Brake "feel" after changing brake pad
Quoted: 106 Post(s)
Dear all.
I have a SRAM Red etap with disc brakes. Got Swissstop pads to replace the oem pads- both, front and rear brakes. The issue is that now the front and rear brake "feels" different.... The rear feels "firmer" While is no big deal, it does feels odd.
The only thing I could think of is that when I was installing the rear pads, the new spring that came with the pads did not fit (faulty?). So I ended up using the OEM springs.
I tried fiddling with the reach of the levers but is more like a "feel" when braking...
ignominious poltroon
Quoted: 2228 Post(s)
Liked 3,412 Times
As the pads wear, the pistons move out a little bit, and the response feels slightly more squishy. This is subtle enough that you don't notice it until you put new pads in, and suddenly it feels firmer. Most people like that.
Likes For Polaris OBark:
Liked 3,412 Times
Likes For eduskator:
Quoted: 20808 Post(s)
Liked 9,450 Times
I'll agree that my levers typically feel a little more firm with new pads and my suspicions for that match the piston position assumption already mentioned.
Another thing to keep in mind is that the new pads need some time to bed in to the rotor, so you're going to need more lever force, for the same amount of breaking power, until the pads start biting like they should.
Likes For WhyFi:
Quoted: 815 Post(s)
Liked 1,647 Times
The piston in the caliper slides outward in a bore when the lever is applied, and then retracts every so slightly due to the seals returning to a non-deformed state. This keeps the distance between the pad and rotor constant, no matter how worn the pads are. As the pad wears, the piston just moves further out, and more fluid fills the space behind it. Since fluid cannot be compressed, the "firmness" of the lever application should remain constant, provided no air gets in the system. It's really no different than the disc brakes on an automobile. You can still have a good 'feel' on the brake pedal even when your brake pads are worn out, which is why most modern auto disc brake pads have little metal tabs on them that will scrape against the rotor when the pad gets to its useful limit, and squeal like crazy to let the driver know.
Likes For Bald Paul:
Bikes: SL8 Pro, TCR beater
Quoted: 981 Post(s)
Liked 583 Times
That's really not how disc brakes work.
Quoted: 815 Post(s)
Liked 1,647 Times
Exactly, fluids can't be compressed, which means that when more fluid fills the space behind it, there is less fluid in the brake lines and that equals to softer brake levers since more travel is needed to get the required pressure. My brake pedals and levers (cars, motorcycles, bicycles) have always felt firmer after changing the pads. Everyone seems to be agreeing on that statement.
Many years ago, when cars had drum brakes with non-self adjusting brake shoes, owners would have to come in now and then to have the brakes adjusted, as the gap between the drum and shoes would increase with wear, causing a lower brake pedal. Self-adjuster mechanisms helped (when they didn't rust up) but disc brakes are superior. As a professional auto tech for over 40 years, I've seen cars come in with brake pads worn down to metal backing plates, and rotors ground almost clean through. The only reason the owners came in was because the piston had to move out so far, the seal popped out past the caliper bore and they lost their brakes. Up to that point, they still claimed they had a 'good pedal' although the brakes were a bit noisy!
Now, if the OP flipped the bike upside down to service the pads, it is possible that some air entered the line, in which case bleeding the system should help.
