How to pull cables fast enough into derailleurs?
Bikes: Cannondale Bent 2, Fuji Royale, Mongoose Snare
Quoted: 103 Post(s)
Liked 8 Times
I usually use pliers but I suspect there must be a less abusive way. Sometimes it's easy, others is not. Currently struggling with the front one on my Fuji Royale. And yes I have it in the gear that provides the most slack. I need to pull it in another 5mm to be able to shift up. Thanks
Whats the trick/tool to do this right?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Holy crap. First, get a new cable. Having a full length cable makes it easier to pull. If you can't get it to work that way, cheat the low limit screw. Undo the cable, screw the low limit in a full revolution or so, attach the cable, undo the limit screw the same amount you turned it in. That old stuff doesn't work very well even when it's in good shape.
Quoted: 241 Post(s)
Liked 232 Times
I've used a 4th hand brake tool to hold some tension on the cable while tightening the pinch bolt.
Likes For RGMN:
LR÷P=HR
Quoted: 865 Post(s)
Liked 1,204 Times
Zip Tie
Pull the FD in with a Zip Tie, then cut it off when your done.
Barry
Barry
Likes For Barry2:
Really Old Senior Member
You can put it on a larger ring (or just hold the cage over) and then screw in the L screw the needed amount.
Then shift back to the smallest ring.
Quoted: 426 Post(s)
Liked 274 Times
I have always just used the limit screws on the front and rear derailleurs. Super easy that way.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3883 Post(s)
Liked 6,476 Times
- Understand where you need the lower limit.
- Return the shifter to its forward position.
- Tighten the lower limit two full revolutions or so, noting exactly the number of turns of your screwdriver.
- Secure the cable to the anchor bolt.
- Return the limit screw to its proper position.
- Check for cable slack. If there's too much, you know you need to turn the lower limit screw even more.
- Repeat/try again.
Always use a socket driver (not a wrench!) on the anchor bolt. You won't strip it that way. I use a 5/16" socket on anchor bolts like this.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
This, 100%.
- Repeat/try again.
Always us a 5/16" socket driver (not a wrench!) on the anchor bolt. You won't strip it that way.
- Repeat/try again.
Why are you using a SAE tools, most bikes have metric size fasteners and typically the nut for the anchor bolt on the FDER is a 9mm, works fine with a socket or combo wrench. Using the wrong tool may be the source of your damage warning.
Likes For JoeTBM:
señor miembro
Liked 6,476 Times
While using the limit screws will help and should work, new cable and housing would go a long way towards making this easier. There must be so much friction in that old housing that it would barely work even if you could take up the slack.
Likes For BTinNYC:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
No Thanks, I believe my 9mm works just fine, I haven't had an issue in adjusting thousands of FDERs
Likes For JoeTBM:
