how do i know when disc brake pads needs to be replaced?
Old 04-11-10, 10:02 PM
misc
i got avid 5, had them for about a year. The braking sucks now.
misc is offline
Old 04-11-10, 10:08 PM
mystolenbikes
mystolenbikes's Avatar
Bikes: Specialized Hardrock
Remove your tire and look at your brake pads and you'll know if you need new pads or not.
mystolenbikes is offline
Old 04-11-10, 10:14 PM
misc
i think the pads are still good, but why does me brake suck so much
misc is offline
Old 04-11-10, 10:25 PM
mystolenbikes
What kind of riding do you do?
Old 04-11-10, 10:37 PM
misc
95% dodging traffic in NY and 5% mtn
misc is offline
Old 04-11-10, 10:41 PM
mystolenbikes
Then it's your pads. Just check them, it only takes 30secs to remove your front tire.
Dannihilator
Still kicking.
Dannihilator's Avatar
Bikes: Bike Count: Rising.
Quoted: 145 Post(s)
Liked 31 Times in 24 Posts
Pads should be replaced once a year and in some people' cases around here a couple of times(at least.)
Hydros or mechanicals?
Appreciate the old bikes more than the new.
Dannihilator is offline
Old 04-11-10, 10:43 PM
Shadowex3
Bikes: Kuwahara Aries
Not tight enough perhaps?
Shadowex3 is offline
Old 04-11-10, 10:48 PM
mystolenbikes
He's been dodging traffic in city for a year on those brakes I bet you he put a bout a 1000 miles on those pads.
Old 04-11-10, 10:56 PM
misc
861 miles to be exact. so i should get them replaced?
misc is offline
Old 04-11-10, 10:59 PM
Dannihilator
Still kicking.
Quoted: 145 Post(s)
Got to be careful with the disc brakes to replace the pads when the pad area itself is thinner than the thickness of the end of a flat bladed screwdriver. Past that point you stand the chance of damaging the calipers.
Edit: Yes I would say after 861 miles that it would be time to replace the pads.
Old 04-11-10, 11:03 PM
mystolenbikes
Originally Posted by dannihilator
got to be careful with the disc brakes to replace the pads when the pad area itself is thinner than the thickness of the end of a flat bladed screwdriver. Past that point you stand the chance of damaging the calipers.
Edit: Yes i would say after 861 miles that it would be time to replace the pads.
+1
Old 04-11-10, 11:11 PM
electrik
Single-serving poster
electrik's Avatar
I read once there is about 3mm deep of material left... maybe that is a bit premature.
electrik is offline
Old 04-12-10, 07:14 AM
Covalent Jello
DEJA VU
Covalent Jello's Avatar
Just put new pads in the front for avid juicy 5's
I don't get it, thought they'd be tighter and more responsive but they are just about the same
New disc, and new pads, hydraulic
Covalent Jello is offline
Old 04-12-10, 08:05 AM
lubes17319
Chronic 1st-timer
lubes17319's Avatar
Bikes: ...take me places.
Clean & sand the rotors
lubes17319 is offline
Old 04-12-10, 05:26 PM
Shadowex3
That's why I asked if it was all set properly, if you're yanking and not getting enough braking force it could just be that it's gripping too loosely...
Old 04-12-10, 08:02 PM
helifitz
Bikes: HiFi Pro 29
You said you have Avid 5 brakes. Assuming Avid Juicy 5's or Code 5's you may have air in the hydraulic lines which will require bleeding.
helifitz is offline
Old 04-17-10, 02:06 PM
Covalent Jello
DEJA VU
edit
Old 04-17-10, 02:08 PM
Covalent Jello
DEJA VU
i got the avid juicy 5's, no brake lines were opened which youd think would mean no air could get into them
i suppose it could be due to not cleaning the rotor before installing, forgot to do that, doh..
its moreso that the lever depresses farther than the bite not being good
tried adjusting the calipers (didnt touch the lever adjustments as they havent been touched to begin with)
might just leave it
but then again, brake fluid is hygroscopic (??) and can get moisture in it over time
which really effects braking
at least on cars
Old 04-17-10, 05:10 PM
Zan
Zan's Avatar
Bikes: Road: Trek 1.5 (2007). Mountain: Santa Cruz Chameleon (2008). Beater: Peugeot Recorde du Monde (1850)
You should bleed your brakes. Being able to pull the lever and not get any braking power (with clean pads and rotors) means that the problem may be a lack of fluid, or air bubbles in the line.
Bleed kits aren't terribly expensive, and it's easy to do it yourself.
Try not to touch the pads / rotors with your hands. You really shouldn't be getting any oils on these parts.
Zan is offline
Old 04-17-10, 10:52 PM
zjk
bleeding would probably be the next step to take in trying to get the brakes how you like them. One thing to also remember is that there is a little burn in period for the pads when they are first installed. The braking right away won't be quite as good as after they have been broken in.
zjk is offline
Old 04-20-10, 04:51 PM
acpeeps
road, mud, what ever
acpeeps's Avatar
Bikes: '82 motobecane, '06 Giant XTC
I replaced mine when I hit the tree.....
I get new ones every season....at 260lbs.....i HAVE to
acpeeps is offline
Old 04-20-10, 05:23 PM
dminor
Moar cowbell
dminor's Avatar
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 4 Times in 4 Posts
"[BikeForums] is the best thing ever. Anyone in the world can write anything they want about any subject, so you know you are getting the best possible information."
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
dminor is offline
Old 04-20-10, 06:45 PM
ed
ed's Avatar
Bikes: Hecklah
Well said!
ed is offline
Lew.
Mountain Biking
0
12-22-13 03:08 PM
Black Jaque
Bicycle Mechanics
0
04-01-13 03:23 PM
kardar2
Bicycle Mechanics
0
03-29-13 07:34 PM
mcdun13
Bicycle Mechanics
5
01-14-11 10:46 AM
