Clicking Noise When I Ride
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,637 Times
If you are over 50, it is more than likely one of your knees.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I recently had something similar. Started out as an occasional click or "tick." It progressively got more frequent and louder, and happened especially when I'm pushing hard on a climb. It developed almost into a creaking or groaning.
I started pulling things apart to inspect and try isolating it. One of my bottom bracket bearings was getting rough. I'm 90% sure this is the culprit.
I'm going to order new bearings. Haven't decided whether to buy the tool to pull off the old ones, borrow it from someone, or just take the crank to a shop and pay them for the work. In the meantime, I was able to pry the seal out of the way enough to pack in some new grease, and that seems to have worked as a temporary solution.
Habitual User
Quoted: 4946 Post(s)
Liked 8,085 Times
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I like how you think. Unfortunately, that attitude is how I got a garage full of bikes, enough that I can ride a different one every day of the week. Since I don’t want to get divorced, I’ll probably just replace the bearing.
Habitual User
Liked 8,085 Times
Follow me for more relationship advice.
Likes For Eric F:
Bonking Enthusiast
Sources of noise to eliminate include: handlebar/stem, headset, axles/skewers, rear wheel/spokes, pedals, cleats, shoes, rear derailleur hanger, chain, and finally bottom bracket.
I had a single click per crank rotation that I'd narrowed down to the bottom bracket. I ignored it for about a year, until it became louder and evolved into several clicks through one crank rotation. I could no longer stand it because I could hear it bouncing off walls, curbs, etc. A new bottom bracket seemed to take care of it, so far.
just to add recommendation on things to check, I just found the culprit of the ticking noise on my bike was a bad cartridge bearing (9000km+) on the inside part of the freehub
Grupetto Bob
Liked 5,637 Times
If you have Look Keo pedals, you have found the issue. Thought my bottom bracket bearings were absolute toast on one climb, then I replaced them with my old Deltas and the bottom bracket was miraculously healed. Praise the Deltas!
cycles per second
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 71 Times
WHen one of my bikes starts making a clicking noise while pedaling, it is almost always one ot the chain ring bolts. Snug them up and see if that fixes it.
