Dura Ace brake knurled washer replacment.
Tange
Bikes: 74 Raleigh Super Course Mk II, 77 Nishiki International, 77 Motobecane Super Mirage, 84 Team Fuji, 85 Schwinn Traveler, 86 Schwinn Prelude, 86 Raleigh Technium 460, 87 Raleigh Technium Tri Lite, 88 Cannondale "Crest", 96 Giant ATX 830, 05 Trek 1000
Quoted: 44 Post(s)
Liked 103 Times
We can't delete posts.
We can't delete posts, so we're stuck editing them.
Last edited by chiefkurtz; 10-26-22 at 07:45 AM. Reason: Why can't we delete posts?
Quoted: 3504 Post(s)
Liked 2,922 Times
LR÷P=HR
Quoted: 865 Post(s)
Liked 1,201 Times
A $4 washer is an expensive washer!
Anything on a bike that costs $4……. Bhahahahaha!
Barry
Barry
Tange
Quoted: 44 Post(s)
Liked 103 Times
I didn't, I said "The only solution I can find is expensive", that being a genuine Shimano part (#Y87008100). If you found a link selling that item for $4, please advise. I don't know if the Campy one is compatible, hence my post.
Liked 2,922 Times
But it's not "just" a washer--it's a Campy toothed washer!
And I see no reason why it wouldn't be "compatible." Brake bolts are the same diameter.
Liked 2,922 Times
Tange
Quoted: 44 Post(s)
Liked 103 Times
Clearly, nobody is reading the post, or is having difficulty comprehending.
Tange
Quoted: 44 Post(s)
Liked 103 Times
Tange
Quoted: 44 Post(s)
Liked 103 Times
Liked 2,922 Times
I'd just buy the Campy washer and use it until you find a reasonably priced Shimano washer--assuming you want to keep it all Shimano, for some reason.
Liked 2,922 Times
Tange
Quoted: 44 Post(s)
Liked 103 Times
Yeah, the post was does anyone have experience using the Campy washer on a Dura Ace caliper. Bike Forums maintains its 100% rate of non germane responses.
Liked 2,922 Times
I'm more curious about how you destroyed the washer to begin with.
LR÷P=HR
Quoted: 865 Post(s)
Liked 1,201 Times
Here you go.
Another £14.32 ($15.86 shipped from UK... still cheaper than ebay)
$12.62 shipped (Two as a set , so $6.31ea)
I'm still trying to find one for you in the US.
Gave up..... the US is a desert if you want repair parts. I always seem to be able to get what I need from the UK.
I believe for economic reasons, the US tends to replace the unit and UK is forced to effect a repair.
OK I'm NOT going to be beaten by this, so I changed search engine....
$14.98 Shipped from Huntington Station, N.Y. (Backorder Arriving Soon)
OK Now I'm just having fun... $11.74 shipped from Utah
Barry
Barry
Likes For Barry2:
Quoted: 323 Post(s)
Liked 730 Times
Have you tried a bike shop? Is it important to you that it is a Shimano part? Every shop I’ve worked at has had a bin of generic brake washers that go for a dollar or 2 each.
https://www.universalcycles.com/shop...tribute=172402
LR÷P=HR
Quoted: 865 Post(s)
Liked 1,201 Times
Oh I read it.
Then decided to present an opinion rather than a solution, you know, this being the internet and all !
Then after your comment... decided you may deserve a solution, so I googled up a couple... you know, with this being the internet and all !
Barry
Barry
Likes For Barry2:
Tange
Quoted: 44 Post(s)
Liked 103 Times
I've seen all of those, the shipping costs are prohibitive. I know how to google. The question was if anyone has direct experience using the Campy one on a Dura Ace caliper.
SE Wis
Quoted: 2744 Post(s)
Liked 3,390 Times
Any one of the right dimensions should work just fine.
https://www.porkchopbmx.com/dia-comp...sher-25mm.html
Liked 2,922 Times
It's a washer. It has teeth. Every one that was suggested will fit the brake bolt. Just buy one--I promise it'll be fine.
Geeze, we aren't talking about whether a 12-speed Campagnolo shifter is compatible with a 9 speed Shimano rear derailleur. It's a washer!
Quoted: 5774 Post(s)
Liked 2,571 Times
Stupid question.
Looking at the photo I'm wondering why the washer broke that way. Just to check, does your brake bridge have a mounting face with a diameter greater than 12mm? If not (and many don't) the star washer is useless since the rim doesn't engage anything, plus the bolt will bear on the center, fracturing the washer.
FWIW - yes the Campy washer will work. Also, you don't really need these. There's minimal rotational forces on brake calipers and once tightened they tend to stay put. If you want more traction without spending any dough, you can mix a bit of sand into grease and apply between the mating faces. When compressed, the sand will bite into both and prevent any relative movement.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
Using a Campy washer on a Shimano bike is letting the Camel’s nose under the tent. This will lead to endless searches for the rest of the group set. I would recommend sticking with Chorus, Record would get real expensive.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Liked 2,922 Times
Just buy the washer. Using sand on your bike is right up there with the worst advice I’ve ever seen. This isn’t a hobby for the cheap.
Sand…seriously?
Liked 2,922 Times
Steel on steel v carbon on carbon?
Listen…do what you want. Add as much sand to your bike as necessary. Sounds like an insanely cheap and effective solution to most problems.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
That toothed washer is probably doing more with the paint than the actual fork crown metal anyways.
Sand is a perfectly reasonable and practical solution, assuming we’re talking flat on flat.
If you want to be picky, the industrial way of doing this is with a diamond impregnated washer on a clean smooth surface. They cost around $1 each in quantities of 2M/year, and they aren’t reusable.
Likes For jccaclimber:
