One vs Two Wheelsets
Old 12-09-21, 06:57 PM
Noonievut
Quoted: 286 Post(s)
Liked 261 Times in 129 Posts
I’ve been thinking of pros and cons of
1) One really good wheelset and maybe 38mm tires, tubeless that are good enough at both road and gravel
2) Two Wheelsets: one with 30-32mm tires for road rides, other with 43’s for gravel/mixed surface
Wondering how others have thought this through? I love getting lots of perspectives before deciding.
Noonievut is offline
Old 12-09-21, 07:47 PM
Random11
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times in 197 Posts
If you're riding solo, I don't see much of an advantage to a second wheelset. I have a Specialized Diverge with 700x38c tires that does fine on paved roads, in addition to light gravel. New wheels might increase your speed a bit, but I don't think it will increase the enjoyment of your ride (and may decrease it if it results in a harsher ride).
That said, I did get a second wheelset with 700x30 tires... but I also got a second bike to go with the new wheels (Cervelo Caledonia). I can tell that the Caledonia is faster and more responsive than the Diverge, but all-in-all, it is no more enjoyable to ride, and I ride them interchangeably even on 100% paved rides. If I'm riding with a group, I'll take the Caledonia to help me keep up. Otherwise, the Diverge is as enjoyable as the Caledonia. Based on my experience, I don't see the value of a second wheelset.
But, you said you have a lightweight skinny tire road bike. So (1) why not just keep that to use if you want different wheels? Also (2), you can see the difference new wheels would make, at least somewhat, by comparing your road bike with your gravel bike. So, you could answer your own question.
Random11 is offline
Likes For Random11:
Old 12-09-21, 07:49 PM
sean.hwy
sean.hwy's Avatar
Quoted: 426 Post(s)
Liked 274 Times in 201 Posts
I have a aero road bike systemsix and a gravel bike giant. I prefer to ride my gravel bike with my road wheel set. It's also nice to go out town with the gravel bike with two sets. The gf and I can take two gravel bikes and two wheel sets and not take up that much room to ride 95% of anything.
I have a few friends with aero bikes that like to fly. On those days I will take my aero bike out and try and keep up. I think my aero bike with aero carbon wheels is probably about 1mph to 1.5 mph faster than my gravel bike with the same carbon wheel set on it.
sean.hwy is offline
Old 12-09-21, 08:49 PM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3646 Post(s)
Liked 5,378 Times in 2,730 Posts
Originally Posted by Noonievut
I’ve never had a strong view on this and with the gravel bikes I’ve owned over the years I don’t feel I had this paradox solved.
There are stock 700c WTB rims i19 / 32 spoke on the bike. Running the stock 40mm Ventures for now. .
What gravel bike did you finally get? I've gotten confused by all the threads, I must have missed it.
shelbyfv is offline
Old 12-09-21, 08:55 PM
Noonievut
Quoted: 286 Post(s)
tbd
Likes For Noonievut:
Old 12-09-21, 09:01 PM
Steve B.
Quoted: 3221 Post(s)
Liked 2,043 Times in 1,169 Posts
I got a second wheel set for my Topstone, has 28 mm tires, which on wide rims ends up at 31mm. I run 70-80 psi for a very comfy ride, better than my carbon with 25mm at 110 psi. As well, when I go on vacation its great to just carry a 2nd set of wheels, two bikes in one, gravel and pavement ready.
Steve B. is offline
Old 12-09-21, 09:30 PM
chaadster
Thread Killer
Quoted: 3125 Post(s)
Liked 1,694 Times in 1,025 Posts
Definitely two wheelsets, if only for seasonal variation. It’ll make getting the knobby rubber on for winter and spring a breeze, and you can run smoother, lighterweight rubber in the warm, dry months.
Also, i23s are heavy, so if you get a lighter wheelset, you can improve the feel of the bike…assuming you’d think livelier is better. Admittedly, there are conditions where sure-footedness is appreciated, too.
chaadster is offline
Likes For chaadster:
Old 12-10-21, 08:52 AM
tdilf
tdilf's Avatar
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times in 70 Posts
I sold my road bike so I have two wheelsets, one for road mode and one for gravel. Also the original wheelset is fairly heavy so I wanted my other wheelset to come in under 1500 grams for the set.
tdilf is offline
Old 12-10-21, 10:54 AM
jonathanf2
Quoted: 445 Post(s)
Liked 1,037 Times in 440 Posts
If you have tame gravel why not get a set of semi-slick gravel tires? I can still hang with my road bike buddies, while still being able to roll on dirt packed trails and gravel. You can also consider something like 35c tires, which would be a nice all-around width (decent acceleration and more traction/cushion than 32c). I rarely put on my 2nd wheelset mainly because I still have to adjust my brake calipers and I have different brand rear cassettes which also require cable tension adjustment.
jonathanf2 is offline
Likes For jonathanf2:
Old 12-10-21, 02:26 PM
Rusty Peters
Rusty Peters's Avatar
Bikes: Trek Domane SL5
Quoted: 5 Post(s)
Liked 3 Times in 3 Posts
My experience exactly. My carbon wheels with nice tires gain me 1.5 mph average on any given ride. I refer to them as my "something to prove" wheels.
I have a Trek Domane with my road wheels and a pair of gravel wheels with 38mm Schwalbe tires. Unless I am riding with people on road bikes that want to go fast, I would prefer to ride gravel wheels. Better ride, more road options and fewer wheel changes before rides. I bought this bike as a "one bike" experiment and I find that it works well.
Rusty Peters is offline
Old 01-11-22, 09:39 PM
Hondo Gravel
Life Feeds On Life
Hondo Gravel's Avatar
Bikes: Too many Motobecanes
Quoted: 4405 Post(s)
Liked 4,520 Times in 3,022 Posts
I replaced my WTB stock wheelset with a custom one. The WTB wheelset is solid with 40mm WTB tires a worthy backup. Don’t want to be riding out at Big Bend NP have a wheel go Kaputz! without a backup. I have 2 wheelsets for my MTB for the same reason. It doesn’t have to be high dollar to serve backup duty.
Hondo Gravel is offline
Likes For Hondo Gravel:
Old 01-14-22, 06:08 PM
Steve B.
An advantage to a 2nd wheel set is big gravel tires on one set, skinnier slick road tires on another, bring both on vacation, best of both worlds,.
Steve B. is offline
Old 01-14-22, 08:08 PM
Noonievut
Quoted: 286 Post(s)
I ended up with the ‘seasonal’ approach. Stock wheels with 700x40 and 650x42 supple tires tubeless for rest of the year, paved and gravel roads.
Old 01-15-22, 12:24 PM
walnutz
walnutz's Avatar
Bikes: CO-OP ADV 3.1 aka Beeftank (stolen, RIP), State All-Road
Quoted: 96 Post(s)
Liked 144 Times in 75 Posts
The answer is one quality wheelset with one quality set of fat slicks, 650b preferably. I use Rene Herse Switchback Hills for everything from single track to road. (Rene Herse can o’ worms officially open now)
walnutz is offline
Old 01-15-22, 03:51 PM
Noonievut
Quoted: 286 Post(s)
My 650b is the Babyshoe, and I agree about one quality wheelset. However, for short rides exclusively on loose gravel, dirt, mud, and winter riding, I’ll keep the Babyshoe’s at home.
Old 01-15-22, 04:40 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3870 Post(s)
Liked 2,563 Times in 1,577 Posts
I ended up with the ‘seasonal’ approach. Stock wheels with 700x40 Ventures that are very sticky so great for winter. 650x42 supple tires tubeless for rest of the year, paved and gravel roads.
You're probably aware, but this will change the BB height considerably. Gravel bikes are often spec'd with 700x40-42C or 650x47-50B to minimize that difference...
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 01-15-22, 07:11 PM
Noonievut
Quoted: 286 Post(s)
I am, thanks. With 700x40 I’m higher up than I like, with the 650b the very bottom of the pedal is more than 9cm above the ground, which feels good
Old 01-17-22, 10:04 AM
showlow
showlow's Avatar
Bikes: Lemond Zurich, All City Macho King Ace
Quoted: 105 Post(s)
Liked 53 Times in 33 Posts
Been enjoying having two sets.
One set is lighter and has tubed 28c road tires. Tubed tires can sit forever and require no "maintenance" and are always ready to go. Worst case I just need replace a tube.
My other set is built a little more stout and runs WTB Resolute 42s (the best tires). They're tubeless and it's hot where I live so they aren't totally maintenance free. The sealant dries out. I have ripped a hole in one once and it's a whole ordeal to get it running again. I use these for up to light single track and on mixed rides.
The only thing is that the rotors don't align perfectly between sets. So swapping from one set to the other isn't as easy as you might be hoping. It's not hard though. Just fiddle with the pad alignment (easy for me w/ my TRP Spyres) and then you're off.
showlow is offline
Old 01-17-22, 10:10 AM
Jeff Neese
Quoted: 1081 Post(s)
Liked 681 Times in 438 Posts
I've enjoyed having multiple wheelsets for a long time, and right now I have three wheelsets I can swap between two different frames. The rims are identical so I don't even need to adjust the (rim) brakes. I can ride skinny, medium, or fat tires, and choose between drop and flat bars. It's like having six different bikes.
Jeff Neese is offline
Old 01-17-22, 11:02 AM
Noonievut
Quoted: 286 Post(s)
I love the idea but so far I’ve not enjoyed the finicky brake alignment I’ve needed to with the few bikes where I’ve tried this (hydro brakes). I’m still figuring this out, hope to solve it one day!
Old 01-17-22, 11:51 AM
biker128pedal
biker128pedal's Avatar
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 265 Post(s)
Liked 447 Times in 266 Posts
Have you tried shims. I saw some online. When I get a second wheel I may beg too try them.
For now I use tubes and swap tires. I hand the tires not installed with the tubes partially inflated. This make swapping quicker.
biker128pedal is offline
Old 01-17-22, 12:11 PM
Noonievut
Quoted: 286 Post(s)
Yes, on a previous bike. It was a CX bike with Spyre brakes. That system worked very well.
Old 01-17-22, 12:16 PM
pbass
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times in 211 Posts
Never thought much about a second wheelset before but since putting knobby Senderos on(which work great for my regular routes where I live but are overkill at other times), I've been contemplating it--would be nice to have a second set on the other end of the spectrum--something slick. I personally found Ventures to be a pretty acceptable middle ground though - might go back to those and keep it simple . . .
pbass is offline
Old 01-17-22, 01:54 PM
msu2001la
msu2001la's Avatar
Quoted: 1455 Post(s)
Liked 1,477 Times in 867 Posts
I like having multiple wheelsets on my CX bike. I have one nicer carbon wheelset that I mainly use with road tires, and run the off-road tires on my heavier alloy set. During the fall CX racing season I'll switch that around and run CX tires on the carbon wheels, and use the other set as either a backup or with road tires for easy swapping.
So far the disc brake adjustment between sets hasn't been an issue. I had my shop install shims on one set to get them better aligned.
msu2001la is offline
Old 01-17-22, 04:44 PM
Dino_Sore
Dino_Sore's Avatar
Quoted: 34 Post(s)
Liked 57 Times in 38 Posts
Two sets. Buy more stuff. Moderation shows a lack of commitment!
Dino_Sore is offline
Likes For Dino_Sore:
