Stitching Tools
Stitching Tools
These instructions:
https://web.archive.org/web/20121103040713/https://chefonabicycle.com/2012/10/28/how-to-correctly-patch-a-tube/
seem pretty good. My procedure isn't too different. They use a dedicated stitching tool to press the patch and tube together. When I'm at home I've been using the edge of the cement can, which seems to work ok.
I still don't have a good substitute for a stitching tool on the road. What do you use?
climber has-been
Quoted: 3427 Post(s)
Liked 3,561 Times
Likes For terrymorse:
I keep a quarter coin in my saddle bag for that very reason. You get good purchase on the coin and the serrations on the edge help stitch-down the patch. I roll and rub it over the patch.
Likes For drlogik:
Likes For wheelreason:
I let the glue dry for much longer than you'd expect, and then press the patch on to the tube firmly with my fingers for a couple of minutes. That's enough - the pressure of the tube pressing against the tyre when pumped up provides the rest of the pressure to keep it from moving. (Don't pump the tube up to test it before putting it back in the tyre - it will expand more than the patch can and cause a problem)
Likes For Pootler:
SE Wis
Quoted: 2745 Post(s)
Liked 3,390 Times
I patch tubes at home and use a deep socket
Likes For dedhed:
climber has-been
Liked 3,561 Times
good point! I find those on the road once or twice a year. The last one had a ratchet on it.
but what about a couple co2 cylinders? I assumed they were too round but if a socket works then maybe they'd be the best "already on the bike" solution.
just got two more spare tubes (3 total) so your "patch tubes at home" suggestion is looking more in reach.
Thread Killer
Quoted: 3133 Post(s)
Liked 1,701 Times
Hold on now, this is crazy talk! A stitching tool??!! The whole point of vulcanizing glue is to chemically bond the patch and tube, so there’s no mechanical bonding required at all. As terrymorse said, it takes very little pressure to apply a vulcanized patch; just finger pressure.
If you need a tool to create a successful patch, you are doing it wrongly.
The things one needs to worry about are proper tube prep, applying a sufficient amount of glue, and the exercise of patience. That’s it.
I don’t even use glue anymore, only self adhesive patches, and they work well to the point that I can’t recall having one fail, so I don’t know why people mess around with glue-on patches at all anymore. Hell, I’ve had a Lezyne SA patch on a Schwalbe Aerothan TPU tube for 8 or 9 months now…
I've had patches fail because they appear to have had bubbles underneath. Good pressure from the center out using some sort of tool is my plan to prevent this.
I love glueless patches but discovered that you have to follow the directions closely, and they don't seem to work for pinch flats on the inside of the tube (facing spoke nipples).
Sr Member on Sr bikes
This reminds me of the satirical pic (attached) on the Sheldon Brown pages about the “proper” way to clean a chain. Certainly you can acquire all the materials, and go to all the trouble to “stitch” a traditional patch. But isn’t that overkill? I’m with others who’ve said they use the self-adhesive patches like “Skabs.” They work well, last long time for me.
Dan
Dan
Likes For _ForceD_:
Should Be More Popular
Quoted: 22592 Post(s)
Liked 8,925 Times
Likes For datlas:
Quoted: 1068 Post(s)
Liked 783 Times
Likes For OldTryGuy:
Quoted: 4802 Post(s)
Liked 3,923 Times
I've been using just my fingers this past 50 years. When I've kept the tube relatively clean, decently sanded and let the glue dry enough and located a large enough patch correctly, they've just about always worked. I'm hearing now I've been doing it wrong a very long time.
To me, fingers have it all over those tools. Completely weight weenie-friendly. Very accessible. Take up no space in my tool bags (and I don't need another set for each bike), never get lost or misplaced, work in just about every situation I've ever ridden in. (Well, not so well on the very coldest days but in those days, I rode tubulars in the winter, partly for that reason. Also cyclocross tires, which in those days were all tubular, make excellent snow tires.)
And last, I guess I should just read the Rema instructions to see what I should have been doing.
Liked 8,925 Times
^ I think Rema says fingernail or coin.
If you are reusing patched tube immediately it matters less as the air pressure in the tube will help apply ongoing pressure to the patch area, but if you “batch patch” like me, I think it helps to use a stronger tool than a fingernail.
As always, YMMV.
As always, YMMV.
Likes For streetsurfer:
Quoted: 5224 Post(s)
Liked 3,581 Times
"Long story short" precedes long story
I take deep breaths
I take deep breaths
Quoted: 569 Post(s)
Liked 581 Times
Rema recommends a stitching tool, I carry spare tubes and repair at home using a screen door screen installation tool which is the same thing.
https://www.amazon.com/Prime-Line-75...02781043&psc=1
Rema site instructions:https://www.google.com/search?q=rema...0PEP7a2MmAI_18
