WD40 Anti-Rust on BB threads
Hi all,
While rust-proofing a new steel frame recently with WD40 Corrosion Inhibitor (basically a fancier type of WD40 that is supposed to help with preventing rust), I accidentally got some on the BB threads. I didn't notice this till it already dried. It is not a lot, but enough to be noticeable. Is this a bad thing? I saw a YouTube video where the mechanic cautioned against getting framesaver on the BB threads. And if it is a bad thing, how do I remove it? Do I try using regular WD40 and wiping with a cloth?
Quoted: 462 Post(s)
Liked 372 Times
There's quite a bit of discussion about this cheap penetrant, this one may be related to your concerns:
https://www.bikeforums.net/bicycle-m...urt-tires.html
I would wash the whole bike with your fave bike soap, and then avoid using WD40 at all.
All rust inhibitors don't work if dirt is left there to keep things moist and mushy.
Regularly washing a bike and having it lazily drip-dry will be more effective.
Despite how crappy WD40 is, it will penetrate when left over long periods of time, and you don't want any of it to mix with any lube, especially in the BB.
Guest
Quoted: 1346 Post(s)
Liked 3,269 Times
You could always ask a local shop to chase the BB threads. It only takes a few minutes and should be cheap.
Bikes: Old Stuff
Quoted: 912 Post(s)
Liked 514 Times
Hi all,
Likes For FBOATSB:
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
Wire or tooth brush and some mineral spirits rags and clean it out.
Likes For dedhed:
SE Wis
Liked 3,361 Times
Common really to rustproof a steel frame internally, in fact they make products specifically for that.
Once sprayed in you flip the frame around so it coats all surfaces and some runs out the main tubes into the BB shell.
https://problemsolversbike.com/files...er_INST_VF.pdf
Likes For dedhed:
Friendship is Magic
Bikes: old ones
Quoted: 26251 Post(s)
Liked 10,233 Times
Hi all,
If the frame is Italian or French threaded, I usually install the fixed cup using Loctite, if it's an old school cup and cone loose bearing BB. For that to work, you need a cleans threaded surface. So for those, I clean it with acetone oor mineral spirits before installation. Unless it's something like that, I wouldn't worry much about it.
Quoted: 2304 Post(s)
Liked 2,742 Times
not at all, very common to treat steel frames with rustproofer like J.P Wiegle ....
Likes For squirtdad:
Likes For bitpuddle:
I recently treated a frame with the WD-40 corrosion inhibitor, as I couldn’t get FrameSaver anywhere. The product seems similar to FrameSaver, if a bit thinner and much less noxious. It seemed to dry more quickly, as well.
After it set, I did clean out the BB/headset/seat tube before greasing and assembling, but I can’t imagine that product causing issues with the threads (particularly if you grease them).
Quoted: 712 Post(s)
Liked 793 Times
I build bicycle frames and they all get protected inside with Amsoil Heavy Duty Metal Protector, which is very similar to Frame Saver. The frames sit in the stand overnight to dry and he excess coating drips down and puddles in the bottom bracket. I just wipe the excess away with a rag and have never concerned myself with having it in the bottom bracket threads. Its just a wax coating and won't hurt anything. I can't even imagine what kind of harm someone could think it would do.
Likes For dsaul:
Quoted: 2578 Post(s)
Liked 1,901 Times
It could...
It could keep the bottom bracket from corroding into the frame, so the next time you need to replace the bottom bracket, with that waxy stuff in the interface, it could take an hour or two instead of giving you six weeks without a usable bike. That would deprive you of a chance to go buy another bike!
Likes For pdlamb:
Can't imagine? Can't even imagine?? Well, it could --
It could...
It could...
Bikes: Old Stuff
Quoted: 912 Post(s)
Liked 514 Times
Just curious.
I have never even held in my hands a brand new bare frame. Having the BB threads and shell faces chased with a proper BB alignment tool is an acceptable practice and just as important as dropout alignments. Has this been done on your frame?
Quoted: 4746 Post(s)
Liked 3,861 Times
My less than scientific approach: I'd simply grease the threads with a generous amount of marine grease (the stuff from auto parts stores for boat trailer hubs), screw in the BB and forget about it. Can't imagine that unscrewing it is going to require much more force than going on even if it's 10 years or more.
Yes, if I had to fight to screw the cups in, I'd back them pout and re-think this but till then ...
Likes For 79pmooney:
Liked 3,861 Times
...I have treated many frames internally with Rustoleum corrosion inhibitor, which leaves an oily deposit on the interior surfaces. It usually gets on the threading of the BB shell. I have honestly never thought about it as problematic. The only conceivable thing it might do in that spot that would present a problem might be if it somehow interfered with the threading enough to inhibit cup and spindle installation. Which it never has, IME.
i intend to let my LBS do just that!
Constant tinkerer
Just wipe the threads with a rag before you grease them to install the bottom bracket.
You cannot possibly have hurt the bottom bracket threads, jeez. I hope all the ridiculous nonsense responses were jokes.
Likes For FastJake:
