished. I may well cringe if I ride these in the rain and abrade up the pristine sidewalls. Maybe I will report back on the ride of this classic/modern wheelset when it takes its maiden voyage on my rescused size 57 silver Masi Gran Criterium.
Likes For masi61:
#2760
Liked 4,824 Times
I have made washing and polishing my bikes a fun ritual that I try to stay caught up on. Rain rides are adventure for me and some of my best training is done on the crap days. I have a soft nylon paint brush that flows water through a ball valve when connected to the garden hose. I spray a dilute solution of Dawn dish detergent with Simple Green then scrub my tire sidewalls, rim sidewalls, take a toothbrush to my rim brake pads and rinse with clear water. The whole process goes quickly and I also wear a magnifier to be able to visualize where the gritty nastiness lives.
In addition, while deep-cleaning after the fact is a good thing, there's no way to actively deep-clean during the ride. That's when the slow but constant additional wear is happening to the components. I've been running the same chainring pair, for example, on the Colnago Mexico for well over a decade - and there's probably another decade left in that pair, too. I don't 'shift heavy', avoid dirty, wet, nasty weather, and replace chains before their stretch begins to cause undue wear on the rings and cogs. Oh, and of course, periodic cleaning and lubrication of the chain, since it's the component picking up the gunk and distributing it to the rest of the drive train components.
I'm a 'clean-as-you-go' type. The extensive drive train component life I realize from this approach speaks for itself.
Again: speaking only for myself. I understand others have their own vision when it comes to their reason(s) and motivation(s) to ride their bike. It's all good!
DD
#2761
Quoted: 253 Post(s)
Liked 223 Times
So, as previously mentioned, I am a proud owner of some vintage wheels which came with tubulars. Those are trash though and need to be replaced. How do I go about removing the old ones? Do i have to remove all residue? If so, how?
thanks for all the tips in advance!
#2762
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Unless there's a lot of build-up from previous glue jobs... it's fine (maybe even better) to leave it on there. If not and/or you want a clean rim... a wire brush on a drill will take off the crusty stuff without using solvents. You don't want any old tire fabric on the rim... but you'll get better bond with a little "tooth" on it.
#2763
Bikes: Waterford W-13, Ritchey road logic; Ritchey SwissCross; Pinarello Paris ; Surly Karate Monkey monstergravel hauler 1983 Mike Mullet, mid 80s Alpina, late 70s schwinn world sport tourer
Quoted: 19 Post(s)
Liked 33 Times
within reason: leave the residue was what my master teacher taught me, it allows a better bond for the next layer of glue, and a few layers is nothing to sweat
if..however, you have a ton, yes, then lightly use wire brush or lightly sand down carefully and then leave appropriate amount to bond to
It's actually easier regluing than new rims that need a couple layers applied and dry time between
#2764
Quoted: 1607 Post(s)
Liked 2,216 Times
If you use a wire wheel, use a brass one only if crusty residue. Otherwise you may gum up your wire wheel. Brass minimized scoring the rim.
#2765
Quoted: 2338 Post(s)
Liked 2,822 Times
brass is the key word here
#2766
Quoted: 253 Post(s)
Liked 223 Times
The tires were easily removed.. almost fell off, when i started to tear it. Must have been incredibly dry. I lightly sanded the residue off with sand paper, and put on some tubulars for pre-stretching
#2767
Liked 2,216 Times
Judge weather the remaining glue is dried out. If it is, then using a brass wheel will take it off in a matter of minutes for both wheels. Check you sandpaper to see if there is a gumming as a result of the sanding you did.
#2768
Quoted: 2482 Post(s)
Liked 2,952 Times
If you're not sure of what brand the original rim glue was, best to clean it all off before gluing the next tire on. You might luck out, but be aware that some glues act as solvents for each other. (White glue and red = might end up dead.)
(Rebuttal to future replies: as I said, you might luck out.)
#2769
Quoted: 253 Post(s)
Liked 223 Times
Likes For Positron400:
#2770
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
I've had great results with tape and no issues whatsoever. Plus, aligning the tire is very easy.
Bob
Bob
Likes For pastorbobnlnh:
#2772
Bikes: 1980 Dawes Super Galaxy + 1981 Lotus Classique + 1986 Bianchi Sport SX + 2005 Van Dessel Project WR + 2021 Zizzo Liberté
Quoted: 142 Post(s)
Liked 480 Times
If anybody is looking for glue, you can save a few bucks on Vittoria Mastik at backcountry.com right now--$19.99 for the 250g can. Shipping is $5.95. https://www.backcountry.com/vittoria...ofessional-kit
Same deal also through competitivecyclist.com and steepandcheap.com (which is what I did), those are just different fronts for the same store. I've ordered from steep&cheap previously, their sale prices can be very good. Their offerings lean heavily towards MTB stuff but I did find a few more items (bottle cage, brake cables) to spread the shipping cost further.
#2773
Quoted: 253 Post(s)
Liked 223 Times
More questions: When i eventually use tape for putting my tubulars on the rim, should i leave small section of rim w/o tape opposite the valve, in case i need to change the tubular on the road? How do you guys do it?
#2774
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
You will find the tire much easier to remove if you leave the gap.
#2775
Quoted: 253 Post(s)
Liked 223 Times
Installed my first set of tubulars with TUFO rim tape. decided to leave 1 cm untaped opposite of the valve. First ride, and despite the fact that i am used to way wider tyres (30mm +), the 25C challngers rode suprisingly nice! Do i have to remove all the tape, when i eventually switch tires or puncture?
