Soldering wiring guides on steel frame?
Passista
Quoted: 866 Post(s)
Liked 711 Times
After 11 years and 50,000kms I'm going to strip and brush-paint (thanks randyjawa!) my steel hybrid frame. I use dynamo lighting with the wires fastened with zip ties. Thought to make guides from thin sheet metal and tin soldering them to the bare frame. Never seen it done before, what do you think of it?
Sr Member on Sr bikes
On a steel frame I think I’d consider internal routing before soldering tubing onto the frame.
Dan
Dan
Quoted: 4172 Post(s)
Liked 3,793 Times
Since the wire guides/clips will see very little tension on them and should one come off the results is not likely to be a immediate safety situation I sat YES, simple plumbing solder should be fine. Consider looking at the K&S model metal tubing offers before making your own clips. They offer cool brass tubes in small diameters and thin walls that are easily manipulated, filed, sanded. Andy
AndrewRStewart
AndrewRStewart
Quoted: 929 Post(s)
Liked 1,595 Times
No problem. I have silver soldered/brazed many Shifter and Cable Bosses to my steel frames. I use a little Harbor Freight touch and plumbers silver solder with regular copper pipe flux. It's no biggy but you should do a few test runs on similar tubing. I also make sure the frame and bosses are clean and sanded to expose raw metal.
https://framebuildersupply.com/collections/braze-ons
Quoted: 1438 Post(s)
Liked 1,092 Times
Likes For dsbrantjr:
Quoted: 598 Post(s)
Liked 377 Times
I used glue on hydraulic cable guides on the frame and rear rack. I cleaned the paint with alcohol stuck them on then to make sure they stayed on I used a little Shoe Goo.
Passista
Quoted: 866 Post(s)
Liked 711 Times
Soldered 3 guides, all went OK.
Before finishing:
Finished:
This guides are 6mm diameter and they will be used for my Nexus cable & dynamo wiring.
Before finishing:
Finished:
Quoted: 194 Post(s)
Liked 204 Times
Having seen this I am planning on doing something similar on some of my bikes
As I also use dynamos but dislike having wires wrapped around the frame I sometimes run the wires through brake housing and then clip that to the frame.
IGH and front-to-rear dynamo housings
