Cartridge bottom bracket for Suntour Blaze cranks?
Hey folks,
Trying to pick a bottom bracket for these cranks and I don't know much about some of these specs, eg. I can pick a 110mm bottom bracket but what do I need to consider about the "asymmetrical" and "3L standard" specs mentioned on velobase:
BB Length: 110.5mm asymmetrical (3L axle standard) https://velobase.com/ViewComponent.a...17b5a&Enum=115
Is there a common cartridge replacement for that or will I just have to do some guesswork?
Thanks!
Probably ugly to most people here but I kinda like the hidden chainring bolts
Thanks!
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
Link says 3I not 3L
This shows 28 x 52 x 30.5 for a 3I
https://www.walmart.com/ip/Sunlite-B...-Bike/51751365
https://www.sheldonbrown.com/bbsize.html
Link says 3I not 3L
Really Old Senior Member
There is also a 3L. See the pdf
Yes, very informative now that I know what I'm looking at. I also have a GPX crankset which velobase says uses a 113mm BB, but my GPX spindle is marked 3L which that doc says is actually 116mm symmetric, odd to me since they are both early 90s road doubles, you'd think Suntour would just use the same bottom bracket size...
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1944 Post(s)
Liked 1,468 Times
The spindle length needed depends on both the frame as well as the crankset. If there is already a compatible bottom bracket on the bike, I suggest first installing the right crank arm (with chain rings) onto the existing bottom bracket to gauge the chain line -- the line between the mid-point between the two chain rings (assuming a 2x setup) and the middle of the cassette, which should be parallel to the top tube -- then removing the existing bottom bracket to read the specified spindle length, then buy a new bottom bracket with the same or a different spindle length depending on whether you need to move the crankset inward or outward to get a chain line parallel to the top tube.
SE Wis
Liked 3,391 Times
