Recurring Flat tire alex rim rc24
Hi all,
I’ve had 5 flats both front and back over three weeks on my bike. I have newer corsa tires but these flats also happened on another tire set. I’m going crazy - I don’t see any issues. I’m actually thinking of just getting a new wheelset. Anything I should look for or note? I ran various tire pressures between 120 and 140.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Much more info is needed to ascertain how to advise. Tube or tubeless? Assuming tubes, where on the tube is the puncture occurring? Is it more of a puncture or a rupture? Are you patching the tubes or mounting new ones. Are you doing the repair or do you take it to a shop? Any issues (like goat heads) prevalent in your area? What have you done so far to figure this out?
Likes For Moe Zhoost:
I’m mounting new ones each time and doing it myself.
Seems like a puncture. Today it blew about 15 k from home and I managed to limb back. It probably went from 140 psi to about 80 to 60. It started hissing loudly and then stopped. I took advantage of the stop and flew home.
It happened at the stem once. I reinforced the tape in that area.
One time I spun the road on the rim under heavy braking - I think the tire slipped on the rim.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Your pressure is wayyyyyyyy too high. Moving on from that...the very first thing you should be doing when you flat is to pump up the punctured tube and find the hole. Always. First thing. When you find that hole have a close look at the tube and determine whether that hole would be against the tire or the rim. This will make it very easy to find your problem. Did I mention your tires are inflated wayyyyyyyy too hard? How much do you weigh?
Likes For cxwrench:
What can I say, I always want to go to the edge…
Bikes: lots
Liked 2,932 Times
Your bike will roll better, have more comfort and more traction w/ lower pressure. What size tires? Riding at 140 is just ridiculous.
Likes For cxwrench:
Bikes: lots
Liked 2,932 Times
I'm the same weight as you. First thing I would do is buy bigger tires. 25 or 28mm. I'd inflate 23mm tires to 100 rear at most. More likely 90-95 rear and about 10psi less for the front. I will never ride 23mm tires again. There is just not enough air volume for them to both be comfortable and protect the rims. For every size larger tire you can drop 10psi to keep the same feel, but as you gain air volume you can go a little lower. I'd ride 25mm at 85rr/75frt and the 28mm tires 10psi less than that.
Likes For cxwrench:
and thanks to everyone - I’d say the pressure solves it.
Quoted: 1455 Post(s)
Liked 1,477 Times
I agree that you should be riding lower pressure. I'm 165lbs and when I rode 23mm tires (10 years ago?) I ran them at around 100psi.
That said, while 140psi seems a bit extreme, I don't think that is causing you to get flat tires. I'd suggest removing the existing rim tape/strips and installing new, paying special attention the valve stem hole so that there is no exposed metal. Also check your tires carefully to make sure you haven't picked up a tiny shard of glass or metal that is stuck on the inside of the tire.
Likes For msu2001la:
Are you checking the tire?
I was having this problem a while back ago. The culprit was a very tiny thorn in the tire. Visually inspect the tire than run your fingers carefully on the inside of the tire.
I ran 100 psi and got another one...
It looks like something cut the tire hence why I wasn’t feeling anything. Could this be it? It’s a tiny hole.
Quoted: 20808 Post(s)
Liked 9,450 Times
Aside from the aesthetic reasons, it helps to locate the site of problematic flats - find the puncture location on the tube, relative to the valve stem, and then find the corresponding spot on the tire, relative to the logo. You really shouldn't have to be asking "could this be it?!" if you play your cards right.
Likes For WhyFi:
