RivNut Question
Quoted: 455 Post(s)
Liked 112 Times
RivNut Question
I am doing a ebike conversion for a friend. The frame is aTrek Antelope. The battery will be mounted on the DT. I would like to add 2 more mounting points to to make it more secure but don't want to mess up the nice paint. Wi using a RivNut compromise the DT?
Thanks!
Thanks!
Randomhead
Liked 3,687 Times
It's not likely to hold.
Likes For unterhausen:
Quoted: 4195 Post(s)
Liked 3,837 Times
Rivnuts have a bad enough time dealing with the mass of a water bottle. Is the motor less weight? How does the motor react to its drive forces? How do the various mounting points deal with this vector? If the Rivnuts were positioned so that only shear forces are seen and there are no rocking forces than maybe enough Rivnuts could work, but I wouldn't trust it until a trial was done with enough miles/cycles to make me comfy. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Randomhead
Liked 3,687 Times
It's for batteries, not the motor, so there isn't a concern with torque. OTOH, I recently saw a pic where a battery just ripped out a batch of mount points. Most production ebikes don't use water bottle mounts at all.
Liked 3,837 Times
My mistake for not catching the battery mounting aspect. Still my concerns are much the same as Eric's.
Tom mentions adding additional mounts. I assume this is in addition to the factory bottle mounts. Steel or alloy frame (as in brazed in place bosses or compressed rivnut types)? Andy
AndrewRStewart
AndrewRStewart
Quoted: 455 Post(s)
Liked 112 Times
Thanks for the replies. For perspective I Used Rivnuts on my ebike conversion, a Giant Escape,which is an aluminum frame. Have about 1400 as of yesterday. This is my commuter bike.
Randomhead
Liked 3,687 Times
It won't compromise the dt until the rivnuts tear out. If you're convinced it will work, have at it.
Get one of these mounts, and run the hose clamps. Most secure mounting I've done or seen. They come with some heat shrink for the clamps to protect the paint, I just used some rubber strips from a reflector set and it looks much better.
I have added a rivnut as well, it was okay. Still had to run the hose clamps, too much movement without them.
https://ebikes.ca/shop/electric-bicy...ouble-bob.html
https://ebikes.ca/shop/electric-bicy...riple-bob.html
framebuilder
Wes's solution seems like a solid one. It would also be possible to drill holes on the other side of the tube so that the bosses being used could be attached with bolts going all the way through the tube. Of course there would need to be reinforcements around all the holes (probably made out of .058" wall tubing) to distribute the stresses over a wider area.
Randomhead
Liked 3,687 Times
I like that clamp on mount. I'm wondering if I should get something like that laser cut to be brazed on.
