Novice question
Quoted: 11 Post(s)
Liked 31 Times
Novice question
I apologize for asking this question the answer to which is probably common knowledge, but, here it is: On a "road bike", that is, on a bike with the handlebars that turn down so the ends of which point back to the bike -- in looking at photos I see the brake handles on the right and left handlebars, but WHERE ARE THE SHIFTERS? Are they located at the point where the handlebars join the frame? If so, then you have to take one hand off the handlebar to shift gears?
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,992 Times
Likes For veganbikes:
Quoted: 523 Post(s)
Liked 229 Times
No apology needed. Those are called drop bars. Several choices depending upon how old the road bike might be. I've had them on the downtube part of the frame below the headset. (downtube shifters), at the very ends of the handlebars (handlebar shifters, and integrated with the brake handles (brifters?). If you don't see them it probably has the latter. You can see the latter here:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
No apology needed. Time to learn and ride.
The road bike bars you mention most call drop bars. The brakes these days on 99% of bikes are referred to as brifters. The shifters are integral to the brake levers. Right controls rear derailleur and left the front. There is mechanical and digital. For most mechanical pushing the brake levers inward shifts to the larger cog or ring. Behind the brake lever is a small lever that shifts down to smaller cogs.
Take a trip to your local bike shop. They’ll be happy to show and demonstrate all the permutations. Go for a test ride. Pretty soon you’ll have a new ride.
I type too slow on a phone.
Sr Member on Sr bikes
In addition to those shifter locations afore mentioned…down tube, bar end (of the handlebar), and integrated (with brake handles)…you may also experience shifters mounted at the stem; twist shifters on the top bar of the handlebar; and even thumb shifters that are usually utilized on mountain, hybrid, and commuter bikes.
Dan
Dan
Likes For _ForceD_:
Quoted: 11 Post(s)
Liked 31 Times
Thanks for all you replies -- told me exactly what I need to know.
I'm in rural VA where the Potomac River joins the Chesapeake Bay; nearest bike shops are in Richmond or Williamsburg, two hours away. Probably will not get to either for couple of months so I'm doing my research online.
Thanks again. This is a great place with lots of helpful people!!
Likes For Average Old Guy:
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
https://twowheelsbetter.net/bike-shifter-types/
https://www.levelninesports.com/lear...n/shifters-101
then there are internal geared hubs (IGH) like 3 speeds with different shifters.
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times
I have four bicycles, all different shifting methods - brifters, indexed thumb shifters, bar end friction shifters, friction thumb shifters. When I switch rides, it takes a few minutes to remember how to do it. If you choose a bike, the shifts woon will seem logical and easy.
Likes For _ForceD_:
Quoted: 270 Post(s)
Liked 447 Times
Nice riding up in the Reedville area. This spring I want to park in Kilmarnock and ride around. I'm in Gloucester. Yes your choices are a trip. Williamsburg, Newport New and Richmond. Trek and the Contes in Williamsburg have more space for test rides. See Betsy a the Trek store.
