bottom bracket adjustable cup stuck
Quoted: 339 Post(s)
Liked 623 Times
Old 70's Ron Cooper with Campi bottom bracket cups
Adjustable cup with 6 holes for pin spanner.
I have tried using a pin spanner on it and it won't budge.
I Have used liquid wrench on the threads.
Is there a social wrench for this type cup with multiple pins so you can use more force?
Any suggestions for how to extract this cup with out destroying it that have worked for you?
Quoted: 339 Post(s)
Liked 623 Times
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,445 Times
You could remove the fixed cup and BB from the other side, then once you have unfettered access try a large bolt and lock washer inserted from the drive side with a lock washer and nut on the side we see in your photo. Then use a socket on the bolt head and a big wrench on the nut. You might be able to "tighten" the bolt to drive the cup out. I'd use an impact driver on that bolt. Lots of soaking with Kroil or PB Blaster and some heat before trying the wrenches, of course.
Guest
Quoted: 1346 Post(s)
Liked 3,269 Times
Likes For Rolla:
Liked 2,445 Times
Duplicate thread.
Quoted: 2304 Post(s)
Liked 2,742 Times
https://www.sheldonbrown.com/tooltips/bbcups.html
Likes For squirtdad:
Really Old Senior Member
IF you can remove the fixed cup, you can try the PO from the opposite side.
Squirt onto the shell and let it run down the side of the cup. The beveled inner edge of the cup acts like a reservoir. Let soak. Repeat a couple few times.
Could the cup possibly be "painted in"?
Friendship is Magic
Bikes: old ones
Quoted: 26250 Post(s)
Liked 10,232 Times
When you heat it, focus your torch heat on the cup itself.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 834 Post(s)
Liked 332 Times
Are you sure you are turning it in the right direction? You should be able to grab it from the sides with a Vise Grip.
Likes For 2_i:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
OP said "remove it without destroying it"...that kinda rules out Vise Grips. I thought Campy or somebody made a wrench that was half round on the end and it had 3-4 pins...can't remember for sure.
Droid on a mission
Quoted: 315 Post(s)
Liked 276 Times
Don't know what type of pin wrench you were trying but this style you can use with a cheater bar vs. the "V" type.
There is also a version meant to work with a ratchet wrench or breaker bar from McMaster-Carr but it's not cheap
Shown with Ratchet Wrench (Not Included)
Wrench
Replacement PinUse your ratchet wrench as a handle. Reverse the pins to fit different hole sizes on the face of collars, bearings, and other machine tool components. Wrenches are hinged to fit a range of diameters.
Wrenches
Replacement
Pins Square
Drive Size For Circle
Dia. Pin Dia. (Pin Lg.) Overall
Lg. Material Finish
Each
Each 1/2" 1"-3 3/4" 7/32" Dia. × 1/4" Dia. (3/16" Lg. × 3/16" Lg.) 3 1/2" Steel Black 69745A52 $63.65 69745A521 $8.85 3/4" 2"-6" 5/16" Dia. × 1/4" Dia. (3/16" Lg. × 1/4" Lg.) 5 1/2" Steel Black 69745A51 140.10 69745A511 19.56
Square Drive Dual-Size Adjustable Pin Spanner Wrenches for Holes on the Face
Wrench
Wrenches
Replacement
Pins Square
Lg. Material Finish
Each
Quoted: 2578 Post(s)
Liked 1,901 Times
Sometimes it takes a (long) while to free up a bottom bracket. How long has it been since that one was removed?
1. Apply penetrating oil.
2. Let it sit a bit.
3. Put the pin wrench on it. Double-check which way to turn it.
4. Give it a whack.
5. If it moves, unscrew and continue.
6. If it didn't move, come back tomorrow or the next day and start all over.
Maybe 10 years ago I had two bikes' BBs need replacing, about three months apart. Both of them took about 6 weeks to come free.
4. Give it a whack.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 669 Post(s)
Liked 725 Times
Heat gun and impact, though impact is harder with a pin spanner.
Liquid Wrench is not the best penetrant. I think PB Blaster is better. Some get even better results with an acetone/ATF mixture.
Quoted: 2026 Post(s)
Liked 1,095 Times
Done carefully, a pair of large Vise-Grips can work without damaging the cup. Pad the jaws with pieces of leather, rubber gasketing material or brass or aluminum shim stock to prevent marking the cup edges and clamp it on firmly.
Quoted: 1124 Post(s)
Liked 1,704 Times
I broke a pin wrench removing a cup as such, I ended up using a new pin wrench clamped in place using a torch to heat for loosening hardened grease and melting in PB Blaster to the threads. You can get things pretty warm, or hot to the touch with out damaging your paint.
Quoted: 2475 Post(s)
Liked 722 Times
The 'whacking' mentioned in a previous post is important. It may be 'the' thing that does it. Assuming the direction of force is in the right direction. I read it should be counter-clockwise on the drive side, and also counterclockwise on the non-drive side. I don't know if that is universal but that's what worked for my particular frame. But the initial torque to get things started should be of an impact nature.
Likes For Leisesturm:
Liked 2,742 Times
this is pain because of duplicate threads so to repeat from the other thread
Get the drive side of first
then use the sheldon brown bolt remover method
Mad bike riding scientist
Quoted: 6147 Post(s)
Liked 4,093 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Expired Member
Quoted: 3638 Post(s)
Liked 5,316 Times
I've used PB Blaster but the 50-50 homebrew might make it easy to fill the bb.
Forum Moderator
Quoted: 3059 Post(s)
Liked 6,379 Times
Merged duplicate threads.
Quoted: 339 Post(s)
Liked 623 Times
After using as much force as I could at home without success and applying liquid wrench both to the outside and (through the bottom bracket cut out holes) from the inside I figured I would have to take the drive side off and use the bolt and nut method to try and get the adjustable cup off. Using the spindle nut and washers to clamp my thin wrench to the drive side cup I still couldn't budge it . The shop at the Bike Exchange has a dedicated wrench for this that completely encircles the cup so I took the frame in , hoping that with some help and a long breaker bar we could shift it.
As I was getting the tools together another volunteer offered to help me. He produced a Park pin wrench, and proceeded to unscrew the adjustable cup easy peasy. Apparently the penetrating oil had finally done it's job. The forking thing unscrewed with absolutely no effort at all.
Note I just ordered a can of Silicroil from Amazon. If I have to use penetrating oil I might as well use the best.
Likes For capnjonny:
