Cable guide under Captains bottom bracket
Quoted: 5 Post(s)
The blue colored cable guide under the Captains bottom bracket on our tandem has cracked. Does anybody know where to get a new cable guide for under a tandem Captain’s bottom bracket shell. I looked around on the internet, but everything seemed shaped specifically for single bikes and thus would not work for a captain’s bottom bracket shell.
Thanks,
Thanks,
Since Paketa is out of business, I would suggest reaching out to other tandem manufacturers who use similar cable guides and see if one of them would sell/send you one. Alternatively, you could try a regular plastic guide from a single bike and just cut off the back half of the front derailleur guide. The guide doesn't have to do much other than help the cable turn toward the next guide without creating too much friction, so that would probably work.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
1. It's cracked, but is it actually causing a problem? The cable tension probably keeps it in place, and if it isn't impacting your shifting in a detrimental way I wouldn't worry about it. I've worked on bikes that didn't have the guide, but rather a piece of cable housing liner to protect the paint. One of the even older ones the cable just runs unprotected over the shell.
2. A search for "cannondale tandem cable guide" or "tandem cable guide" turned up several options that don't have the tail.
3. Cutting the interfering part of an existing guide as suggested above seems like a viable option.
4. For the more motivated, a 3d printed option seems pretty feasible as well.
Quoted: 624 Post(s)
Liked 396 Times
Clean it up the best you can and Shoe Goo it in place. The shoe goo will hold it in place. If you want to remove the Shoe Goo later use a pair of pliers on the Shoe Goo to pull it off.
+1 on reaching out to tandem manufacturers. I purchased a replacement guide a few years back from Co-Motion and IIRC it was only a few dollars.
It may well stay in place if you leave it as is, but if it doesn’t you may lose shifting or brakes and it would never be at a good time. Relying on goopy goo may get you a few miles but would not likely last very long. A few bucks is cheap insurance.
You could also try any of the tandem dealers, they could easily help you.
Quoted: 624 Post(s)
Liked 396 Times
